Question about Hoover Washing Machines
Hoover vision hd 1600 aaa washer display shows - - - in red no digital numerics or anything else
4 Suggested Answers
SOURCE: Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Posted on May 07, 2008
kapishtech
  • 2272 Answers
SOURCE: hoover vision HD 1400 AAA,
Check if the inner drum is spinning without noise when you turn it on manually.If the same noise is heard then it can be drum center bearing,that is out of alignment/.The other possibility can be the timer ,it must be getting short causing the noise. Check out.keep updated. Thanks.
Posted on Sep 18, 2010
  • 24 Answers
SOURCE: My Hoover 1600 AAA Vision
try pushing the door really hard if it opens check the door seal is on properly sometimes they pull off when removing clothes they can get trapped in hinges
Posted on Jan 17, 2011
How to reset the delay start on a hoover 1400 AAA vision hd
consult the manufactures website for a manual free download eric
Dec 25, 2017 | Hoover Washing Machines
Hi. I just bought a Hoover vision HD 1400 aaa. But i didn't get the user manual, and i am totally green when it comes to washing clothes. i've been around checking out local stores, but nobody seem...
Being from the UK I am amazed that vendors elsewhere seem not to supply manuals automatically with each machine!
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 04, 2011 | Hoover AAA140 Front Load Washer
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
My Hoover 1600 AAA Vision HD 8 kg. Washing machine will not open the door after programs are ended. I can run all programs, but when finished the door will not unlock! What is wrong? I dont have the...
Jan 17, 2011 | Hoover AAA160 Front Load Washer
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
May 12, 2010 | Hoover H160E Front Load Washer
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
Instructions for Hoover Washer Time 160E
i have a hoover soft wave maxi 1600 7.5kg AAA it spins and empty's and sometimes it don't what could be the fault
Nov 23, 2008 | Hoover AAA160 Front Load Washer
Error code 8 on Hoover vision hd 9 kg frontloader. No Manual.
Had same problem wouldnt spin found clip on motor had come loose pushed it back on problem solved!
Nov 18, 2008 | Hoover AAA160 Front Load Washer
High summerzaman,
with regard Andreas
Apr 11, 2008 | Washing Machines
Washing Machines Logo
127 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
