There is humming sound coming from the computer and the green light below the power buttom is flashing.
  • mrmpc Jul 08, 2008
    The computer is a dc 5100 and the green light I believe is the power indicator light
  • 6,487 Answers
Is the hum coming from the computer/case itself or the speakers? This seriously determines how you go about diagnosing the problem. If it's coming out of the speakers then it comes down to:
Checking for solid sound card connection (if separate) to motherboard
Checking for loose audio cables
Trying different speaker product
Trying out a set of headphones
The point is to try one thing at a time to see what might be the cause.
Now, if the sound is not coming out of your speakers then most likely it is an issue relating to something with moving parts. This all relates to hardware so it may or may not be something you are comfortable doing. Possible sources of the hum could include:
Hard drive(s)
Fan(s)
Loose screws (in the computer, not the owner)
Power supply
If the hum is present at all times then I would try the following:
First open the case and see if you can tell generally where the sound is coming from. If it sounds like the hard drive, turn the machine off, disconnect the power connection of your hard drive and see if the sound is present when you turn the machine back on. It won't boot but at least you can listen for the hum. If it's the hard drive then I would suggest you make sure the screws holding in the hard drive are tight. Ultimately, I would recommend replacing the hard drive. Most new drives include software for copying your old drive's data to the new drive. You may want to make a separate backup first, though.
For each fan, while the PC is running you can push on the center of the fan to momentarily slow down or stop the fan (be careful to not touch the fins as that might be a bit painful). If you notice a change in the hum volume then you have found your culprit. I have been told that sometimes you can oil a fan but that may depend on the fan.
Make sure all your case screws and electronic connections are tight. Make sure all cables are not touching anything with moving parts. When I got a new machine a few years ago, there was a terrible noise the first time I turned it on. It turned out the case fan cable was hitting the case fan blades. I fixed this with a small zip tie to the case.
If it seems like the power supply is the source you could always replace it and see what happens.
Hope that helps.......
Posted on Jul 08, 2008
  • 487 Answers
Ok this can be 3 things which you will have to determine one by one.
cd-rom is buzzing and broken. ( either cd is still inside or just broken)
2 hard drive is going bad and that will creat a buzzing sound too
3 or your cooling fan from either power pack or cooler fro cpu is dirty. Blow it out with vacuum. and clean it and it should take care of it. If really broken not hard to replace
    Genius:
  • 1,847 Answers
The green light is the hdd light that will flask. the humming sound should be a fan or hdd.
  • Legin Varghese
    Legin Varghese Jul 08, 2008
    for the you have to open the tower and disconnect the hdd/ fan and chk. remember there is also afan inside the power supply.
    Genius:
  • 2,028 Answers
You didn't list the make and model, what is this light for? Power light, cd drive, etc...
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
The tv Sony kdf-42we655 will not turn on, the light will flash green and make a humming sound but thats it, the light below that labeled "lamp" flashes red? Why is the tv not working properly and why is...
Your tv is a projection one - it uses a very powerful lamp/bulb to generate the light that used for the image. In your tv that bulb has died and must be replaced - it will cost about $200.
Jul 05, 2010 | Sony KDF-42WE655 Television
I actually have a 250. bulb is new but stopped working. When plugged in green power indicater lights then flashes two red lights.
The projector is bloked, you need reset the lamp timer. Press and hold the VOLUME + buttom, then press the VOLUME - buttom. Hold both buttons down for 10 seconds.
Jun 16, 2010 | InFocus LP 240 Multimedia Projector
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red light stops...
this happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
I HAVE A Z-2300 NO SOUND
Is it plugged in with a 3.5 millimeter jack? If it is, pull it out of the computer and press you thumb on the tip, if no humming noise comes out, your speakers are probably blown.
However, if a humming noise does come out. Please check to make sure the volume on the computer is turned up/unmuted, the software's volume is turned up/unmuted, your sound card driver is installed (Right-Click "My Computer" -> left click on properties -> Click on the Hardware tab -> click on "Device Manager" -> Click the "+" next to "Sound, video and game controllers" and make sure there is no Red "X"'s or yellow "!"'s.
If you do get a hum, and you do have everything set up right in Windows, try a different pair of speakers or head phones. Your sound card might be fried.
Also, make sure you're plugging the speakers into the correct port on the computer (It's usually a washed out green port"
Mar 01, 2010 | Logitech Audio Players & Recorders
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
My rca tv
a high pitch sound.. usally indicates a shorted horizontal transistor or possibley a flyback or both. common problem for this set
Dec 10, 2007 | RCA F31672ET TV
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
