Question about Amana AFD2535DES French Door Refrigerator
Is there ice in the maker?
Checked the maker, there is no ice inside
  • tlewis Jul 08, 2008
    Oh my -- so, I will probably need to call the service repair center, huh?
    Thank you for your encouraging words, Frank!  It's worth a shot -- and won't my husband be proud that I at least tried .... if all else fails, I can call the service repair center.
    Sergeant:
    Champion:
  • 250 Answers
You'll want to pull the icemaker. Start by disconnecting the wires and then remove the screws holding it in. Check the gears that make the ice maker ams turn. Make sure all the teeth are still on the gears and that there is nothing obstructing them from moving.
Posted on Jul 08, 2008
  • Frank Gant
    Frank Gant Jul 08, 2008
    You can do it yourself. It's pretty easy.
  • Frank Gant
    If you would, please also rate me on your original question. Thank you.
Ice maker not working. Seems stuck. Freezer is cold. Ice maker does not move not water in try either.
After you have checked to see your water is turned on...
All the schematic diagrams I have looked at show a SEPARATE FUSE for the Ice Maker...
That is the cheapest and best trouble... and NOTHING will work without that fuse.
There is a separate water solenoid for the water... next cheapest issue (but you could eliminate that as a possibility simply by filling the ice tray manually)...
After that I would be ordering the Ice-Maker and keeping the old one for parts.
All the fill valve power and ice making SMARTS are inside the ICE-MAKER.
Good luck with that!
See below Ice Maker adj.
http://www.applianceaid.com/ice-fill-adjustment.html
Dec 04, 2015 | Refrigerators
Why ice cube maker does not fill up with water?
Check your tube going into the ice maker and make sure ice is not frozen inside of it
Feb 16, 2015 | Refrigerators
Whirlpool Gold model GB9FHDXWS06 :I had the very common problem of the condensation drain being blocked; I removed the inside back panel, which necessitated removing the door, drawers and ice maker. After...
I know this is basic but did you check to make sure the ice maker didn't get switched off in the moving stuff around. Most have some manner of interconnect to shut down the ice maker if the receptacle is not in position - perhaps a wire got knocked loose?
Dec 01, 2014 | Refrigerators
My ice maker model RS2545SH does not work I could not locate the reset button How to fix please
Have you checked the temperature, inside of the freezer? It must be at least, 0 degrees, before the water will freeze into ice. Is the ice maker getting power? Why do you need to find a reset button? I don't know your ice maker. I've never heard, of a rest button on an ice maker. Your question isn't specific enough. Other than that, I can't help you. Good luck.
Sep 07, 2014 | Refrigerators
Water doesn't fill the ice maker trays
Most ice makers need to be at 8 to 13 degrees to make ice. If you had to defrost coil, then it's a defrost issue. Could be timer, bi-metal our heater.
Aug 17, 2012 | Refrigerators
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Ice maker hasn't worked in years. A couple of days ago food below the ice maker was thawed. Today I felt that the ice maker was hot to the touch. Is there anyway to disengage the power to the ice make
Yes you will need to take the screws that mount the Ice maker to the side of the freezer and unplug the cable plug that is hidden behind the back of ice maker. The only time that element is needed to become hot is the moments before the ice maker drops ice. Thanks, Sea Breeze
May 15, 2009 | Kenmore Refrigerators
Ice Maker Not Working
have you checked the inlet to the ice mAchine inside of the freexzer to see if its frozen up. use a hair dryer to thaw it out. the main cause of this is a leaking solinoid valve on the outside of the unit.
Feb 03, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ge artica side-by- side ice maker fillsup once then stops making ice? whats up?
YOU NEED TO HAVE YOUR ICE MAKER CHECKED AND SERVICED BY A TECH.THE TIMER MOTOR INSIDE THE ICE MAKER COULD BE STICKING.
GOODLUCK.
MOHAMED
Sep 19, 2008 | GE Refrigerators
Ice maker not making ice.
These Icemakers have plastic gears on the modules that are breaking, also some have thermostats that are malfunctioning. I recommend haveing an experianced tech look at the unit to see if you need the new upgraded indoor ice maker.
Jan 14, 2008 | Kenmore 21.7 cu. ft. Top Freezer...
Amana AFD2535DES French Door Refrigerator Logo
89 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
