Question about CTX PV 720 17" LCD Monitor
Faulty monitor ctx pv720a. The screen has the
Faulty monitor ctx pv720a. The screen has the message "no signal input" when unplugged as you would expect, but when plugged into the video cable... nothing. Checked other monitors on the PC, fine. Checked this monitor on other PCs, same problem. Checked for bad caps, couldn't find any the all looked good, and the screen works with the no signal message, so somehow the data is not getting through... Any ideas anyone?? Thanks, David
  • David Wedge Jan 09, 2011
    Thanks for that, I will look into it. Sign of the times I guess! but I just hate to throw out stuff that might just be fixable. I have fixed both my Meile washing machine and dishwasher,saved £1000 to replace both, by fitting new bits at PCB/soldering iron level. Thanks again.
    President:
  • 2,992 Answers
Try another cable, or check the plug for bent pins. If they are all good, check that the monitor is set for VGA input (if it supports VGA and DVI) as it may be looking for a different input. Then replace the monitor. It's not common, but video processing circuitry can sometimes fail, and yours may have. New 17-inch LCD monitors are quite inexpensive now, so it would probably be more economical to replace this one than to try repairing it.
Posted on Jan 01, 2011
    Thanks for you suggestions, I have already tried all those, well apart from buying a new monitor! That is hardly a solution is it?
    Thing is... it can't be set up as it was working fine for a few years, then it just stopped.
  • Jan 09, 2011
    Yeah, I agree that replacing the monitor really isn't a "solution", but sometimes it's all that can be done. Manufacturers don't often make service information available for these kinds of products, or even design serviceability into them, as they expect people to replace rather than repair them if they go bad. It's frustrating, since any problem has a real solution. But that's the attitude now: make it cheap, sell it cheap, replace it when something goes bad. I have a large collection of electronic stuff because I know it's probably fixable, and sometimes I do eventually get it going. I enjoy the exercise of tracking down the real solution, but sometimes it just never happens. Electronic technicians can be a stubborn bunch, though. I did find one page http://warrantyvoidifremoved.com/tft-rep... where several people mention your same model as being fixed by the trick the author used on another model. If you have electronic service skills or know someone who does, it might be worth looking into trying on your monitor. It may not be what's wrong, but at least it's something to try. Unless I were to have your monitor here to work on, it's the best I can offer. Good luck!
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
wow ,, why not test the monitor on any other PC or laptop.
see if its good or bad.?
this is the only way to find this, unless guessing works.
i got lost in your post.
try 2 machines
the post photos of what screen does bad, words never work for telling graphics./
Mar 08, 2017 | HP LP2065 Monitor
Screen locked
I would suggest turning the monitor off and unplugging it. Then retry the settings.
Try this manual:
http://support.octek.com.au/Downloads/Files/CTX/S762A.pdf
Jan 07, 2012 | CTX S762A 17" LCD Monitor
'No signal input and power down' message after switch on.
Remove the data cable from the back of the monitor check what message its giving ? If it shows some message like No VGA cable etc.. it means the monitor is fine.
Checked the computer in safe boot
It could be windows issue
Nov 04, 2010 | CTX P922E (Silver) 19" LCD Monitor
Ctx pv720a monitor goes blank
This is what inverter board looks like:
http://www.shopjimmy.com/catalogsearch/result/?q=CTX%20PV720
Look for bad caps also, more likely to need new inverter board, warning, you can have bad lamp assembly also.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 27, 2010 | CTX PV 720 17" LCD Monitor
Hi we have a ctx monitor PV720A that stays on for a couple of seconds then goes black
glenn659, possible cause is bad internal switch-mode-power-supply" failure or SMPS is detecting something wrong with lcd cold-cathode-fluorescent-tube backlighting circuit, (INVERTER) and it goes into SHUTDOWN mode to try and prevent a catastrophic failure from occuring. Glenn, visit youtube, search for video clips on LCD monitor disassembly and also also research BAD Capacitors or Swollen Capacitors and also the "WHY DO LCD MONITORS FAIL PREMATURELY" Certainly your's will be in the top two causes! Did you do the flashlight test with your monitor "on" and connected to a known good PC with the WIN-desktop screen showing. Even though screen is BLACK it might still show the desktop when you hold the light about 1" from screen. Some will, some won't depends on condition of the power supply. In any case get back to me with your plan of action you intend to take after viewing YOUTUBE stuff. Bye for now. I'm louie12fix on fixya or lmistyrel@aol.com
Oct 02, 2009 | CTX Computers & Internet
Screen shows message "no input signal" and monitor goes to sleep.
monitor show "no input singnal" error masage when not gating any type of video singnal ,
so if u realy check your monitor wires for correctty plugged in .
then:-
Two possibilities:
either the video/mainboard of the monitor is defective; or
the video card/ CPU is the faulty.
A way to verify is to try the PC with another monitor or to try the monitor in another PC.
thanks
Apr 30, 2009 | HP vp17 Monitor
Hello, My color isn't right on my computer. The box that pops up says "RGB no input signal". How can I fix this problem? Thanks Debbie
REMOVED THE 15 PIN PLUG - I GET A SCREEN MESSAGE - SYSTEM CABLE DISCONNECT! WHEN I PLUG IT BACK IN THE MESSAGE RGB NO INPUT SIGNAL APPEARS FOR A FEW SECONDS THEN THE MONITOR GOES INTO STANDBY AND THE SCREEN STAYS BLANK,
I ALSO PLUGGED THE MONITOR INTO MY LAPTOP AND THE SAME MESSAGE APPEARED
Nov 18, 2008 | Computers & Internet
Ctx model PV720A
Hi...there,
You can saved even more repaired yourself. The problems on the backlight inverter power supply. Open it up and check all the capacitors, it look like a tiny battery cap on the side had writing on it. (Example 1000uf 16v ) if you are lucky you can spot it right away...with a bulged on top of each caps. If not, just replaced all of the caps... Good luck!
Sep 01, 2008 | CTX PV 720 17" LCD Monitor
Re: CTX monitor getting blurry
Hi Beth,
Your focus screen network turn faulty. It can be solved by by passing the original focus screen network to a new assembled focus screen network.
Apr 08, 2008 | CTX PL 9 19" CRT Monitor
CTX PV 720 17" LCD Monitor Logo
219 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
