Question about Sony KDL-26U2000 26 in. LCD Television
We have a KDL-26U2000, the problem is the menu button doesn't bring up the menu?? When you press the button on the remote or the top of the tv the green light will flash so the tv must recognise that I'm pressing it but nothing happens? I've tried to reset to factory settings but when I've got into the service menu I can't input anything? Please can anyone help??
  • Sony Master
  • 5,568 Answers
Checking your remote can be done with any digital camera since they can 'see' the infrared light from them but I suspect the remote is working; generally, if they are emitting anything, it will be sending correct correct pulse trains.
Having the camera 'live' you will be able to see that the remote is working by aiming the remote at the camera's lens and pressing any button while watching the camera's LCD display. The output of the remote will appear as white or near white blinking lights.
Often the service settings require entering some code (password) sequence to access factory settings and it may not be possible to enter the code if one or the other end of the IR system isn't functioning.
Summary; I think the remote transmitter is OK but the receiver in the set is not decoding the received signal despite it indicating that something was received.
I think the set itself is a fault and you will need a tech on site on in the shop to search for the right board to replace since the IR receiver may be part of the main board (expensive) or a separate assembly (somewhat less expensive).
Posted on Jan 01, 2011
We have a Model un40eh5300fxza tv, where on the remote is the OK button
    images for where on the remote is the OK button
    More images for where on the remote is the OK button
    RC: Tv code so i can use ok/select button on comcast remote
    www.remotecentral.com > ... > Consumer > Original Equipment Remotes
    Mar 3, 2010 - 13 posts - ‎7 authors
    I have the comcast dark grey remote and a vizio lcd tv .when i press the tv button i then can press the menu button it brings up my tv menu and ...
    Button Functions by Remote ' MyDISH ' DISH Customer ...
    https://www.mydish.com/support/.../remotes/button-functions-by-remote
    Register, Button, Button Sub-Category, Function, Condition ... on screen menu/pop-up, -. 2, Color Buttons, -, -, Function varies by screen and customer selection.
    Select/OK button doesn't work when Using Comcast remote with ...
    www.avsforum.com/...remote.../1533595-select-ok-button-doesn-t-work...
Jan 07, 2016 | Samsung Televison & Video
I have no remote, how do I get off close caption on a TS2554C101
There is a Menu button on the TV for the TS2554 C101. Press this button to get the OSD menu. Then press the vol +/- buttons to highlight Set. Use the Ch +/- buttons to get Closed Caption. Then press Vol+ or Vol - to get the closed caption menu. Use the Ch+/- buttons to set the desired closed caption setting and then press Vol + or Vol - to confirm the selection. Press Menu again to exit.
This will only help if the captions are being interpreted by the TV. If there are open captions, they will not go away. If the closed captioning is on at a set top box, you will need to turn them off using the controls for the set top box. (I know satellite receivers have independent captions available.)
I hope this helps. If your TV doesn't have a menu button on the set, you will need a remote that has a matching Menu function. Some universal remotes should have this feature.
Apr 28, 2011 | Philips TS2554C 25" TV
The guide button no longer brings up the tv listings
This problem lies in your cable remote. Try pressing the satellite or cable button on the remote given to you from your provider and try to bring up the guide again. If it doesn't work, contact tech support from your provider and have them walk you through configuring the remote.
Apr 03, 2011 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Can the sony bravia kdl-40ex500 can change the display language menu from english letter to french letter?
Please press Menu button on tv remote to pull up menu then go to Setting menu and change Language settings as per desire.
Hope this will help.
Thanks.
Mar 26, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Hi i have one tv sony lcd model kdl-26u2000 and it is off
Check the power to the TV by plugging something else into the socket.. If it is getting power the power supply of the TV will need to be looked at by an engineer.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Sony KDL-26U2000 26 in. LCD Television
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
Menu not working.........
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Panasonic TC-26LX60 26 in. LCD Television
Loss of freeview channels
The retuning process is as follows:
  1. Press the [i+] button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If toy wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
Feb 08, 2008 | Sony KDL-26U2000 26 in. LCD Television
Sony KDL-26U2000 26 in. LCD Television Logo
482 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
