Washing Machines Logo
Posted on Jan 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to buy parts for a Sears Carpet Cleaner. or "Home Cleaning System" 1) 644037-003 Ferrule Nut 2) upholstery nozzle
Anonymous
Level 3:
President:
  • Master 1,937 Answers
  • Posted on Jan 01, 2011
Anonymous
Master
Level 3:
President:
Answers
1937
Questions
0
Helped
430157
Points
5400
See the following Sears parts site:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your complete model number and you should be able to see diagrams with parts and a parts list with prices from Sears.
How to clean suction area
If you are referring to the front nozzle area, Hoover has made a tool called a nozzle cleanout tool # 39514003
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
How to use the upholstery attachment for hoover max extra 60 carpet cleaner?
Hey there! The nozzle/valve that releases the solution from the hose may be clogged and not closing off to stop the solution flow. You can try soaking the trigger end in warm water for a few hours to unclog it. Also make sure you are inserting the hose back into the hose slot in the back of the cleaner. If the cleaner is still dispensing from both the hose and the cleaner, your nozzle/valve assembly may need to be replaced. To order a replacement nozzle/valve assembly follow the link below.
Search Results
Hope this helps!
1helpful
4answers
How do I clean the hoover steam vac floor cleaner machine
Nozzle Clean Out tool is NO LONGER AVAILABLE from Hoover. Hoover stopped making this part over 1 year ago, and it's not sold any more. What you'll need to do is remove the dirty solution thank, unscrew the one silver screw on the suction port of the clear window, then turn the machine upside down and remove the two silver screws on the bottom corners of the see thru window. This will then allow you to completely remove the see thru part to clean inside of it. Unfortunately with this model that's really the easiest way to do it now that the tool is no longer available.
My bissell carpet cleaner won't dispense the
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fdghd
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Steam vac
Either the nozzles are clogged, or the brush block is not turning.
Top Washing Machines Experts
john h
