Question about Dell Latitude D610 Intel Pentium M 1.6GHz / 512MB DDR2 / 60GB HDD / DVD Payer/ CD Burner PC Notebook
Red light burned red and de laptop don't start up
    Guru:
  • 443 Answers
We wish you a Merry Christmas and a Happy New Year.
When did this happen?
Was there any variation is Voltage?
What happens if you switch on the laptop?
Do you hear the fan sound?
Post back,we will answer as early as possible.
Cheers!!
Posted on Jan 01, 2011
For the last few weeks, my 5 year old LG 2487HRMA, has been giving me de code errors shortly after starting. It is because the lock light just goes from red to off for no reason.
Lift up the top of your washer and there will be a code and test sheet in there that will help lead you to fixing that problem, almost sounds like it went into the its own test mode.
Jan 09, 2016 | LG WM2487H Front Load Washer
Laptop battery broken?
i presume that your laptop is still working on wall power socket and since the battery is broken it does not run on battery
if that is the case then your laptop lamp which indicates charging is lit red and i recall that you need to have a new battery
hope this helps
Aug 29, 2012 | Sony Computers & Internet
I had a monitor and xbox 360 power supply plugged into the inverter. It has been working for at least 2-3 months now just fine. Then all of a sudden, it turned off. I unplugged it and thought maybe it...
  • First thing I should ask is have you tried to plug something else into the inverter to see if it is the inverter or a surge messed up your monitor and X-Box?
  • When you say turned off do you get a solid red light when the inverter is on and you are trying to get your X-Box and monitor to work? A solid red light means voltage overload.
  • A blinking red light means you are having a current overload.
  • If the internal alarm on the inverter goes off and shuts down with a red light this means you are having a voltage shortage.
  • If the red light starts to blink this is a temperature overload.
  • Keep in mind that this inverter will start automatically back up as soon as what ever issue it is detecting is resolved. There is no fuse to check inside.
  • If your inverter shuts down from thermal overload then wait 15 full minutes before trying to turn it on again.
  • If you don't have any blown fuses and no burned wires make sure that if you are using over 150 watts and hour you go right to the battery rather than a cigarette light adapter as the stress can burn them wires connecting to the cigarette lighter up.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 13, 2011 | Cobra Electronics Cobra Cpi-480 400w Power...
Am using roxio creator de 10.1,recently when i want burn stuff,it says the driver is been used by another user or program.What should i do? Please help me.
1. check you start up menu and see if you have any audio programs there.
Right click on them if so and delete from the start up menu. Don't worry the program is still in the program list.
You may have a Windows Media play having priority over any other audio program there by taking over the DVD burner.
Jun 21, 2011 | Computers & Internet
What is causing short vertical line streaks of red in the monitor?
Podrías estar teniendo problemas con el flex de la pantalla. Conecta tu laptop a un monitor externo, y si la señal se muestra igual que en la pantalla de la laptop, entonces estas teniendo problemas de video que se resuelve con una resoldada del chip de video.
Nov 19, 2010 | Toshiba Satellite L455D-S5976 Notebook
Flashing red light
This is the machine's way of indicating that it is time to de-scale. It simply counts the number of times that it has been used to brew coffee, and after a set number of cycles, the light begins to blink. It does not interfere with performance, but it can be a major pain to tell when it is on/off.
To de-scale, they recommend you run a solution of citric acid through the coffee maker (diluted vinegar would probably work just as well), followed by three cycles of plain water to clear any leftover solution.
To get the red light to stop flashing, you need to press the "prog" and "drip/auto" buttons at exactly the same time. You don't need to hold them down, just need to time the press at exactly the same time. This resets the counter.
Sep 26, 2010 | DeLonghi Caffe Figaro BCO110 Espresso &...
My headlight burn , i change the burn socked and
Hi and welcome to the site,
Depending on the version, there is a hidden headlight switch inside the start button switch that switches off when starting. In some instances, the contacts may have corrosion or have burned when the headlight socket had a problem. Other than the dimmer switch this is another possibility to consider.
Good luck and thank you for asking.
Aug 03, 2010 | 2001 Suzuki GSX 750 F (Katana)
Oil level was too high/burning oil now
big job the liners need de-glazing, and probaly new piston rings
May 16, 2009 | 1986 Porsche 911
Broken coffee maker
I don´t no realy what you mean, if you have the door open so will the machine be dead, there are a switch in the machine that power off when you open the door.
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Driver download
i want to download driver of Xnote serice .model is FD-225QA2 please help me how can i dowonload
Mar 04, 2008 | LG LW20-EV Notebook
Dell Latitude D610 Intel Pentium M 1.6GHz / 512MB DDR2 / 60GB HDD / DVD Payer/ CD Burner  PC Notebook Logo
Alun Cox
