I forgot the supervisor password and I could not access my computer. I tried to enter bios set up but I could not. So how can I access my computer by removing supervisor password?
    Problem Solver:
  • 16 Answers
I guess the only way to get access would be activating Safe Mode from the Bios Mode.
I think it's holding F4, if not F7 from the start of Windows.
It shall then give you a selection of options.
Choose Safe Mode & hope for the best :)
But then once logged in I am not quite sure if you'd be able to change the supervisor password from Safe Mode.
Posted on Jan 01, 2011
Forgot My Pin Number. how do retrieve it .
Hola Sorry to say but if this is the right one i searched for the manual found
http://download.lenovo.com/UserFiles/UserGuide/en/User's%20guides%20and%20manuals/K1/Lenovo%20IdeaPad%20Tablet%20K1%20Hardware%20Maintenance%20Manual.pdf
IT said as following:
As many as two passwords may be needed for any Lenovo IdeaPad computer: the power-on password (POP) and the supervisor password (SVP). If any of these passwords has been set, a prompt for it appears on the screen whenever the computer is turned on. The computer does not start until the password is entered.
Exception: If only an SVP is installed, the password prompt does not appear when the operating system is booted.
Power-on password
A power-on password (POP) protects the system from being powered on by an unauthorized person. The password must be entered before an operating system can be booted.
Supervisor password
A supervisor password (SVP) protects the system information stored in the BIOS Setup Utility. The user must enter the SVP in order to get access to the BIOS Setup Utility and change the system configuration.
Attention: If the SVP has been forgotten and cannot be made available to the servicer, there is no service procedure to reset the password. The system board must be replaced for a scheduled fee.
Sorry hope this helps a little good luck
May 10, 2013 | Lenovo IdeaPad Tablet K1
IBM T60 Bios password has to remove
The simplest way to remove a BIOS password is to simply remove the CMOS battery
Jun 14, 2011 | Computers & Internet
How do i rmove a bio password out of my toshiba satellite m305-s 4910 laptop
B I O S P A S S W O R D
Setting the BIOS Password
There are two main varieties of BIOS used in Toshiba notebooks, each with its own unique method for setting and disabling a password. First, determine which type of BIOS is used in your notebook model, as follows:
Starting with the computer fully off, turn it on by pressing and releasing the power button.
Immediately and repeatedly tap the Esc key. If the message "Check System and press the F1 key" appears, then follow the "Esc key BIOS" procedure, below.
If the computer ignores the Esc key when it's powered-on, or if you see an invitation to press the F2 key to enter the BIOS Setup utility, follow the "F2 key BIOS" procedure, below.
Almost all Toshiba notebook computers will respond to either the Esc key or the F2 key when they're first powered-on. The Toshiba HWSetup program (found in the Windows Control Panel) may also be used for setting and disabling the BIOS password. See the HWSetup procedure, below.
To set a BIOS password, start the BIOS Setup program and enter a new password into the password field, per the detailed instructions below. Once a BIOS password is set, it will be necessary to enter it whenever the computer is started, restarted or reset. Choose a password that you can reliably recall, or make note of it in a secure location. If you forget the BIOS password, only a Toshiba Authorized Service Provider can remove it.
ESC key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system. Then press (F1) key" appears on the screen.
2. Press the F1 key. The BIOS setup program will appear.
3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
F2 key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key.
2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
3. Use the arrow keys to move to the Security tab.
4. Use the arrow keys to select "Set User Password". (This 'User Password' is equivalent to what is otherwise called, in this document, a 'BIOS Password'.)
(It may be necessary to set a supervisor password before setting a user password. A Supervisor Password may be thought of as a backup mechanism -- if a User Password is forgotten, the Supervisor Password will allow access to the computer. The next section describes how to set a Supervisor Password.)
5. Press the F5 or the F6 key to navigate to the Password section. Type in a new password at the "Password = " prompt, and then press the Enter key.
