Question about Vacuums
Shower works fine when cold but hotter it gets the less water flow there is
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
if you have strong hot water pressure in the other parts of the house, you may have a clogged or defective shower control valve.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
Hoover Spinvac F5915900. Trigger no longer causes a release of soapy water on floor. It doesn't have tension, fairly loose, but still in slots. How do I fix this problem?
The trigger that you pull to release water snaps into plastic pieces inside the handle where it pivots to push on the rod that goes down to push on the regulator that lets the water flow. If the trigger is pulled too hard it can break the plastic it pivots in. If this happens the rod doesn't push hard enough on the regulator to let the water flow. Remove the screw at the top of the handle to remove the handle part holding the trigger to see if this could be causing your problem.
Jan 28, 2017 | Hoover Vacuums
The shower does not heat up the water but the power is there
Possible failure of the heating coils inthe geyser. If there is power you will need to check the resistance of the heating coil to confirm if the heating coil is open.
there can be no other reason if the switch and power flows.
helpful?
Aug 29, 2010 | Vacuums
The water and soap are not coming out of the cleaner. It is heating and pulling air back through.
Related issue: In general, if plain water is not run through the system (and drained out!) after each use, the water can leave "boiler scale" in small inlet and/or outlet tubes on the heater (up inside the handle). If it fills the inlet/outlet tube, this will stop ALL water flow, even if you're not using the 'heat' function, because the water goes through the heater whether the heater is on or off. I was able to get the flow going by digging out the corrosion from inside the inlet/outlet tubes on the heater where the clear, plastic, inlet and outlet hoses attach. It's been working fine for a few years since the fix.
Aug 01, 2010 | Bissell 1699 ProHeat Clear View Upright...
Poor flow takes two cycles to brew one cup. Heater working etc. Something stuck inside inner tube? Sucking air somewhere? can it be dis assembled?
This problem is usually caused by calcium carbonate deposits from hard water collecting in the thermal pump mechanism. The fix is to make a 1/2 pot mixture of white vinegar and cold water (about 50:50) and run through several times. Let cool off each time, and use a clean filter to catch the deposits that are removed. Finally, run several pots of cold water to wash out the vinegar taste. Hope this helps!
Jun 25, 2010 | Vacuums
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
Hoover steam vac..F7452-900. not working in wash-auto rinse mode
This problem sound like you hav a problem with the pump. I would take it to a shop for service
Sep 26, 2009 | Hoover F7452-900 SteamVac Upright Vacuum
Don't know how to use carpet shampooer
You should have the new aquamate, it has a blue top to fill with the water and water/soap solution that pops down into place. You will need to use your power nozzle hose and tube, connect it to your shampooer (make sure to connect the power connection just like the power nozzle). Fill your water up, large compartment is for cold water only and the smaller compartment is for one cap full of soap then the rest filled with cold water. Start with just a splash of water or an empty basin in the rainbow. The trigger will control your water spray and the brush underneath. There are two levers on the back of the shampooer marked with a shower head and a bar of soap. Use the soap with the shower head and the soap on and the water only with just the shower head on. You will want to also go over the area shampooed with both off to **** up the remaining water. Make sure to clean your floor thoroughly before shampooing.
Aug 13, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Bissell 8930 Pro-Heat wont dispense water/cleaner onto floor, but attachment works fine.
The water solenoid that controls the flow of water to the floor nozzles is prone to and known for failure. Replace it. Less than $12.00 part.
Jul 21, 2008 | Bissell Vacuums
No water/soap to carpet, but upholstery attachment works fine.
If the hose is spraying, then the pump is working. The pump is a common problem which is why the repair shop assumes that it is the problem, but their repair cost is way out of line. The more likely cause could be the heater. The heaters on these machines have been problematic in the past. The heater is heating water and soap and quite often they will plug up and then the water will not flow. The heater is used for the floor spray but not the hose. It is also possible that the floor spray jets are plugged or that the indicator dial is fowled with something and will not allow solution to flow. I would suggest finding a different shop to take it to and make sure they find the trouble before repairing and give you a more resonable estimate. This should fall somewhere in the $60.00 repair range.
Mar 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
Sprays soap, but not water
My Bissell is quite fussy. Sometimes I have to wiggle and push down the tank before the water will start to flow. The water doesn't flow properly if the soap container is low - I fill it with water when rinsing. It has a viewport with a red cross that turns when the water flows. Sometimes just removing that and the white filter below (and putting them back) makes it go. Mine is easy to take apart - 6 screws in the base unit and the top comes off. There are two water tubes going into the handle hinge under where the water tank goes - very easily squished or damaged. Last time the water stopped flowing, I ran it with the cover off and just fiddled around with the tubes and away it went. Maybe it is spraying soap only. The water flows up through the handle to the finger valve and heater. Some people say the heater in the upright/handle gets plugged. I haven't had that apart, but it should be easy to bypass the heater.
Sep 07, 2007 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
21 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
