Question about Apple iPhone Smartphone
Always pop up NO SIM INSTALLED or NO SIM , how can i fix it? my phone is iphone4, thz
    Novelist:
  • 141 Answers
Check sim in another iphone first see if it works, if so have you activated your phone and sim correctly? If so then try restoring you iphone as NEW iphone (following instructions below to do) ..... if that doesnt work then you may need to try getting a new sim from your network or maybe popping into an apple store to see if its the phone
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone, iPad, or iPod touch when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to sealways pop up NO SIM - ht1414_08--set_up-003-en.pngr /> ht1414_08--set_up-003-en.png
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new..." If you want to preserve previous backups that iTunes has made, be sure to back up the appropriate directory before choosing to set up as new. To learn more about setting up your device as new, see How to set up your iPhone, iPad, or iPod touch as a new device.
Posted on Jan 01, 2011
How to remove sim card from a iphone 4
look on top of your phone
Right next to your earphone jack [right side of jack] you'll see a small hole
Insert a small paper clip into the hole and push firmly
The SIM card will pop out
Sep 02, 2014 | Apple iPhone4 4G iPhone 4
I cant locate my imei number
Settings\general\About, scroll down to the IMEI number or on many iphone models, pop out the SIM and it is printed on the SIM tray.
Mar 30, 2014 | Apple iPhone4 4G iPhone 4
Invalid sim
Did you just recently update to iOS 7? Best bet is to do a full back up and then take it to an Apple store near you. If you don't have that option, sometimes just pulling the SIM and replacing it can fix the error. do this with it on first. If that doesn't work turn the phone off, remove the SIM, turn the phone on, insert the SIM. If that doesn't work you can try going into the settings and "Reset Network Settings" (not likely at this point)
Feb 26, 2014 | Apple iPhone 4 Black Smartphone
I cant set up my iphone4 because it need the original carrier
you will need it to be unlocked at a shop. then do this make sure you have update itunes installed on pc laptop. ( dont take to apple store for unlocking) Press home volume down and power when phone comes on take finger off power then volume then home. plug into itunes and restore software after it has installed click on new this will wipe phone to new after you can put your stuff back on with itunes all apps and contacts that have been saved to itunes. do this when you get the phon back and its un locked with your new sim istalled
Jan 02, 2014 | Apple iPhone4 4G iPhone 4
I CANT USE ANY SIM IN MY IPHONE 4
sim is locked to the sim you first had in when it was set up. if you want to use another sim you need to do this. Press home volume down and power when phone comes on take finger off power then volume then home. plug into itunes and restore software after it has installed click on new this will wipe phone to new after you can put your stuff back on with itunes all apps and contacts that have been saved to itune with your new sim installed click on one of you saved file to load in this setting and return the phone to how you had it.
Jan 26, 2013 | Apple iPhone4 4G iPhone 4
Iphone 4 network not available
Press home volume down and power when phone comes on take finger off power then volume then home. plug into itunes and restore software after it has installed click on new this will wipe phone to new after you can put your stuff back on with itunes all apps and contacts that have been saved to itunes. the phone lock the sim card that is installed first any other sim card will not work. do this and put you sim card in when it has updated the phone then it will add server settings. then you phone sim will add the messaging services after it has been on a while. if not go to the web page and request setting to be sent to phone you will need the phone number to do this.
Jan 23, 2013 | Apple iPhone4 4G iPhone 4
Apple 4 i am installed ultrasnow but no service fix this problem help me
if you have this Baseband 01.59.00 (iPhone 4)
you can use ultrasnow to unlock
else you can't use ultrasnow to unlock your iPhone4. some use Gevey, or X-sim
Jan 15, 2013 | Apple iPhone 4 Black Smartphone
How to open the sim slot of iphone4?
there is a small hole on the right side of screen ,you have to insert the pin provided with the mobile into the hole,press pin a little and the sim slot pops out ,insert sim in you can see the see the hole in picture provided.do not forget to tell that was it helpful11_29_2012_2_06_32_pm.jpg
Nov 29, 2012 | Apple iPhone 4 Black Smartphone
Dont know how to install the sim card in iphone4?
Bend the paperclip so one side is pointed out.
Press the small indent on the SIM cover at the bottom of the phone.
This causes the SIM tray to pop out.
Place the SIM card in the tray with the writing facing up.
Insert the tray back into the phone and wait for the phone to reboot.
http://www.bing.com/videos/search?q=how+to+install+the+sim+card+in+iphone4&view=detail&mid=D3522C6B74A84AD67E23D3522C6B74A84AD67E23&first=0&qpvt=how+to+install+the+sim+card+in+iphone4
watch video
hope this helps
Sep 16, 2012 | Apple iPhone4 4G iPhone 4
I can't receive text messages on iphone4 how can I fix it
i phones have a minimal selected Sim card that is compatible. check out if your sim card is compatible or not
Jul 13, 2012 | Cell Phones
Apple iPhone Smartphone Logo
128 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
