Question about Kenwood VR-414 5.1 Channels Receiver
I can't get dolby digital to activate on my VR-414. I have it turned on on my ps3, I have an optical cable between the systems but I can only select pro logic, 3 stereo or stereo for listen options. Dolby doesn't activate. I don't have a powered sub but i'm not sure that matters. Help please
4 Suggested Answers
  • 21 Answers
SOURCE: Does not decode Dolby Digital 5.1 from my cable box
If you have an HDMI cable plugged into the cable box it may only output 2.0 on the digital audio output. Set the HDMI audio to off or 2.0 and then set the cable digital out to Dolby.
Posted on Sep 03, 2007
  • 4102 Answers
SOURCE: LEFT SPEAKER HAVE STATIC SOUND AND NOT CLEAR
Hi what are you listening to like cds or tape or radio also are you using copy cds
Posted on Apr 02, 2008
jomabug76
  • 1148 Answers
SOURCE: Music, sound effects no dialogue
MAKE SURE YOU HAVE ALL THE AUDIO SELECTIONS ON UR PS3 CHECK THE BOXES ,,IN THE AUDIO SETUP
Posted on May 15, 2009
NO OPTICAL SOUND I connected HDMI from reciever to TV, HDMI from PS3 to TV, Optical from PS3 to Receiver (PS3 Sound settings switched to Optical, with Dolby Digital 5.1CH, and Dolby DTS 5.1 selected) ...
I think your problem might be at the digital audio setup at the receiver. To fix this, go into the setup under digital audio and make sure that the input that your connected to is set to optical, not analog or coaxial. Example if your plugged into video 1, make sure that the audio setting corresponds to the optical input where your connected. Video 1-optical-1.
Good Luck
Jan 07, 2011 | Samsung HTC5500 Theater System
Problem with RCA RT2870, when connected to ps3 with optical cable (ps3 optical brand new) I would turn on the ps3 and when a game loads, and the audio on the receiver shows that it changes from Dolby Pro...
It sounds like you probably have a broken optical cable. Optical cables are made of glass and are quite fragile. You have to be very carefull to not bend it or smash it. Try connecting another optical cable, or you can also revert back to the stereo analog plugs to eleminate the possibilty of having a bad receiver.
Good Luck
Jan 07, 2011 | RCA RT2870 Theater System
My receiver no longer gets a Dolby Digital signal from the PS#. it only shows an analog signal being available. I have switched the HDMI from Directv to the PS3 input in my reciever and it recognizes the...
To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
Good Luck.
Mar 07, 2010 | Sony Playstation 3 (PS3) Console
How do i get dolby digital to work on my kenwood vr0405 reciever?
Make sure your source is playing something that has been recorded in dolby digital, not all dvd's and tv boxes transmit dolby digital. what is your source?
Dan
Dec 27, 2009 | Kenwood VR-405 Receiver
Kenwood vr-7080
Is your tv wired to a cable box or an HD antenna?
Case 1: If your signal is weak, then the chances are that the feedback from your tv to the receiver's processor cannot interpret a Dolby Digital signal.
Case 2: Check the TV MENU AUDIO setting. Does your TV have a ON/OFF feature for the optical output, or any aux. speaker outputs?
Aug 04, 2008 | Kenwood VR-7080 Receiver
No dolby digital signal
Put your optical cables into the amp and not the tv,also make sure the ps3 audio is set to bitstream.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Audio Players & Recorders
How do i use the dolby digital
You have to connect your dvd player to your kenwood receiver by using the digital port.
DVD ------------ Digital out
Receiver ------------- Digital input
Apr 09, 2008 | Kenwood VR-405 Receiver
Hook up your Xbox to a Dolby Digital Decoder
Xbox® is the first and only game console to support in-game Dolby® Digital 5.1 surround sound. This lets you experience all the game sounds from your home theater system in full 5.1 surround. Before you get started, make sure you've got the following: A digital audio output. A free optical digital input on your receiver. An optical digital audio cable. Digital Audio Output Your Xbox didn't come standard with a digital audio output, but you're gonna need one for this to work, so hightail it to the store for the Advanced AV Pack or High Definition AV Pack, both of which have digital audio outputs. Microsoft makes both of them. You can also buy third-party AV cables for Xbox?but make sure they have a digital audio output. Free Optical Digital Input For this slammin' sound system to work properly, you need at least one free optical digital input on your receiver. Ready to Hook It Up? Let's Go! Connect the digital audio output to your Xbox. Connect one end of the optical digital audio cable to the digital audio output on your Xbox and the other end to the optical digital input on your receiver. Turn on your Xbox with no disc in the disc drive. In the Xbox Dashboard, select Settings. Select Audio. You will see an Audio Mode screen that shows Dolby Digital and DTS status. Select Dolby Digital. You will see the question "Does your stereo system support Dolby Digital Audio?" Select Yes. You will see Dolby Digital Enabled in the audio screen. Your Xbox is now ready for Dolby Digital gameplay. Insert a game disc and play!
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
Kenwood VR-414 5.1 Channels Receiver Logo
53 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
