Question about Sanyo Televison & Video
Combined Sanyo tv/dvd keeps trying to turn on dvd player while watching tv
  • Anonymous Jan 01, 2011
    As far as I am aware, there is no timer for the dvd player.
    Regards, Carol
    Genius:
  • 1,274 Answers
Hi carol,
Welcome to FixYa.
My name is John. I will be assisting you with your issue.
Try turning you timer off on the DVD player.
Let me know if that helps you.
Thanks for choosing FixYa.
Happy Holidays.......John
Posted on Jan 01, 2011
  • Anonymous Jan 02, 2011
    Hi John
    Not sure if you received my reply. There is no timer for the dvd player on the combined tv/dvd. Model is CE 22L D90DV-B
    Kind regards
    Carol
I need a manual for a sanyo DWM-3000.
What outputs does the Sanyo have?
Composite output? (Yellow, with RED/WHITE stereo audio)
Component output? (Red/Blue/Green video with Red/White audio)
HDMI output?
Coax? (Audio & video combined)
What inputs does the TV have?
Coax?
HDMI?
Component?
Composite?
Feb 14, 2014 | Sanyo Televison & Video
Can't get green standby light to stay on, so can eject DVD from combined TV and DVD player.
First try unplugging and plugging back in then remove caseing and insert paper clip under locking mechanism and hit eject...your locking mechanism signals that there's no cd in it and so to it there's no dvd or cd...hope that helps:)
Jan 04, 2012 | Televison & Video
I bought a Sanyo 26 in lcd hdtv 7 months ago. No
Try explaining the problem to the manufacturer. They will help. They may change the software if needed. After the guarantee it will become a payable service.
May 24, 2010 | Sanyo DP46849 46 in. HDTV
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
No signal on TV when we go to watch a movie on the DVD player
You may have to select a different input on the tv. iIs there an "input" put on the tv remote? If not, try channel down.
Apr 30, 2009 | Sanyo DS31520 31" TV
I was watching my tv (sanyo) with cable hooked to it. The cable all of a sudden went out. I tried hooking up the dvd player and the tv is no longer recognizing the cable box or dvd player. I don't know...
sound like a tuner problem. there is a resistor that goes to the tuner that could of went bad 39,000 ohms i think which should have a orange white orang strips around it and a gold. anyway there is a problem with tuner. Sanyo was good about haveing a problem with tuners in there smaller sets. If you do not know anything about how to repair you probly shoud take to a shop but the total cost might be high and not worth it in the long run. think before you jump still water runs deep.
Mar 06, 2009 | Sanyo AVM-2506 TV
How can i watch dvds on this old sanyo tv?
does your tv have a scart socket or is it pre scart, if it does, and you connect the dvd player via the scart then the tv should auromativally switch to av when the dvd player is switched on. failing that, if you have no scart, then the only way you can watch dvd is by connecting a flylead from dvd player to tv, (take out antenna and put it in that socket) and then start a search if you can, normally the buttons for this are behind a flap somewhere on the tv. if you have no scart or a way of tuning tv, then i dont think you can watch dvd through that tv
Sep 06, 2008 | Sanyo DS24205 24" TV
No input button
go to localtv shop try getting a used remote for your tv remote original no longer available and is what you need
Mar 15, 2008 | Sanyo DS31590 31" TV
Please help
You can find the manual here:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=b7a9e24543cb9cdef7c4e094fb734a9a&q=Sanyo+DWM-400
They will make you enter your email address if you want to download the manual.
I'm not sure you'll need the manual if you have a newer TV and want to hook this up the way most people do.
Just about all new televisons have a variety of video inputs. Typically you use one for your Cable box, one for your DVD (or VCR). When you wish to watch cable you "tell" your TV you want to view that input and when you want to watch the DVD player you tell the TV that's the input to use. Most Cable Box remotes are set up to control the TV so you can change the input without having to use the original TV remote. You can also, generally, change the TV input from the front panel of the TV set. If you give me the make/model of your TV I may be able to help you figure out how to switch inputs.
But back to the DVD. I downloaded the manual and this DVD can generate output in a few different formats. The easiest will probably be the jacks numbered 2 which is the Audio There are two them, one is RED, and one is WHITE, and jack number 4. This is the Video and will be YELLOW in color. I'll be the DVD player came with a cable set that has three connectors on each end. They will be colored YELLOW, RED, and WHITE.
You should simply need to plug one end of this cable set into the jacks mentioned above on the DVD player and then plug them into one of the inputs on your TV. Pay attention to which TV input you use because you'll need to select that input to watch the DVD.
If you have an older TV we will need to use a different method to hook up the DVD player.
Now for the editorial section. I'm not paid for this. I know it's a strange hobby, but I like helping when I can. If you have more questions please ask before you rate this solution. If anything I've offered here has been helpful I hope you'll rate this solution positively. About half of the solutions I've offered have never been rated. Thanks and good luck.
Jan 09, 2008 | Sanyo DWM400 DVD Player
Sanyo DVD Home Theater System DC-TS760
Change the TV.
I had same problem since 3 years after moving from dubai to bucharest i believed that my home theater was damaged during transportation. I tryed all repair shops in my area but no luck, so i used it as a simple mp3 player at home.
Last week, after 3 years, i changed my old CRT tv with an LG LS3000 lcd tv and SURPRISE...my dvd have colours again.
Jan 09, 2008 | Sanyo DVW-5000 DVD Player/VCR
Televison & Video Logo
106 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
