Question about Foxconn P4M800P7MA-RS2 Motherboard
What file to download to upgrade bios for ram?
  • 23 Answers
Here you go : )
Foxconn BIOS
Posted on Jan 01, 2011
What are the instructions for flashing BIOS?
Hello use auto detect here to find the right mainboard:
http://support.asus.com/download/options.aspx?SLanguage=en
Download asus update, this is the easyest program to upgrade the bios, while windows is running.
Install first asus update:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
When the mainboard is found, select download, and select your windows system.
Open the bios folder, and download the latest bios version.
Unzip the bios file.
Run asus update, and select update bios from file, and select the bios file, in the folder you just have downloaded ( the bin file )
Be very carefull when you upgrade the bios, because a power loss will damage the mainboard, while the upgrade process is running.
You also have to setup the bios settings, when the job is done.
You have to select F1 or F2 to enter the settings.
If any doubt download the manual.
Good luck
Feb 07, 2013 | ASUS Computers & Internet
I need m2n68-am bios bin file
Hello download here at asus:
http://www.asus.com/support/Search-Result/?keyword=m2n68-am
Select download and your windows system.
Open the bios file folder.
Click on global for download.
Unzip the file.
Make also sure it`s the right mainboard, because flashing the bios with a wrong one, WILL destroy the mainboard.
Use the asus update utility, to upgrade the bios, while windows is running, for a safe upgrade.
Good luck
Jan 15, 2013 | ASUS Computers & Internet
A8n-sli will not enter BIOS,just hangs,restarted a number of times with no success. Even switched from p2 keyboard to wireless again nothing. Cleared the cmos did not help either. FYI just resolved a...
Hi, from here you can download a manual:
http://support.asus.com/Download.aspx?SLanguage=en&m=A8N-SLI&p=1&s=21
Please select your operating system.
Select manual and click on global for download.
The file has to be unziped before you can read it.
Maybe you just need a driver or a bios upgrade.
For the bios update you need to download the asus update utility.
It can upgrade the bios while the system is running.
Good luck.
Sep 02, 2011 | ASUS A8N-SLI Motherboard
HOW TO UPGRADE INTEL 945GCLF MOTHER BOARD BIOS. BIOS VERSION IS "LF94510J.64T.0000.2009.0123.1105" & BIOS SOFTWARE VERSION IS AVAILABLE ON SITE IS " LF94510J.86A.0038.EB " WHEN I...
It seem your current version "LF94510J.64T.0000.2009.0123.1105" doesnt have any BIOS ID's which is required to upgrading. Where '0000' should have any version number.
I recommend using DOS environment when upgrading BIOS, this is the safe way flashing BIOS..so download file LF94510J.86A.0278.BI.ZIP here.
Extract all files on USB flash disk which is bootable flash disk. Run files executable on the command prompt and follow the instructions..
Aug 07, 2011 | Intel Computers & Internet
UPDATE MY BIOS.
im sorry alot more information is needed here, make? model? bios version running now?
Mar 25, 2011 | Computers & Internet
Hello which bios file do I need to download to perform a 2gb RAM upgrade?
Just buy the memory and install it.
You should not need a BIOS upgrade. If you give me your brand and model, I can double check but I doubt if a BIOS upgrade is needed.
Aug 14, 2010 | Computers & Internet
Need BIOS update for my MX6424 Gateway with Win XP
If your board is not supporting the 2gb memory module, it won't make any difference by upgrading the BIOS.
Aug 27, 2009 | Gateway MX6424 Notebook
I want bios driver (bin file) for my intel destop board d915gav/d915pgn
The BIOS bin file is a BIOS upgrade file. It is used to flash the BIOS to upgrade the BIOS version.
This file is has to be downloaded from the motherboard manufacturer's WEB site.
Jul 24, 2009 | Intel D915GAV Motherboard
Slow for open file at freehand mx 11
The most common reason for slow processing speed is insufficient RAM memory.
Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
May 18, 2009 | Macromedia Freehand MX 11 for PC - Upgrade...
Updating BIOS
You need to upgrade your bios.
Heres the link the software.
ftp://ftp.work.acer-euro.com/notebook/aspire_5630/bios/Bios%203.23.zip
You will need winzip or winrar to open the zip file just google either if you dont have them you can get them for free.
You then need to open the folder you just uncompressed and you will see another zip file, winflash is in there. it will allow you to flash the bios from within windows, just install it and follow the instructions on your screen
Dont forget to rate this solution
Aug 23, 2008 | Computers & Internet
Foxconn P4M800P7MA-RS2 Motherboard Logo
27 people viewed this question
Top Foxconn Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
