Question about Miele W 4800 Front Load Washer
I would like to get some information on how to replace the door seal of a Miele Metor 4000?
    Genius:
  • Miele Master
  • 1,461 Answers
Depends if washer drier or just washer...The Door boot seal is secured with two rings one on the outside of machine case the other on the inside...The tricky part is fitting the inner ring in some cases the front of the machine can be removed,greatly simplifing the job if you look on utube you will see step to step how to fit a door boot seal this may help you decide if you need an engineer to do job..Happy New year from Scotland...
Posted on Jan 01, 2011
How to replace door seal miele novotonic 502
Hi Adrian,
Open machine door then turn power off. Remove 3 bolts on front of machine. Remove the soap draw and remove the 2 (or 3) screws.Separate the front of the door seal from the metal front of the machine and fold the door seal in towards the drum. Front of whole machine will now hinge open (there is a spring catch at the bottom where the pump filter is - so dont be scared to use a little force). Use a screwdriver to loosen and remove the metal wire clamp that sits around the door seal. Once off, door seal can be removed from the outer drum. Replace with new door in reverse order. Note that putting on the new door seal to the outer drum is a bit of an art and may take you a few attempts (so be patient but persistant), as you must make sure it is seated in position correctly. Good luck.
Aug 19, 2015 | Miele Washing Machines
I am looking for a new door seal for my Miele washing machine. its a brilliant machine but is leaking badly now. model W1712. your assistance in finding one for me would be very much appreciated.
Hi.
Miele make an excellent machine and I would advise you to have the door seal replaced by an experienced technician. The job is not as straightforward as it might appear.
I suggest you contact 2 or 3 repair people and check prices. Try to get some idea of the final price because the labour cost can be open ended and a big surprise...
I generally allow around an hour for a door seal replacement. It can take longer.
Good luck,
Nomess
Mar 03, 2015 | Miele Washing Machines
I had a machine exclusively for my dirty rags and dogs beddings, how can I clean inside with the round rubber around the drum close to the door. I tried vim and vinegar as what miele technician suggested...
Vinegar is what is suggested to clean the mold build up and if it hasnt come clean the only other option is to replace the door seal and defiently leave the door open once seal has been replaced to prevent build up in the future
Jul 26, 2011 | Miele Washing Machines
Miele front loader rubber door sela has small tear
No.
At the beginning of every cycle water enters appliance via top of door seal this is connected to the inlet water supply
Jul 05, 2010 | Miele Novotronic Premier 500 Front Load...
I need to replace the door seal on my Miele refrigerator
You can open the door, pry off old seal with screw driver,
Then line up new seal. After it is lined up, then you can use sealent inside the seal, and place on the door. You should need to take door apart, though you may need to remove it from the hinges. There are many youtube videos and howstuffworks.com videos you can view that will show you how this is done.
Sep 04, 2009 | Miele K8952SDED Refrigerator
Can you replace the door seal on the miele w404 washer as it is mouldy and we have been unable to clean it?
YES IT IS EASY TO REPLACE:
YOU HAVE 2 RING OF TIGHT:
1-BETWEEN THE OUTER CASE AND the door seal
2- BETWEEN THE SUD CONTAINER
AND the door seal
USING SMALL PLAYER AND SUITABLE WRENSH ,SCREWDRIVER
THANKS
Jul 28, 2009 | Miele W404 Washer
Miele G858 Icognito replace bottom door seal...how to remove door
Kelly --
Since you wrote your question 13 months ago, I'm guessing the problem is solved. Still, for others experiencing the same issue, here's my answer.
We also experienced leaking on our Miele 858 Incognito dishwasher and were able to replace the bottom door seal (today) without removing the door.
First, call the Miele Parts Dept @ 800-999-1360 to place an order for the door seal, which is part #3920725.
Remove the defective seal by loosening the four screws at the bottom of the door. Pull the black rubber seal out and discard. Install the new part in the same spot (underneath the green flange). Tighten the screws and you'll be in business.
Apr 03, 2009 | Miele Incognito G858SCVi Built-in...
Miele W 1918 washing machine front door seal replacement
the seal on the front door runs around 60 bucks and its quiet easy replaced takes 1/2 hour
May 27, 2008 | Miele Novotronic W1918A Front Load Washer
Miele Touchtronic G892 SC Water leak at base of door
check the rubber seal around the door to see if its torn or smashed. if it is replace it, could someone have set somthing heavy on the door while it was open that would have stressed the hinges. it is most likely one of these problems take a nail file and slid it gently between the door and the body of the dishwasher if it slides in easy where it leaks you know the seal is bad and replace it.
Dec 09, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele W 4800 Front Load Washer Logo
206 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
