Question about GRY Viore RPT50V24DHD 50" HDTV DLP TV
Have purchased new 37" toshiba.
    Brigadier General:
  • 8,909 Answers
Check the lead from the lounge to the bedroom is connected correctly. The blue screen means no signal.
Posted on Jan 01, 2011
I have a sky hd+ box in my lounge and wish to make the sky work in my bedroom, I am happy to only watch what is on the lounge tv in the bedroom (not have multi room) thanks Nigel
Run a coax cable from the sky hd+ box at the rear from the RF2 coax port, and into tv in bedroom.
If you want to change channels, buy a magic eye from eBay for a couple pounds, enter sky settings, and turn power on to the RF2 output. this will supply your coax to bedroom with 9v which will power your magic rye
Oct 23, 2013 | Neet Cooler Trunk Organizer
PS3 used to work on TV in bedroom and on TV in lounge, now it won't work on TV in bedroom
I believe your Lounge TV is an HDTV and your Bedroom TV isn't, This is what you have to do:
1. Connect it to
your Lounge TV with an HDMI cable and a red/white/yellow cable.
2. Turn it on and go to the display settings and switch it to the composite cable setting.
3. Change your TV channel where you would see the red/white/yellow cable and accept it that way.
4. You should be all set. Take it to the regular TV and connect it with the red/white/yellow cable.
cheers :)
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
I have three tvs in my house all off the same ariel.The tv in lounge ok as is the one in 1st bedroom.In our bedroom keep losing signal, have had a booster fitted recently.
I expect the connections could be in need of attention. Check the point where they are connected via that booster. If you have a portable to test the bedroom and rule out the tuner in the bedroom TV?
Hope that helps.
Dec 29, 2010 | Televison & Video
Scratches on tv screen.
I have used clear plastic sheets and silicon tire dressing for smaller problems like this, but no idea how well it would work with a large screen TV. The westleys silicon tire shine smooths out the scratches, and you place the clear plastic sheet on top of that and work out any bubbles then tape the ends. It pretty much changes a standard screen into a glossy screen with the added benefit that you can always replace the sheet if it is damaged.
I usually get my clear plastic sheets packaged with the new LCD screens I purchase for repairs and I just keep them in storage.
Mar 12, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
I have 3 digital tv's one in the lounge/bedroom and kitchen for some reason last night, the tv's in the bedroom and kitchen lost all digital channels and the analogue channels were very poor to view snowy...
Loosing digital channels is equivlent to a snowy analog channel, check you cable connections, and splitters to the tv, since you have two of them out, it does not make sense that it is your tv. It is a conneciton in your cable line somewhere.
Sep 02, 2009 | Televison & Video
I share a TV antenna with my neighbour. there are three splitters in the line - one to give an output to a next door bedroom TV, a second gives a signal to their lounge TV with th other leg continuing to...
I suspect there is a Mast Head Amplifier to supply enough signal to split so many ways and the power supply is powered from the power socket supplying the neighbours TV. Switch it off and no/poor signal.
Mar 21, 2017 | Televison & Video
LOST BBC CHANNELS
You need a 45 mg booster to gain the arial signal. Regards, Dave
Jul 27, 2009 | Televison & Video
GRY Viore RPT50V24DHD 50" HDTV DLP TV Logo
83 people viewed this question
Top GRY Televison & Video Experts
Paul Bade
Ronny Bennett Sr.
Ronny Bennett Sr.
Paul
Are you a GRY Televison and Video Expert? Answer questions, earn points and help others
