Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a Chamberlain Whisper Drive Security + model HD900D that is opening by itself awhile after the door has fully closed & I've gone into the house, sometimes its hours after the door fully closes. What causes this? Do I need to adjust the travel?
    President:
  • 3,197 Answers
If the door hits the floor too hard the safety will reverse it to the open position. This can be an intermittent situation. A bad wall control or the wiring to it will also cause this problem. To eliminate them you can remove the wire from terminal #1 on the rear of the motor unit. A staple in the wire can cut through the insulation.
Posted on Jan 03, 2011
How do I replace the motor and gear drive on Chamberlain MODEL hd900d OPENER
Purchase the full kit. Not the partial kit. The instructions come with the kit. Be sure to follow them. The position of the chain and the opener when you reattach the chain are Important. It's not beyond that the ability of a handy person.
Feb 20, 2015 | Chamberlain 1/2-HP Whisper Drive Belt...
The motor runs but it only opens a few inches and slowly goes back down its a chamberlain whisper drive model HD900D
Hi. I have seen this before, although usually not from chamberlain garage door openers.
Pull the release cord that unlocks the door from the opener, and manually open the door ALL the way open.
Then lock back in place in the open position.
Then use automatic opener to shut door.
It will close very slowly, but should close all the way.
Then, open the door again using the remote, and the door will once again open slowly, this time it should open all the way.
Then close door with remote, and door should now close as it is supposed, with the proper speed.
The slow opening and shutting is the system position sensor resetting itself.
This is why your door is acting up.
I would also look up by the belt drive connects to the front of the garage door opening, to make sure there isn't any dirt, cobwebs, or other obstructions on the sensor that may cause it to re-close the way it does.
Jan 24, 2011 | Chamberlain 1/2-HP Whisper Drive Belt...
I have a Chamberlain whisper drive 1/2 hp garage door opener model 9200 and when the weather is rainy or snowy out the door will close fully wait a second then open again. This happens until I can stop it...
It sounds like the door is traveling just a bit too far in the down direction. Locate the 'down limit' adjustment on the side of the motor unit and turn the control in the opposite direction of the arrow printed on the cover. Some tweaking will be necessary to get it just right.
Oct 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Upon pressing open/close button kitchen door the garage starts to close but then reopens after 3-4". one must then hold button until door is fully closed. what is remedy?
The problem is that your system does NOT "see" the safety "eyes" sensors. Make sure that your sensors are properly connected to the opener (both sensors should have lights on them, one amber and another green). If they do not, check the wiring and the connections at the opener itself.
Sep 09, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Chamberlain hd900d garage door opener
You will have to open the unit and look inside it. Unplug it first. It should have 6-8 screws to take off. You will see 3 white plastic adjustment screws. There is a carriage they sit in. Make sure they are in this carriage. If you would like stay back a bit and plug it in and watch it run to see how it works. It is a direct contact system, so when the middle screw touches the copper limit of the limit screw it stops. Thanks BB
May 20, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Random operation of Chamberlain HD900D garage door opener
As for all of us as Experts at Fixya. We would greatly appreciate if you would place your question in the right category so that an Expert with knowledge of this field can provide you with help. Sorry that I could not be of more assistants. I will inform other experts in this field of your issues so that they can redirect to help you. Thank you for using Fixya.
Dec 05, 2009 | Building Materials
Chamberlain garage door opener won't close
read manual, if you have, on trolley engagement
May 30, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
903 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
