I use a h9 cybershot sony digicam with MEMORY STICK PRO DUO... i had to remove the memory stick after it had reached its capacity limit of 2GB. when i inserted it again later, the memory stick wasn't detected and i got a msg saying : " insert the memory stick again " !
i can't access the memory stick anymore n thus the pictures saved on it ..
i desperate help .... pls reply asap !
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
when i put my memory stick pro duo(1gb) in my Sony ericson P990i,,, my phone wouldnt detect the memory stick it would only show the contents of the phone memory but none for the memry stick
sony microvault 2 gb
