Question about Microwave Ovens
I never got the roller guide with my mw7300w. just got it for Christmas
    Brigadier General:
  • 8,909 Answers
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Jan 01, 2011
I have an Emerson Microwave Model #MW7300W, it appears that a small hook on the Latch is broken off of. This hook holds the spring that allows the hook to hold the door closed. I have tried looking
If this is a .5-.7 cubic foot cheapy, your only source will likely be an appliance boneyard. Otherwise, check with searspartsdirect web site using the model # for replacement parts. You can also check with Emerson web site {I beieve it is part of the Funai electrical empire}
Jul 22, 2014 | Emerson Microwave Ovens
Mw7300w light bulb keeps flickering.700 w is their a short it is only 2 years old.
see the filaments is there are touching the poles?. use the VOM, in continuity and test it. Yes the bulb can be damaged to due fluctuation On the line,by that reason can be damaged very soon.God bless youb8435993-949d-465e-b16e-2cca8b6fc2f1.gif
Apr 04, 2013 | Emerson MW8168B Microwave Oven
Find a new glass tray small size Emerson MW7300W suffix C
Try www.ebay.com Type make and model of microwave oven, and go through the list.
Jul 11, 2012 | Emerson MW8168B Microwave Oven
EMERSON MICROWAVE MW7300W INTERNAL FUSE LOCATION?
Unplug microwave, remove top, go to the right where keypad is located, follow the wire to the circuit board, look for a silver rectangular capacitor and short a screwdriver over the 2 points to remove any remainder of voltage. There should a small fuse clipped in near by, replace with same current rating, assemble before testing, carries lethal voltages when turned on.
Mar 09, 2012 | Emerson Microwave Ovens
Turntable works intermittently
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.
Nov 01, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The turn table doesnt work
Good luck.
Mar 12, 2011 | Daewoo KOC-925T Microwave Oven
Turntable does not turn
Good luck.
Jan 13, 2011 | GE JVM1350BW/WW/AW/SY Microwave Oven
Microwave quit
Well first of all you can try to clean the turntable- Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable. With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing. If further you have the same problem then this could be a failing turntable motor...... Please post comments for further help or information.......
Good Luck!!
Thanks
Jun 25, 2010 | Sharp R-1610 Microwave Oven
Plugged in my Emerson MW7300W. Light works, won't cook
there is a thermal (white ceramic) fuse located right under the cover on the top of your microwave replace it.
an electronics part store should stock it.
Feb 01, 2010 | Emerson MW8777W Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