6. Enter the password again when the Setup program prompts for it, and press Enter. The password field will now change to indicate that a password has been entered.
7. Optionally, set the Password on Boot feature to 'Enable'. Otherwise the computer may not prompt for the password at startup.
8. Press the F10 key to save changes and exit the BIOS Setup program.
HWSetup BIOS Password setting procedure (This method works for most notebook models.)
1. In Windows, click Start, then Control Panel (or Start, then Settings, then Control Panel).
2. In Control Panel, click on the icon for HWSetup or Toshiba Hardware Setup.
(If neither of these icons are present, download and install the Toshiba utilities for your model from the Service and Support Website, or use the appropriate BIOS Setup procedure above.)
3. Click on the Password tab.
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other
5. Enter a new password at the "Password = " prompt, and press the Enter key.
6. Enter the password again when the HWSetup program prompts for it, and press Enter. The Password field will now say REGISTERED or SET.
8. Close the HWSetup program.
_______________________________________________________________________
Removing the BIOS Password
Follow one of the procedures below to remove a BIOS Password. See the section 'Setting the BIOS Password', above, to determine which type of BIOS your computer has. Once the password is removed, the computer will no longer prompt for a password when it's started. Removing the BIOS Password requires you to enter it first. If you cannot recall the BIOS Password, only a Toshiba Authorized Service Provider can remove it.
ESC Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.
2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"
3. Press the F1 key. The BIOS setup program will appear.
4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.
5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.
F2 Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.
2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)
3. The BIOS setup program will appear.
4. Using the arrow keys, move to the Security tab, and to Set User Password.
5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.
6. Press F10 to save and exit from the BIOS Setup program.
HWsetup BIOS Password removing procedure (This method works for most notebook models.)
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other.
5. Enter the current password at the "Password = " prompt, press the Enter key. If the HWSetup app prompts for the current password and then twice for the new password, simply press the enter key three times after entering the current password. By pressing the Enter key only, you are selecting no password.
6. HWSetup should now show that the password is Unregistered, which means there is no password set.
7. Close the HWSetup program.
Trus this is helpful. Please vote. :)
Dec 12, 2010 | YouTube Videos
I have forgot my password for my computer and cannot access as the administrator only can access my daughters account which has limited privleges
When you boot up to the log in screen type in administrator to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
or
control panel user accounts
on the users tab,click the name of the computer administrator you can change the password there
hope this helps
Dec 07, 2010 | Acer Computers & Internet
Forgot password
During the boot up process you will see on the screen press a certain key to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
hope this helps
Oct 31, 2010 | HP Compaq nx6110 PC Laptop
I forgot the password
Hard Disk Password
The hard-disk password (HDP) protects the data on your removable hard disk drive from being accessed by unauthorized persons.
Supervisor Password
The supervisor password protects the system information in Easy-Setup from being changed by unauthorized persons.
How to Reset an IBM ThinkPad Power On Password using Software
If you can boot the IBM ThinkPad, KeyMaker will recover the messagebox_info.png BIOS password.
How to Reset an IBM ThinkPad Power On Password Using Hardware
If you cannot boot the ThinkPad, you will have to reset the IBM ThinkPad password via hardware.
If only the power-on password is set, do the following to remove the power-on password.
  1. Power off the computer
  2. Remove the DIMM cover on the bottom side of the computer.
  3. Short-circuit the two password pads or put a jumper on the contacts to short the circuit.
  4. Under the short-circuit condition, power on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The power-on password is removed.
  5. Reinstall the DIMM cover.
If both the power-on password and the supervisor password are set, do the following to remove the passwords:
  1. Power on the computer by pressing and holding F1.
  2. Enter the supervisor password. The Easy-Setup menu appears.
  3. Click on the Password messagebox_info.png icon.
  4. Click on the Power on icon.
  5. Enter the supervisor password and press the Space bar.
  6. Press Enter twice.
  7. Click on Exit; then click on Restart.
Oct 26, 2010 | IBM ThinkPad X21 2662 Notebook
Locked out of bios on my Toshiba u205.
