Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
No real problem
I need a copy of the Manual. I just can't seam to find mine and I do not use the Bissell often and I for got if I put water in the tank, etc. Just how I do it.
  • Anonymous Aug 05, 2008
    I have forgot ,which compartment to put the water in ,my shampooer
    I need an instruction manuel for my shampooer,as I can't remember
    which compartment the water goes in.
Www.bissel.com
has instruction manual
Posted on Jul 09, 2008
Instruction to put it together
Bissell has the assembly instructions in the manual for the unit. Most Bissell manuals are available here: http://www.bissell.com/user-guides/ . The direct link to the manual for 1950 series Quick Steamer is http://www.bissell.com/user-guides/DownloadAsset.aspx?id=567 .
I hope this helps. Out of the box, the assembly is very simple. Put the handle on the lower body and secure with a Philips screw. The water tanks lift off and then get placed back on the body of the unit. (Use care when the tanks are filled with water.) See the manual for adding the bare floor tool.
Oct 15, 2015 | Bissell 1950-3 Quicksteamer Plus Vacuum
I need instructions on how to use my machine. Can you please help!
if its a bissell,go to bissel .com and request a manual sent to you.there should b a cartridge that you push a button to unlock so u can fill it with water or carpet shampoo.I fill mine half water half carpet shampoo. then u put it back on ,make sure it either clicks or snaps on.plug in and turn on,they usually have a button that turns that say wash or rinse.it depends on your machine.
Jan 19, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I lost the owner's manual. I don't know how much
Located on the back side of the plastic container in which the formula and water is mixed into has an indicator for the formula and a separate indicator for the water. You should be able to obtain a copy of the manual from the Bissell website.
Jun 30, 2009 | Bissell 1425 Little Green ProHeat Handheld...
Manual for Bissell Powerwash Deluxe cleaner
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Mar 17, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Want to Buy a Repair Manual for Bissell Proheat 9500 Clean Shot
I have the manual and would be more than willing to share...contact me at brewcrew2u@aol.com
Aug 19, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Not putting out water
I had the same problem with mine and it was an easy fix. If you remove the soap holder without putting the selector dial to "water only" you will lose the prime in the hose that goes to the water chamber. It takes a few minutes of pulling the water trigger to regain that prime, but it will come back eventually. Easiest fix, of course, is to always remember to dial to water only when you need to add cleaning solution..
beth
Jun 02, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Loss of Operators manual
You're in luck! Bissell has pdf files of all of its user guides online. http://www.bissell.com/Products/UserGuides.asp Be prepared for a common problem once you get started. The water may stop spraying on the floor even though the accessory tool does spray water. This happened to me and I searched for a solution. It turns out that this is a very frequent problem. People describe their attempts all over the place. One easy place to look is on amazon.com. Search for "bissell 1699 proheat" and look at the reviews. There is also a copy of the User Guide on the amazon page.
Apr 26, 2007 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
181 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
