Question about Microwave Ovens
My gorenje washine machine wa72145bk comes up with f4 plz can u tell me what trhis means meny tnx vikki
2 Suggested Answers
  • 48 Answers
SOURCE: can you tell me what code F4 means? model
Code F4 means you need to repair the line to or replace the oven temperature sensor. The line typically runs from the display to the back of the oven, you'll have to trace it yourself. The oven sensor should be mounted to the back of the oven lining (Obviously on the inside) by two screws. Disconnect the power from the unit and unmount the sensor to check it, you should have around 1080 ohms of resistance but first you'll have to get that annoying plastic housing of wires through the mount hole and disconnect it so you don't lose it inside the oven. If you don't see screws from the inside of your oven than you'll have to remove the back panel to access them, but this may be a good thing as you don't have to worry about fiddling the plastic connector piece into the oven. You're measuring the resistance from one lead to the other inside that plastic housing, again at around 1080 ohms in a 70 degree environment. If you're way off, or 5 - 6 ohms off, you'll need to replace the sensor. If the error occurs while cooking you can also run the oven hot, turn off and disconnect the power and take your measurements again. If they read the same your wiring harness should be okay and replace the sensor.
Oh and btw, you'll most likely have to splice the wires to adapt to your new sensor they're never the same.. not in my experience lately anyway.
Posted on Apr 25, 2010
LG LMV1813 F4 error code
F4 means sensor open, You have to check the Humidity sensor.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Jan 31, 2017 | LG LMV1813ST Microwave Oven
Hi i have a problem with my servis m6725w washin machine it drains and fills but wont spin the drum at all
Motor brushes? Thyristor on control board? Belt broken? Not a lot else it can be.
Dec 28, 2010 | Microwave Ovens
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    Can you tell me what code F4 means? model
    Apr 25, 2010 | Amana MVH230 Microwave Oven
    What does F4 on microwave display mean?
    This Kenmore is made by LG for Whirlpool. Confused yet? :D
    F4 means you have an open humidity sensor.
    There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
    At our Web site here, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
    A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
    But Sears parts can usually be obtained for far less here by entering either the part number.
    Apr 22, 2010 | Kenmore Microwave Ovens
    F4 shows only whirlpool microwave
    It may be a shorted oven temperature sensor (thermistor) but it depends on the model number.
    d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
    At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your model number).
    It should tell you what F4 means.
    You can find links to helpful exploded view diagrams and part ordering help here.
    I recommend that you bookmark that link to your favorites.
    Feb 09, 2010 | Whirlpool Microwave Ovens
    New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
    GE
    Microwave Fault Codes Failure
    Code
    Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
    Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
    Feb 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    On the screen it shows F4, and F3
    F4 means an open humidity sensor, but sometimes this error is bogus and can be reset by unplugging the oven for a minute or so.
    F3 on a GE / Hotpoint microwave means you have a shorted keypad.
    If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
    There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
    If you would like to have us do this for you, we do that for $39.95 plus part costs.
    Feel free to contact me directly (and please remind me of your model number) for more information & help.
    William E. Miller † prototech@usa.net
    http://www.microwavedisplay.com
    Oct 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave Ultrawave with Hood fan
    You are right. f4 means shorted oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
    Apr 04, 2008 | Microwave Ovens
    Microwave Ovens Logo
    190 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