Synopsis: When a Supervisor password is set, access to the BIOS is restricted by default unless the Supervisor Password is entered at the "Password=" prompt when starting the notebook. However, should the User/Power-on Password NOT be set then no such prompt will appear, and access to the BIOS will not be possible.
Solution: To access the BIOS set-up routine in the above scenario it is necessary to start the notebook from cold (not from standby or hibernation) whilst holding down the "INS" key. This will force the "Password=" prompt to appear. After entering the Supervisor Password a small menu will be displayed, and one option on this menu is to access the BIOS set-up ro
Aug 12, 2009 | Toshiba Satellite U205 Notebook
Supervisor password
A Supervisor password protects the system information stored in the BIOS. The user must enter the Supervisor password in order to get access to the ThinkPad BIOS Setup Utility in order to change the system configuration. If the Supervisor password is forgotten there is no way to reset it to enter the BIOS configuration. Setting a Supervisor password automatically sets the master Hard drive password. The following is the icon that comes up in the upper left corner if a Supervisor password is set:
A forgotten Supervisor password will prevent access to the ThinkPad BIOS setup utility. To regain access, the system will need to be serviced to have the system board and hard drive replaced. Proof of purchase is required, and this repair is not covered under the warranty.
Document id: MIGR-59377 Last modified: 2005-06-17 Copyright © 2009 IBM Corporation Copyright © Lenovo 2009, all rights reserved
Mar 25, 2009 | Lenovo ThinkPad R51
1. My ideapad Y430 easy cam doesnot working after i reinstall windows vista ultimate. Not i cant use it for my password. 2. I also try to partition it into four but it doesnot support i can have only two...
this is all I can offer in your situation.....one option is to..use the...
Novo button
This button functions as a reset button; use with caution. Press the
1. Novo button to enter the main interface of OneKey Recovery while the
power is off. You can use OneKey Recovery to restore the primary
hard disk partition (usually drive C) back to the factory default
configuration, including the operating system and the software on it.
Attention: Once done, the system can no longer return to its previous
state. All data on the primary hard disk partition (usually
drive C) will subsequently be lost. So make sure all
important files on the primary hard disk partition have
been backed up onto another hard disk or USB hard disk
drive before this operation.
For details, see “OneKey Recovery4.65 User Guide
2. For the camera check out these key functions....
The following describes the features of each function key.
Fn + Esc: Turn on/off the integrated camera.
Fn + F1: Put your computer in sleep mode.
Fn + F2: Turn off the LCD screen (any subsequent operation will turn the LCD screen back on).
Fn + F3: Shift to other connected display devices.
Fn + F4: Switch between wide screen and normal mode.
Fn + F5: Enable/disable the built-in wireless networking feature.
Fn + F6: Enable/disable the bluetooth features.
Fn + F8: Enable/disable the touch pad.
Fn + F9: Enable/pause Media Player playback.
Fn + F10: Stop Media Player playback.
Fn + F11: Skip to the previous track.
Fn + F12: Skip to the next track.
Fn + Insert/NmLk: Enable/disable the Numeric keypad.
Fn + Delete/ScrLk: Enable/disable Scroll Lock.
Fn + Pause/Break: Pause to view the system information during start-up.
Fn + up/down arrow key: Increase/decrease display brightness.
Fn + right/left arrow key: Increase/decrease computer volume.
3. And for the password...here you go....
Using Passwords
Using passwords helps prevent your computer from being used by others.
Once you set a password and enable it, a prompt appears on the screen each time you power on the computer. Enter your password at the prompt. You cannot use the computer unless you type the correct password.
Make sure that only authorized individuals access your computer.
Establishing different kinds of passwords requires that other possible users know the proper passwords in order to access your computer or your data.
