Question about IBM ThinkPad T23 2647 Notebook
When i install vga compatible driver then computer ask me to provide ati2mtag.sys file
    Brigadier General:
  • 8,909 Answers
Install the original and up to date driver from IBM.com
That will sort it out.
Posted on Jan 01, 2011
I need the driver for a ST9250320AS disk, ive been searching for days.... for some reason... i can't run a driver scanner. when i try to install windows 7 on my laptop, it display an error asking...
how old is your computer
if your computer is asking for a driver when you insert the windows 7 disc your motherboard might not support windows 7 if its older than 5-6 yrs also you need a minimum of 2 GB of ram to support windows 7
hope this helps you
Sep 01, 2011 | Seagate ST9250320AS 250 GB SATA II Hard...
VGA DRIVER FOR ms 6524 ver 1 motherboard NOT INSTALLED NEED FOR MY COMPUTER
Here's the AWARD BIOS for you msi (Micro Star International)
ms 6524 mainboard/motherboard. It comas as an executable .EXE file. Upgrading/reinstalling your motherboard BIOS may solve your VGA "driver" problem, but drivers are
really the province of MSDOS/Windows - motherboards know nothing of drivers, and simply provide a BIOS to interface between the operating system drivers (the OS can be Linux,
or MS windows, or anything).
http://www.msi.com/product/mb/MS-6524.html#/?div=Download
To get the VGA driver for your MSwindows system, access your C:\Windows\drivers directory where you should find the file "vga.sys," which is the generic VGA driver for MSwindows. This driver will be referenced in the installation file Oemsetup.inf, which you will find in the C:\WINDOWS\inf directory - its ASCII, so you can open it up and read it with "notepad," or your favorite editor.
Use this link to determine which Video driver windows is actually using
when it boots (WinXP only):
support.microsoft.com/kb/314854
Use this link to FORCE windows to use the default VGA driver
even when running an unsupported monitor (which I suspect could be the problem you're facing).
http://support.microsoft.com/kb/268852
Jun 09, 2011 | Computers & Internet
I have Some Problem about my Video Controller VGA compatible.. It so hard 2 find a compatible VGA 4 my System hope u can Help me. here`s some information of my System.... Operating System: Windows...
To find video drivers for unknown cards, you have a couple options. If you are comfortable opening the chassis of the computer, you can look on the video card itself for its model number, and then google for that model number. I've always been able to locate drivers in this way. If you are not comfortable going the hardware route, there is an application called System Info for Windows (SIW.) It can be downloaded HERE. Once you install and run the application, you can click on the "Video" node and the model name will be shown on the right (usually in the PCI ID section.) You can then google for the model name and find the driver that way
Feb 28, 2011 | Computers & Internet
The is no installation for my driver download so i am unable to install it, is it too outdated?
some of the driver files can be installed by right clicking them and selecting install. Other drivers can directly be put into the right operating system folder when a normal installation fails.
What is important before trying the above is to make sure that the driver file you have is compatible with the operating system that you are trying to install it to or that it is at least compatible with the "generation" of operating system. For example, some Vista drivers work with Windows 7 but they will not work with Windows XP.
Providing more information concerning the product for which you try to install the driver and the type of driver file (.exe, .ini , .sys ...) will make it easier for us to help you.
Regards,
Jan 15, 2011 | Computers & Internet
hi.
mean that you need to download the necessary drivers
(Download in accordance with the display card used by your computer)
TQ
Jan 01, 2011 | IBM ThinkPad T42 Notebook
SM Bus Controller and Video Controller (VGA Compatible) drivers
You can download all Windows XP Home Edition drivers for the Intel D101GGC motherboard from Intel's web site at the following link:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go!
May 15, 2009 | Intel D101GGC Motherboard
Connect HP 3015 all in one printer to Aspire One
Disconnect the printer from your computer. Go to Start -> Control Panel -> Printers. Right-click on the HP 3015 printer and select Delete. Confirm the deletion of the printer. If it asks about removing unused driver files, answer Yes. Reinstall the driver files using the provided setup program. Do NOT use the Add printer... dialogs. If the installation program prompts you to plug in and turn on the printer then do so, but do not do this before it prompts you. This is what generally causes the missing files problem. If it goes completely through the installation without telling you to plug in the printer (which would be unusual for HP printers), plug it in when it completes. It should automatically recognize the printer being plugged in (and turned on, if necessary) and then finalize the driver configuration.
Mar 18, 2009 | Acer Aspire One PC Notebook
The file LV561AV.SYS on logitech USB Video camera Disk is needed
If you have driver/software CD of that webcam, then please try to reinstall it. It might work. If not then...
The same file is also available with Logitech Webcam
This is the site where you can download the Logitech drivers...
http://www.logitech.com/index.cfm/435/4266&cl=us,en?WT.ac=sc|downloads||dd
After downloading all the driver files... you can look for the file LV561AV.sys in it.
This is all I could find.
Please Rate if you find the above info of any use.
Dec 09, 2008 | Labtec 961307-0914 Webcam
Video Drivers
The file “Windows/System/Drivers/mup.sys” is not actually causing the problem. It’s the next step after mup.sys that’s causing the computer to hang. That next step consists of the OS checking the registry files for plug and play devices.
Some causes are: new or defective hardware installed, corrupted registry, (caused by virus), defective or corrupted hard drive, just to name a few.
Try removing all devices attached to the computer like printer, web cam, flash drives, etc.
If your computer has a PCI or AGP graphics card AND your motherbrd has a VGA connector, remove the video card and use the one on the motherbrd.
If the above doesn’t work, try running “CHKDSK /P” from the Windows recovery console.
Your responses are intended to improve the level of service provided. Please rate this solution.
Thank You.
Oct 18, 2008 | Dell OptiPlex GX260 PC Desktop
Problem with the Nvidia GeForce FX5500 256M DDR driver
Try this it will automatically detect the best driver for your Nvidia graphics card. (And yes its free)
Oct 06, 2008 | MSI FX5500-TD256 GeForce FX 5500, (256 MB)...
IBM ThinkPad T23 2647 Notebook Logo
85 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
