Question about LG Televison & Video
LG GOLDEN EYE RF-21FD50VW SMPS OF SUB WOOFER BOARD NOT WORKING
hawkwatcher
  • 67 Answers
SOURCE: sr7200 LFE (sub woofer) output stopped working
Chances are if The Receiver only has sound in Stereo Direct Mode and all surround modes and Sub out are Inop the DSP (Digital Signal Processing) Card is most likey defective. These boards are not available from marantz (D&M Holdings) and must be Component level repaired which usually is not cheap. If Only the Sub out is not working check setup to be sure sub woofer is set for on. Also If On Screen setup menu does not appear on video monitor Unit may need to be Reset manually which entails discharging a Capaitor on main P.C.B Contact kstahl65@att.net for details
Posted on Jan 10, 2008
SOURCE: sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
Posted on Nov 21, 2008
realbat2
  • 68 Answers
SOURCE: jvc th-m303 sub woofer not working all other speakers are fine
check your internal wires inside subwoofer.b4 that try to connect to other instrument to make sure it not working.
Posted on May 12, 2009
  • 3 Answers
SOURCE: childlock not opening of lg flatrontv
dear brother reples memory ic 24c16
Posted on Sep 04, 2009
  • 60 Answers
SOURCE: How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Posted on Mar 07, 2010
Lg golden eye 21inch ctv stand by led glows but switchin progress key only clicking sound found,set unable to on
Shorted component/s in the main circuit board's horizontal output section. Check and replace the damaged components there.
Jan 05, 2013 | LG Televison & Video
What is the function of golden eye?
There is an LDR [Light Dependent Resistor] fitted insie the circuit board. It will sense the light condition of the surronding, and will adjust the bright ness level automatically according to surround light condition. Taht is, if light level to surroundings is high, the brightness of the tV will also go high to compensate it and vice versa.
Actually there is no need for this,as if you switch ON the Golden eye function, you can see the quality of picture will go out. Manual settings to picure will be always best.
May 24, 2012 | LG Televison & Video
In my Lg Golden Eye 21" television remote control
Which type of remote control can I use for golden eye TV
Aug 12, 2011 | LG Televison & Video
Hi there the sub woofer for my lg lht550 home cinema system is not working. I then bought a new sub woofer from ebay, still an LG and put that into the system and thats not working either, Im now...
Check the marking of the connection of your tv if it is audio out if still not working check the setting, go to main menu of your tv then try to look for external audio input then try to configure the setting.
May 13, 2011 | Televison & Video
Dear Sir, LG Golden Eye Marquis Model No: RF-29CA40PQ., i forgot the 4 digit Tuning Lock Code. Due to this i am not able to Tune my TV. Can any one help me out, is there any master Tuning Lock 4 digit...
In my LG golden eye marquis 32 inch TV, I have switch on the childhood protection mode to prevent the TV from children's by pressing the buttons on my TV.... Now The remote gets broken which was given along with the TV.. Now I bought a remote for tat model that name is LRIPL... I can't able to access the menu button and most of the buttons cannot able to process... I need to access all the buttons... Please help me..
Feb 24, 2011 | Televison & Video
Lg 29 inch flat tv golden eye is power off he dont start
Possible failure of the SMPS power supply. Please check the fuse and switch after disconnecting and checking the circuit.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Feb 21, 2011 | Televison & Video
LG TV RT29FC85VW 29" woofer not working
Check the Woofer for continuity and also with an external amplifier.
if there is no issues then the sub-woofer power amp IC can be faulty.
Check the main voltage to the IC, if not present the power section must be traced for a line break, fusible link.
If there is power , then test for input signal to the IC. If so the IC can be the supect.
Oct 28, 2010 | LG Televison & Video
Hi i just bought a sper nes system it came with rf
If I am understanding...
If the RF switch comes with a power cord on it, it MUST be plugged in to work. Try plugging it in.
Also check your tv settings. I don't have an HDtv but I do know they have multiple options of "inputs"
If it is an RF modulator and not just a switch, check the settings on that as well. On the one I own I have to designate channel 3 or 4, that could make a difference.
Jul 09, 2009 | Nintendo Super NES Console
Televison & Video Logo
103 people viewed this question
