Question about Toshiba Computers & Internet
I have purchased a toshiba satilite c650. how do you get the intergrated veiw cam to work
  • 74 Answers
-Toshiba normally comes with all the software/applications pre-installed. To quickly try and check it if it works, try using YM or Skype because this applications uses any default webcam available.
Posted on Jan 01, 2011
How do I access my web cam on my Toshiba satellite/satellite pro c650 series computer?
Your laptop should have come with software to use your web cam. If you can't figure out where that is, your best bet is the forums on the manufacturer's web site.
You can also download and install 3rd party software that should be able to use your web cam. You can try this one:
http://www.yawcam.com/
Donald
Feb 23, 2015 | Toshiba Computers & Internet
My intergrated Web Cam is not working.
Is the driver for it installed? Go to Device Manager, find your camera on the right side. It will be inside one of the menus, don't recall which one at the moment. If there is no driver it will display a yellow question mark. If so, go to the Toshiba website and download it for your model of PC and install it.
Aug 17, 2014 | Toshiba Satellite Computers & Internet
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
Toshiba satellite pro c650,Built in web cam working satisfactorily till yesterday. now giving message 'unable to find pc camera'. kindly help.
A couple of things to try.
1) Go into your BIOS and ensure that the webcam isn't somehow turned off in the BIOS. 2) Go into Device Manager in Windows, find the webcam. Right click on it and remove it. Then reboot the computer and let Windows find it, and reinstall the drivers again.
3) You may also want to reinstall the Toshiba specific drivers and software which likely includes drivers for the webcam. You may have a CD that came with the laptop, otherwise you can go to
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2769587&rpn=PSC13U&modelFilter=C650-Z2510T&selCategory=2756709&selFamily=1073768667
and reinstall the webcam application for your laptop.
Hope this helps!!
Jun 20, 2011 | Toshiba Satellite Pro C650-Z2510T Notebook
Hi. My Toshiba Satellite Pro C650's mouse pad isn't working. Neither are the buttons. I'm using an optical mouse right now so that I can navigate around my Laptop but I'm pretty worried about my mousepad....
just above the intergrated mouse area you will see a small button perhaps 1 cm long and not so easy to notice, press it and Hey Presto the mouse pad will work again, spent hours descovering this myself bloody badly designed machines these are. hope I have helped you.
Dec 31, 2010 | Computers & Internet
I want all the drivers of Toshiba Satellite Pro c650. Please its urgent. Thanks.
Please visit http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Communicate
Select the Downloads
This is how you need to select your model number and then select the operating system you have in your system.
Then you will get a list of drivers for your laptop.
Regards
Anand Sachan
Nov 02, 2010 | Toshiba Satellite Pro C650EZ1521 Notebook
Ws-65313
this is correct! this tv does not have the ATSC tuner built in. 1080i is a format of the digital broadcast approved by the ATSC. you must have a source of this format to veiw this format. standard cable boxes and satilite boxes altho digital are not outputing HD formats so you need to have the HD boxes to veiw HD 1080i and the broadcasters must be broadcasting HD to get true HD.
Sep 03, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
