Question about Dell Inspiron 530 Desktop Computer
Very often when I turn my computer on the key board is not working properly, when I dial one key many letters arc written. after turning it on and off several times the probleum is solved by it self but it may take several days. see the same text below without editorial changes. rvecrvy o.ftecn whecn I< tumrvn umy eco.ump]umtecvr o.n thec kecy bo.arvd i,s no.t wo.rvki,ng p]rvo.p]cevrlyi, whecn I< di,al o.nec kecy umany lecttecvr arvce wrvi,ttecno. aftecrv tumrvni,ng i,t o.n and o.ff servecvral ti,muecs thec p]rv.oblecum i,s so.lrvecd by i,t seclf bumt i,t umay takec secrvecvral dayso. secec thec saumec tecxt beclo.w wi,tho.mut ecdi,to.rv,ial echangecso.
    Genius:
  • 1,288 Answers
Keyboard controller problem, possible liquid damage to the circuit inside the keyboard
TBH, the price that keyboards are, i would try another one to see if it work and if it does, junk the old one
Posted on Jan 01, 2011
CONTINOUS BEEP WHEN COMPUTER IS TURNED ON
To do this properly I need to know which model your computer is - is it an eMachines MB.NBK09.003 Motherboard El1850 Desktop S775 G41T-Ad ? I need this to try to establish the BIOS seller and version. You might try finding the BIOS version by (continuously) tapping the F1, F2 or esc key (or possibly another)immediately after you turn on. The "splash screen" that appears aftrer you turn on may have some lettering which tells what key to enter the BIOS.
In the absence of this information here are two suggestions
EMachines that beeps constantly and won boot up
if it is the above it is serious and the computer will need serious (difficult) repair, or main board replacement or whole unit replacement (by which I mean new computer)
The other suggestion was about the RAM not being properly in place, but I doubt this as this usually gives a different beep code
19.January.2016
Jan 19, 2016 | eMachines MB.NBK09.003 Motherboard El1850...
How to turn the beep for Spell Check on.
Hold the code key down while pressing the Spell key spell written in small letters above one of the letter keys
Aug 24, 2015 | Nakajima AE-740 Typewriter
Keyboard typing wrong letters
Your keyboard is not "typing wrong letters", you have a stuck key. The key is shorting out and is stuck on the letter W. Usually caused by dirt/dust/spills on the keyboard jamming the key so it can't release. Things to try in order of difficulty:
>Vacuum cleaner with brush attachment, vac the keys.
>Paper towel moistened lightly rubbed on the 4 sides of the W key; use a knife blade to gently work down into the edges.
>Soft toothbrush, lightly dampened with water, work the bristles all
all around the edges of the W key. After that do step 2 with a dry
dry paper towel.
>Take the keyboard apart; usually several tiny screws on the rear/sides. CAREFULLY remove the top. You may have to turn the board over, lie on its face to do this. Do not knock the letters out of order or you will have a headache placing them back in proper order! Clear whatever it blocking the W and replace the cover.
If none of the above works the keyboard has failed, needs to be replaced.
Jun 08, 2013 | Samsung Computers & Internet
My computer is dell inspiron,the letter 'd' in my keyboard is not working,and when i'm turning on my computer for the first time,always letter 'd' is being typed by itself
If this is a wired keyboard (USB or PS2) then turn off the computer. Unplug the keyboard, and bang it against your palm to work some of the debris out of the keyboard. Now check the d key and make sure it bounces back when pressed.
You might also take a small screw driver and pry the d key off the key board and see if there is anything sticky on it. If so try cleaning with alcohol.
Last ditch effort before replacing the keyboard completely: Run the key board under running water to rinse it. MAKE SURE YOU LET IT DRY FOR A COUPLE OF DAYS (KEYS DOWN) BEFORE PLUGGING BACK IN. I have had this method work more than once. If it works its great if not, then non of the key board will work.
Jul 20, 2011 | Dell 0Y3740 Keyboard
Lincoln AC/DC 225 control dials inoperative
the only way you can get a repair manual is to be a service shop,but what your saying is the dial turns with no resistance.did anyone turn the dial while someone was welding?if so the dial has to be replace,what happens is the contacts inside the unit weld together becuase once the dial is turning it breaks contact then makes contact welding the dial in place.You would not be able to turn the dial.so if the dial turns very easy I would check to see if the dial handle is loose on its shaft.the unit can be taken apart but it just takes a little time.it is a very basic unit with not to many internal parts.good luck,you can fix the problem.
Jun 05, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Satellite pro m300 keyboard
Look for a NumLock key which may be written in colour, then press Fn key and the key with NumLock written on it.
LED light for NumLock should go out
Aug 17, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Blackberry 7100g
About fixed dialing
If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
so if you have this enabled chances are you have to turn it off.
this is how you turn it on so you should be able to use it as a guide to turn it off.
Turn on fixed dialing
1. In the phone options, click FDN Phone List.
2. Click the trackwheel.
3. Click Enable FDN mode.
4. Type the PIN2 code provided by your service provider.
5. Click the trackwheel.
or if you wanna keep it on and add friends to the fdn
Add contacts to the FDN list
3. Click New.
6. Type a name and a phone number.
7. Click the trackwheel.
8. Click Save.
and finally some shortcut keys:
To open the phone, press the Send key.
To end a call, press the End key.
To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
To add an extension to a phone number, press the X key. Type the extension number.
To call your voice mail access number, hold 1.
To type a letter in a number field, hold the Alt key.
To type the first letter on a key, press the letter key once.
To type the second letter on a key, press the letter key twice.
To turn on or turn off mute using the Mute button, press the Mute button.
To turn on or turn off mute using the keypad, press the exclamation point (!) key.
To turn speakerphone on and off during a call, press the period (.) key.
To change the volume during a call, roll the trackwheel.
Aug 02, 2008 | RIM BlackBerry 7100G Smartphone
KEYBOARD PROBLEM
My Blackberry 8310 curve key board is not working properly. When I press 5 nothing happens on the screen, when i press 4,7,and some of the letters dont work at all till i move them arround .
Jun 26, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
Power problems
Hi Tarry101,
Can not help you because you have not listed the model name of the motherboard & the model number. You can find this on the mother board. Depending on the age of the board the model number will be written on the board, usually written in white lettering. (Example), "Asus P4XP-X or AOpend VKM400Am-S".
If you have the manual for the motherboard you can find the model number there.
When you do find the model number click the Ask Me button under my nickname & I'll go over the connections for you.
Mike
May 06, 2008 | Intel Motherboard
Dell Inspiron 530 Desktop Computer   Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
