I have a problem, with the agitator, one of the small one's has become dislodged, and is causing the hole unit to gring as it is in use. I request information on how i may disassemble it and fix the problem. "thankyou". Bill
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
If you could post the make and model of your machine, we will be able to help you with this problem.
The FixYa Team
Posted on Jan 01, 2011
Where the charger plugs into the tablet has become dislodged.
Need to open the casing and re-solder the power plug. Hopefully, no pcb traces are broken but it can be repaired with a little patience. If unit is out of warranty, go to the local cell phone repair shop, they can easily do this for you.
Sep 22, 2014 | Ematic 4.3" FunTab Mini Android 4.0...
Leaking gas out of gas tank looks like it is missing a plug on the side of tank
I don't know your particular saw, but all fuel tanks are vented. Possibly the vent line or vent fitting has become dislodged and lost.
Sep 13, 2014 | McCulloch Garden
I cannot eject cd from my all in one Dell studio one 1919 desk top
Most CD drives have a small pinhole in the front face to manually release the drawer. Use a paperclip or similar item to insert in the hole, and push. This will manually release the drawer and cause it to try to open. Be careful as the CD may have become dislodged from the spindle mechanism and askew in the tray.
Hope that's helpful.
Dec 31, 2010 | Dell XPS One All-in-One TV Desktop with...
Insinkerator hums but does not gring. What to do? Tim
Hey Tim. I can help you look into the obvious and perhaps most inexpensive problems to fix.
At the bottom of the ISE there is a hex type hole in the center of the bottom plate. This is for an allen wrench of the appropriate size, a wrench usually comes with the units when they are new. UNPLUG the unit under the sink and insert the allen wrench into the hole. You can now use the allen wrench to manually turn the cutting blades inside the ISE. You may find something wedged in the blades that needs to be removed, family silverware, dog collars, etc. As long as the unit is unplugged you can reach inside and clear any debris. You will also find a small button on the bottom of the ISE. This is a circuit breaker and does trip from time to time. You just need to push it in to reset it. But since your unit is humming, I doubt the breaker is tripped. Feel free to contact me if you have questions.
Sep 15, 2010 | Emerson Vacuums
How big should gap under agitator be? kennmmo sr 70
USUALLY THE AGITATOR HAS A VERY SMALL GAP AROUND 1/4 INCH AT MOST, IF THERE WAS A LARGER GAP YOU WOULD HAVE SMALL ITEMS SUCH AS SOCKS AND UNDERWEAR CONSTANTLY BEING WRAPPED AROUND THE TRANSMISSION SHAFT AND CAUSING A MORE SERIOUS PROBLEM. IF YOU AGITATOR HAS BECOME LIFTED MORE THAN THIS IT COULD BE THAT YOU AGITATOR MAY NEED TO BE REPLACED OR TIGHTENED.HOPE THIS HELPS
THANKS
Oct 12, 2009 | Washing Machines
Kenmore elite sm 9710803-a motor
Belt is loose or pulley needs to be tightened.
Servicing the Tub and Agitator
©2006 Publications International, Ltd.
Replace a damaged agitator
with a new one of the same type.
Unscrew the cap on top of the
agitator and pull straight up;
the agitator should lift off.
The washing machine tub, or basket, generally doesn't cause problems. However, at times it may cause damage to the laundry, make a lot of noise, vibrate, or stop completely.
If laundry is torn during the wash cycle, feel around the tub. If you find a rough spot, you may be able to smooth it with an emery board. Sand the spot lightly. If this doesn't work -- or if you have to cut to bare metal to remove the roughness -- the tub should be replaced. In this case, it's probably much wiser to replace the entire washer.
The agitator -- the finned part that fits on the tub shaft -- can also tear laundry if the fins are cracked or broken. You may be able to solve the problem temporarily by pinching off the splinters with pliers and lightly filing the plastic smooth, but this is just a stopgap measure; the agitator should be replaced. Replace a damaged agitator with a new one of the same type. To do this, unscrew the cap on top of the agitator. With the cap off, pull straight up on the agitator; it should lift off. If it doesn't move, rap its side with a hammer. If it still won't lift off, drive wedges under the bottom rim of the agitator to dislodge it. Then set the new agitator into place and replace the agitator cap.
Damage to the snubber, a padlike device sometimes located under the agitator cap, can cause the machine to vibrate excessively. The snubber may have a suspension spring in it. Lift off the agitator cap and examine the snubber. If the spring is broken, or if the pad is visibly worn, replace the entire snubber. Snubbers might also be found at the splash guard at the top of the tub, under the transmission, or as part of the water pump housing. Look around until you see it.
If the machine doesn't have a snubber, listen for noise at the suspension unit between the tub and the machine cabinet. The suspension unit has fins or pads that may need replacement. In some cases, the entire unit may have to be replaced. Another noise point is the basket support nut. Tighten the nut or, if you can't tighten it, replace it.
Sudden tub stops can be caused by a broken motor belt, but they are usually due to poor tub loading. Check to see if wet laundry is wadded around the bottom of the tub shaft, or under the basket or agitator assembly. Remove the basket or agitator in order to remove the laundry easily.
Replacing Drive Belts and Tightening Pulleys
The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
Sep 04, 2009 | Washing Machines
Will not agitate
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Jul 14, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine
Sounds like the agitator securing bolt is missing and what you see is the remaining washer (" a plate with a hole in"), if the bolt is missing the agitator should simply lift up to remove, the securing bolt is a 10mm x 40mm should do the job, you will need a 17mm socket and long extension to refit the securing bolt.
Mar 17, 2008 | Admiral AW22 Top Load Washer
Noise
The Hunter 33202 uses a recirculating pump to keep the aluminum mesh wicks (filters) wet. There is a vinyl hose which runs from the pump outlet to the top of the main unit (you will need to lift the main unit off the base to see any of this, much less do anything to fix the noise). The top of the hose meets the diffuser, which has several small holes to drain into that V-shaped double trough (located directly above the two wicks) which has larger drain holes on either side. If any of the holes in the diffuser or the trough become clogged, the other holes will tend to release a higher volume of water, which could lead to that running faucet sound. The clogs are easy to dislodge-- they're usually mineral deposits from the water. Another likely cause is the filters becoming clogged from dust that's being sucked in from the fan. Easy fix, also-- remove the wicks every week or so and thoroughly rinse them under running water.
Feb 13, 2008 | Hunter 33202 Humidifier
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
