I tried to install a zune mp3 player. Now i receive a message saying boot error install system disk. i went to setup and no drives are detected?
  • 10,421 Answers
Hi, Please re install your driver and find it here :
www.brothersoft.com/downloads
Regards
Posted on Jan 01, 2011
Error code 0300 on disk drive A
0300 Flexible disk drive (A) boot error POST has detected the flexible disk drive (A) reported an error during its self-test.
To correct this:
1. Verify a diskette can be properly inserted and removed from the flexible disk drive.
2. Verify the flexible drive type configured in the Setup utility matches the flexible disk drive installed in the HP Server.
3. Verify all data cables and power cables are firmly connected.
4. If the problem persists, your flexible disk drive may need to be replaced. Contact your service representative.
Jul 12, 2012 | HP Vectra VL800 PC Desktop
Can't install xp
Are you receiving any error messages when you try to install Windows XP?
If it is not detecting your Hard Disk follow the steps below:
Go into the BIOS setup (press f10 during boot process), System configuration and disable SATA Native Support. Try installing XP again and it should see your hard drive.
May 18, 2010 | Compaq Presario 700 470024-192 Notebook
MY LAP TOP MESSAGE SAYS... 1782 DISK CONTROLLER
You are getting this mess because the system is not able to detect a boot partition on the hdd or may be it is not able to detect the HDD itself.
Try to remove the HDD(hard disk) and re-seat it, Also make sure that there is no disk in the CD drive (in case the first boot device in the BIOS is set as CD drive).
Go to BIOS by pressing F10 (system setup) and check if the HDD is detected in BIOS.
Try to run a recovery by pressing F11 on first screen after power on.
Please get back for any further assistance.
Thank you for choosing Fixya
Feb 24, 2010 | Compaq Armada E500 Notebook
The COMPAQ splash screen displays, with F1-Setup and F10 system recovery option, but then displays 'DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER'. This is my sisters computer, and she says there...
You may be able to purchase a system disk from Compaq, otherwise, try any generic XP disk. It won't have any Compaq drivers, but at least you can reformat the C: drive and get XP on it.
Nov 27, 2009 | Compaq Presario S6300NX PC Desktop
On Armada M700 when I try to install windows XP a note tell me there is a disk controll error, soon it goes away, and when I insert the system diskettes on the 4th disk it will not go dfurther it says...
This error can be caused by one or more of the below possibilities.
Floppy or CD that is not bootable is cur...
BIOS or CMOS setup is not setup properly...
Hard disk drive does not have bootable f...
The hard disk drive is bad or not connec...
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:>
Once at the A:> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Oct 16, 2009 | Compaq Armada M700 Notebook
I can't install Zune Software
Are you running Windows? It will not work on a Linux System. (Not sure if it runs on a Mac)
Jul 29, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune 30 gb isnt detected by my pc
u had better to consult customer service centre
May 05, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Booting Error Message No Operating System Found
Hi!
Make sure that hard drive is detected in BIOS. If not, there is a problem with the hard drive and any attempt to install OS will be futile since there is no hard drive detected. If this basically means you have a busted hard drive, you may need to replace it then to continue with OS installation.
Thanks.
Jan 03, 2009 | Acer Extensa 4620 Notebook
TRYING TO INSTALL MY ZUNE MP3 80GB
You need to download the software from www.zune.com before connecting your zune. Follow the setup instructions. After installation you connect your zune to the PC and the software should automatically detect it and continue the setup and update process.
Oct 03, 2008 | Microsoft Zune JS8-00001 Digital Media...
Unplugged my armada m700
 - Floppy drive
 - CD drive
 - Hard drive
At the A:\> type fdisk <press enter>
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
All users
Oct 28, 2007 | Compaq Armada M700 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
