Question about Samsung Office Equipment & Supplies
SAMSUNG ML 191X252X SERIES PAPER JAM INSIDE MACHINE!
  • 186 Answers
SOURCE: Samsung ML 2010
First open all covers and make sure there is not another piece of paper stuck in the machine. Check under the toner cartridge. If you are sure there is no other paper stuck, try unplugging the machine wait about a minute and plug back in.
Posted on Nov 25, 2007
SOURCE: MX 310 paper jam
i have the same problem
Posted on Oct 21, 2008
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
SOURCE: Paper jam 2 on Samsug ML-3051N
There is a door around the very back of the printer, if your printer is slightly encased in as mine is you can't see it. That is where the Paper jam 2 is
Posted on Jan 05, 2010
uberpuma
  • 83 Answers
SOURCE: my samsung ml-1610 printer always
There are a series of rollers which are made of rubber in the unit. When these rollers become dry or covered with dust (usually from cheap paper) they arent able to pick up paper correctly any longer.
Think of it as though you are trying to turn a page, and you have to lick your finger to do so.
Its the same concept. When your printer grabs the paper, it cannot hold it while it is rolling it through the printer.
There are kits available through your manufacturer or a local print shop which can clean your printer and help to restore it to its working order.
Hope this helps!
Posted on Feb 23, 2011
Paper jam
You have to check very well, Open the paper tray and check, look inside, then open the toner door and take the toner with drum outside the machine and check. Put back again and try again all of this with the printer on. You should be able to find the trouble and continue printing.
Jul 25, 2014 | Samsung ML-2165 Mono Laser Printer...
There is a paper jam inside the printer and i dont know where
For some paper jam like this it will be better if you blow air inside your printer and make sure everything is clean and not even a small piece of paper is causing the problem. SO better do check again the inside of the printer and use a flashlight for you to see everything.
Feb 07, 2013 | Samsung ML-1660 Monochrome Laser Printer...
Paper jammed inside my printer near bottom
open front cover where toner cart is situated and remove cart.check and see if the jammed paper has fed into the machine and if so pull paper in the direction it is feeding into the machine.
Oct 26, 2012 | Samsung ML-3051N Laser Printer
My samsung ml-1610 printer always getting paper jam on print job. Is this problem related to fuser or something else? please help me...
Hope this helps!
Feb 23, 2011 | Samsung ML 1610 Laser Printer
ML 2010 Laser Printer: I HAVE A SAMSUNG 4200 IT IS SHOWING PAPER JAM, BUT...
you may want to check again on the printer.if it show paper jam.
open up the fron door and bnack door. remove the toner and check if there is any small pices of paper still jam in the printer.
if not try and see if the fuser flag is not sitting properly. you might need to do small adjustment.
May 18, 2010 | Samsung ML 2010 Laser Printer
After freeing a paper jam on my Samsung ML 1750 the On line/error
Frequently a very small scrap of paper is caught in the paper path. Take out all the trays and the toner cartridge. Then look very carefully with a flashlight for the smallest scrap left behind.
May 12, 2010 | Samsung ML 1750 Laser Printer
How to solve samsung ml 3051nd paper jam 2??
check paper stuck from tray to roller going out, if no visible tear paper inside, if clear check possible sensor key some on that disconnected from housing and didn't touch to sensor itself.
Mar 26, 2010 | Samsung ML-3051N Laser Printer
I have a samsung ml-2010 and the printer light is stuck on red after a paper jam. doesn't seem like there's any other paper stuck. apparently, some folks have said that it's best to take the fuse from the...
It's a very short paper path, you should see a lever near where the paper exits, sometimes that lever sticks, on this machine the red light doesn't go away until you load fresh paper in the tray as well. You can see any leftover scraps when you pull out the toner cartridge, after that any other sensors are hidden inside the fuser assembly, requiring a shop repair.
Aug 07, 2009 | Samsung ML 2010 Laser Printer
Samsung ML-2510 Series: the error red light is blinking
reset the printer by opeing the front over and closing it again.
check all area for paper jam. i.e.: paper tray, ink cartridge, out put tray.
Feb 28, 2009 | Samsung ML-2510 Laser Printer
Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Jan 30, 2009 | Samsung ML 2010 Laser Printer
498 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