As many as three passwords might be needed for your computer: the Supervisor password, the User Password, and the hard-disk drive (HDD) password. When the Supervisor password is set, only the Supervisor password entitles you full control of the computer.
• User password
If a user password is set and Password on boot is enabled, a password prompt appears when you turn on the computer. Unauthorized users cannot get access to configuration data.
You can also use the user password to enter the BIOS Setup Utility, but once the Supervisor password is set only a part of the options can be set.
• Supervisor password
With a Supervisor password, you can get full control of the computer. It also can be used as a power-on password, the same as the User password. Also, when you enter the BIOS Setup Utility with a Supervisor password, you are entitled to set all of the options.
• Hard disk (HDD) passwords
Once an HDD password is set, you need to enter it to get access to the hard disk. You can set the HDD password through either the User Only selection or the User + Master selection in the BIOS Setup Utility.
Note: If you set passwords through the BIOS Setup Utility and you put your computer into sleep mode by pressing Fn + F1, the following describes the behavior of the computer when you bring it out of sleep mode:
• You are prompted to type the Windows log-on password rather
than the User password to resume operation.
• If an HDD password is assigned to any hard disk drive, the hard
disk drive is unlocked automatically when you resume operation.
To set a User Password:
1. Turn on your computer. Press F2, while the initial screen is displayed.
The BIOS Setup Utility screen opens.
2. Select Security, using the cursor directional keys.
3. Select Set User Password, and press the Enter key. The Set User Password window opens.
4. Choose your user password, which can be from one to eight
alphanumeric characters in any combination. Type it in the Enter New Password field.
5. Press the Enter key once to move to the Confirm New Password field. Retype the password you just entered to verify it.
6. Commit your password to memory, and press the Enter key.
7. Press F10 to exit.
8. Select Yes in the Setup Confirmation window.
Changing or Removing the User Password
To change the password, do the following:
1. In the Enter Current Password field, type your current password.
2. In the Enter New Password field, type a new password; then retype it to verify.
To remove the password, do the following:
2. Leave the Enter New Password field blank, and then press the Enter key twice.
Note: Make sure the Password on boot is set to Enabled if you need the password protection at power on.
To set a Supervisor Password:
Only a system administrator will be able to perform this procedure.
2. Select Security using the cursor directional keys.
3. Select Set Supervisor Password, and press the Enter key. The Set Supervisor Password window opens.
4. Choose your supervisor password; it can be from one to eight
5. Press the Enter key to move to the Confirm New Password field.
Attention: You might want to note your password and keep it in a
safe place. If you forget your supervisor password,
Lenovo can not reset your password. You must take your
computer to a Lenovo reseller or a Lenovo marketing
representative to solve this problem. Proof of purchase is
required, and a fee will be charged for parts and service.
The next time you open the BIOS Setup Utility program, you will be prompted to type your password to proceed.
Changing or Removing the Supervisor Password
1. In the Enter Current Password field, type the current supervisor
password.
2. In the Enter New Password field, type the new supervisor password; then retype it to verify.
password.
Hard Disk Passwords
Two types of the hard disk passwords help protect the information stored on the hard disk:
• Hard disk user password
• Hard disk master password, which requires a hard disk user password If User only is selected and a hard disk user password has been set, but no hard disk master password has been set, the user must enter the hard disk user password in order to gain access to files and applications on the hard disk.
If User + Master is selected you need to set a master password and a user password both as the Hard Disk Password. Either of the two passwords can be used to get access to the Hard disk. Any change or removal to the master password deletes the user password.
To set a hard disk password:
Print these instructions.
3. Select Built-in HDD1 Password Select, and press the Enter key. A window for selecting User Only or User + Master opens.
I will send the rest in the comment section..hope this helps in some way...the Fang.
Mar 07, 2009 | Lenovo 3000 Y410 Notebook
Ibm thinkpad r51
What is the default password for my R51 Thinkpad by IBM Model # 2888?
Feb 04, 2009 | IBM ThinkPad R51 Notebook
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
