We have a potterton EP2001 that is not functioning properly after a brief power cut yesterday. My land lord has informed me to reset the timer and run at constant. Temperature control can then be achieved via the CH thermostat in the house. Using the EP2001 Customer Guide I have reset the clock to the correct time, reset the correct date and left the built in on / off times (0630 - 0930 and 1630 - 2230). I have set the select switch to constant as I wish to control the temp from the internal theromstat. I assume this will over ride the built in set timings. The boiler is working OK. I have switched it on and off several times and it seems OK. We have plenty of hot water. It is an Ideal Mexico 2 There is power into the programmer and the fuse is OK. However there is no CH although I have all correct lights and settings on the programmer. Is the problem with the programmer, boiler or internal thermostat? Thanks
  • 944 Answers
It clearly indicated the problem is the programmer.The board does not accepts the settings.In old system or short circuit system this problem occurs.Solution is to replace the control board.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Jan 05, 2011
4th lord in 12th house means will live away from home land?
4th house belong to education and 12th house is travel house which belong to foreign land so native may go for foreign for study purpose. It may also cause for foreign residence because 4th house also belong to residence. It may be known by involvement of planet and its significant and other relationships with 4th house and its Lord in 12th house.
4th house is belong to happiness and 12th house belong sleeping so 4th Lord in 12th house indicating native may enjoying happiness of sleeping.
Jan 04, 2017 | Horoscopes
Main oven not working following a power cut. Timer flashing AUTO and clock control buttons not working
The auto function will cut off the power to your oven try switching the oven to manual control to reset the control.
Apr 26, 2015 | Ovens
No display
Try reset button.
Timer is unknown without more information.
For additional help, add comment with product brand, model and type, and brief description of timer and application and voltage.
Sep 29, 2012 | Hardware & Accessories
My intermatic ej351c timer is not working properly. lights only stay on a few seconds - a few minutes before shutting off, even when button is pushed to override program. is there a battery that needs to...
Timer has non-replaceable capacitor battery for 15 minute carryover during power outage.
Timer can be affected by radio and TV receivers. Unplug those devices and check if function is restored.
Reset timer and program again.
If timer function is not restored after reset, then buy new timer.
Timer has 1-year limited warranty, and is rated for incandescent only, up to 150Watts.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Aug 12, 2011 | Intermatic Programmable 24 Wall Switch...
Brief power cut but, timer light did not come back on. Cant use main oven. Top oven fine,isthere a trip switch?
Hello everytime the power goes off & then comes back on my oven won't work until I turn the knob for the timer around as far as it will go then back again. My oven is rather an old type but maybe if you reset the timer or turn it that may help. Or check the meter box as well. dee
Dec 27, 2010 | Ovens
My timer dosn't function properly, insects might have penetrated, where can i get a replacement. transformer works ok.
You posted under Intermatic-malibu power packs.
There are no replacement clock motors.
Improvise by setting timer to override and plug power pack into cheap plug-in timer.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Apr 15, 2010 | Malibu ML200RT - Low Voltage Power Pack...
I have a Honeywell ST699. Is about a year and a half old. It now repeatedly resets itself to midnight, then goes on for about 3-4 hours, before resetting itself. What is wrong - do I need to replace it?
Check to make sure the built in battery pack is working (holds a charge). Without a functioning battery pack, some timers will not work properly and will only operate for a brief time before resetting itself when the battery pack discharges.
Usually any timer that utilizes a backup battery to retain the program settings will require replacing the batteries or battery pack annually.
You can also check the Honeywell site for more details on your specific model number.
http://europe.hbc.honeywell.com/products/pdf/en0r8439uk07r0101.pdf
Jul 28, 2009 | Honeywell Water Heaters
LG microwave no longer heats!
It sounds as though you may have run the microwave while empty, which can damage the magnetron.
Not that I'm optimistic, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise it likely needs a new magnetron.
Apr 06, 2008 | Microwave Ovens
Heating & Cooling Logo
493 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
