Question about Dell Vostro 1000 Notebook
I have a laptop (Dell Vostro 1000) which is not worked now due to motherboard problem. I want to replace motherboard of laptop. How much it cost for a new motherboard & How much it costs for second hand motherboard?
    Sergeant:
    Champion:
  • 215 Answers
Hi,it depends on your location in the globe,and my recommendation is if you are still under warranty you take to Dell service Center,if you are not under any form of warranty then go to approve Dell Centre in your Country for purchase.
Posted on Jan 01, 2011
  • 6,826 Answers
I would check Ebay.com or Amazon.com for prices of used motherboards. I wouldn't use a new one unless it was cost competitive with the used.
Good luck on this repair.
I have a dell vostro 1000 they said that the graphics card was fried. is there anyway to get it working again
You would have to replace the whole motherboard because it is an integrated graphics chip. It wouldn't be worth it at all. You are running Vista with minimal ram and a slow CPU so it's just not a good laptop. Get yourself a new computer.
May 22, 2012 | Dell Vostro 1000 1310 1400 1500 1510 1710...
How can I fixed a defective motherboard of my dell vostro 1000 laptop? where can I order the exact type of my vostro 1000 motherboard laptop?
Only Dell will be able to supply a replacement Dell motherboard.
Telephone Dell, and ask for Technical Support, to find the part-number and the (HIGH!) cost.
Jul 18, 2011 | Dell Vostro 1000 Notebook
Vostro 1000 no power
check the AC adapter and power cord. if the power cables are fine. it would mean a motherboard replacement and you need to call the DELL Support team
Dec 30, 2010 | Dell Vostro 1000
My Dell Vostro 1000 could not start from battery. The seems to be OK, but once its in the pc, it wont start. But if I press the switch and hold it before putting in the battery it will start. Mikel from...
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Sep 24, 2010 | Computers & Internet
My dell vostro 1000 laptop's display ain
if i read this right, when you power up the laptop you get fan spin but no display ?, if you just get fan spin and the green power light and nothing else the you have a motherboard failure, if you get LED activity and it seems to be working but you only have no display the its more likely LCD failure, if you DO get activity try this : power off the system, press power button while holding down the D key, this will run the LCD BIST SELF TEST which will run through full colour screens if fails this test you will et a beep code, please bear in mind you will only be able to run that test if you get LED activity, if you dont have activity then the motherboard needs replacing
Oct 27, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Vostro 1000 wont charge also 2nd machine same model has a ic blown on mainboard where can i get a schematic diagram also is there a general known fault with the charging circuiton this model . Rgds
Schematics for Dells are generally unavailable.
The not charging is normally due to a failure on the charging circuit or damage to the power plug (If ac adapter will not run system or if you have to play with the power connection.)
Replacement motherboards start at about $75
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1000+motherboard&_sacat=0&_trksid=p3286.m270.l1313&_dmpt=Motherboards&_odkw=dell+1000+motherboard&_osacat=0
Oct 06, 2009 | Dell Vostro 1000 Notebook
Booting problem
Unfortunately blinking Caps Lock light on Dell laptops means faulty motherboard. If laptop still under warranty, then bring it back to Dell.
Sep 04, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Missing F11 key on Vostro 1000 laptop
ebay will be the best place to get replacement keys for the laptop without having to buy a replacement keyboard, the Dell Vostro 1000 replacement keyboard key repair kit is fairly cheap at around $7/£3, check this out >>>>>>>>>>>>>>>>>>>>>>>>
http://cgi.ebay.com/Dell-Vostro-1000-replacement-keyboard-key-repair-kit_W0QQitemZ160344889363QQcmdZViewItemQQimsxZ20090627?IMSfp=TL090627143006r26034
Good luck.
Jul 09, 2009 | Dell Computers & Internet
Heard pop and dell vostro 1000 cut off and will not come back on
Based on the symptoms (Power light on cord is on when not connected to laptop but goes out as soon as you plug it in), the motherboard has to be replaced. YOu may call dell to ask about their out-of-warranty depot or you can call their spare parts sales dept to purchase the motherboard, then find a local tech to replace it.
Jun 16, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Vostro 1000 black screen an i can hear it running, but can see..
A blank screen with evidence that the motherboard is working (the Capital "A" green light is probably the CAPS LOCK on your computer's keyboard) initially points to an output or video problem. One quick way to see if that is the case is if you connect the computer to an alternate screen. Do so with the "sick" computer powered off at first. After being sure the connections are snug, be sure that the test monitor is powered on and then turn on your "sick" Dell. If the test monitor runs as your laptop's monitor ran when it was healthy then you know there is a cabling/backlight/inverter/screen problem. Some of these can be solved very easily, some more expensively as replacement may be required.
On some laptops pressing down firmly on the keyboard may seat a screen cable to motherboard connection. That often works on IBM Thinkpads with screens that fade in and out due to a poorly seated screen cable connection to the motherboard.
So let's see how the test to a known working screen goes.
Apr 18, 2009 | Dell Vostro 1000 Notebook
Dell Vostro 1000 Notebook Logo
144 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
