Question about Gateway 4025GZ Notebook
What is the correct battery for the BIOS memory for a Gateway model 4025GZ notebook ?
    Brigadier General:
  • 8,909 Answers
Http://cgi.ebay.com/GENUINE-ACER-250-REAL-TIME-CLOCK-RTC-CMOS-BATTERY-/250619795738?pt=Laptop_Batteries&hash=item3a5a1a991a
Method.
When your Gateway computer is switched off, it still keeps track of various system information such as the date and time, thanks to a small battery that never powers off. The size and thickness of a dime, the CMOS battery can run out and need to be replaced. You can swap out a dead CMOS battery with a new one by removing the Gateway computer's side access panel.
Difficulty: Moderate
Instructions Things You'll Need:
  • Phillips-head screwdriver
  • CMOS battery replacement
  1. 1
    Shut down the computer. Remove the power cable from the back of the computer case. Disconnect the cables for the monitor, mouse, keyboard, and printer.
  2. 2
    Set the computer case over on its side. Use the Phillips-head screwdriver to remove the two case screws at the far left end of the case.
  3. 3
    Slide the side access panel to the left and remove it from the computer case. Find the CMOS battery port, which will be located to the lower left of the processor in most Gateway computer models.
  4. 4
    Lift up the plastic clip holding the CMOS battery in place. Slide a fingernail under one side of the battery and lift it off the motherboard port.
  5. 5
    Check the orientation of the new battery and compare it to the CMOS motherboard port. Push the new battery into place in the same direction that the old battery was facing. Push down the plastic clip.
  6. 6
    Set the side access panel back onto the Gateway computer case and reattach the case screws. Plug in the Gateway computer and power it on.
Posted on Jan 01, 2011
Gateway Solo 9550 bios unlock password master
There isn't one, either take the laptop apart and remove the CMOS battery for 10 seconds or download and burn hiren 15 to a CD and use one of the CMOS password wipers.
Jul 12, 2012 | Gateway Solo 9550 Notebook
Where do I find a working BIOS file for my Gateway MX6453? The update zip-file being offered at Gateway seem to be missing the new BIOS file named 1208.ROM...
remove the battery get some isopropyl alcohol and qtips and clean the contacts where the battery actually connects to the pc, if that doesn't work it's possible that the IC inside the battery has gone to hell and if that's the case you'll need to purchase another battery.
Jul 01, 2012 | Gateway MX6453 Notebook
Have a Intel gateway mobo model number DG33SXG2. Looking for a newer bios than original 2007 date. Intel site is worthless for this. Also want to replace existing Q6600 CPU with a Q9650. Will this board...
Gateway 4025GZ notebook Schroeder Town Motherboard BIOS Update v.DPP3510J.15A.0296 Note: This file contains the BIOS for the Intel(r) DPP3510J (Schroeder downico.jpg hope this helps
May 20, 2011 | Gateway Schroeder Town DG33SXG2...
I forgot my gateway model ML6230 bios password, i need a new password for it (reset the password).
A method you can try if you don't have a password reset software is by removing the CMOS battery. Remove the CMOS battery then turn the computer on. The system BIOS will be reset and password will be removed. Then you can put the battery back in. Click on this link for the Gateway ML6230 Notebook PC Manual. Check page 36 for CMOS battery removal instructions.
http://support.gateway.com/s/Mobile/Q106/Oasis/8511725_Service.pdf
Mar 21, 2011 | Gateway ML6230 Notebook
What is the small battery inside when you take off the back of a gateway mx8711
It is the back up power for the BIOS chip . The BIOS saves vital information about the computer's configuration and it must be continuously powered to maintain its memory.
Jan 09, 2011 | Gateway MX8711 Notebook
Swapping hard drives in laptops
if you want to use your old drive in your new laptop then your have go for new case 2.5" case which will fix your old HDD from USB prot u will able to use
frist chack your HDD it's ID or SATA according that u buy a case
Apr 21, 2010 | Gateway 4025GZ Notebook
Just got this used gateway 4025gz from a friend. i didnt have anything better so I put vista on it to clean it out and it runs fine but I cant get any sound. Drivers say they are up to date and everything...
Go to devise manager (Type Device manager on search box) and then remove/ uninstall the sound driver. Restart the laptop. Then it should work. If the same problem still there, Right click on sound driver and select update driver.
Jan 19, 2010 | Gateway 4025GZ Notebook
Gateway Computer, model CX2619 will not start
have you done any upgrades
EI memory or windows
Jan 22, 2009 | Gateway CX2619 Notebook
Solo 9559 can not pass the initial screen
it may be the bios.... remove the bios battery for at least ten minutes... make sure the main battery is removed
so there is NO power to the laptop for about ten minutes
.... after you reinstall the bios battery and put the main battery back in and plug in the external power.... boot it up again.
Robert
Sep 08, 2008 | Gateway SL9550-30165318 Notebook
Gateway 4025GZ Notebook Logo
273 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
