Question about Whirlpool Washing Machines
Does not fill with water. There are 3 wires to the water level control it is getting power to the brown wire but not to the pink wire. The best I can tell it is not actuating the water control solinoids. Can you tell me a way to read this out and best determine the correct part.
  • 177 Answers
Find the wiring diagram, it sounds like you have power to the pressure switch and none coming out. you need to look at the wiring diagram and determine which color wire runs to the water valve.
Now be very careful and check for power out of the pressure switch, with the timer on at the beginning of the wash cycle where the machine would fill with water, if you have power coming from the pressure switch you could have a bad mixing valve.
Is the water turned on for both the Hot and Cold supply?
If you select cold does the machine fill, with cold? also check warm, and Hot. if the macine fills with any water the pressure switch is not you problem. It could be the mixing valve.
Posted on Jul 08, 2008
1973 chevy truck wiring diagram
The odometer uses the same cable the speedometer uses. It should be mechanical.
Now the HEI coil has two pinks and a brown. One pink goes to the pickup in the bottom of the distributor and the other pink goes to the key switch. The brown goes to the pickup or the ignition module in the distributor.
Jul 14, 2013 | Cars & Trucks
1990 Chevy GMC Suburban alternator wiring
Well, according to my diagrams for 88-94 models, the alternator only uses the red and brown. There are pink-black wires that power some of the sensors and solenoids but should go to a fuse marked ECM in the fuse box.
Have you tried hooking up the harness without using the pink-black wire ?
Aug 28, 2012 | 1990 GMC Suburban
My washer use to fill up with water and all of a sudden it stopped. THen washer begins to agitate but not water.
That has to be the water level control. It has 3 wires and a tubing attached to it.
The 3 wires consist of a live wire, a wire to water valves, and another wire to the motor.
The water must fill first in order for the pressure in the tubing to activate the motor.
No water coming in and motor running without water I would def take look at that water level switch.
You do not work from behind this machine.
What you do is rotate the controls up to access the timer and water level switch.
On your machine you need a long skinny phillips screwdriver to back out the screws on back side of the endcaps. Once they are backed out you can rotate the washer controls up.
Service manual and more is here
Aug 04, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
STARTER WIRE YELLOW Ignition harness
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
POWER DOOR UNLOCK (5-wire reverse
PINK/PURPLE Harness Coming Into Vehicle From Driver's
DOMELIGHT SUPERVISION (-) Use door trigger
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
Model wfw8300sw05 washer, part # ap4340286 water level switch. I know big brother doesn't want me to do this, but I would like to raise the water level during wash and at least 1 rinse cycle. There...
Noooo there all gonna laugh at you lol no just kidding the water level switch aka pressure switch does control how much water the machine fills up with Water level switch, located inside the console, is used in controlling the amount of water entering the washer. There are different water levels, depending on the model you have. Selections might include "extra small", "small", "medium", "large" and "extra large", plus a "reset" option. Some models have a fixed water level switch. This allows for just one water level in the washer. you need an Ohmmeter to test the water level switch. There are three color-coded wires going to this switch: violet (V), pink (P), and tan (T). The violet wire carries the current (electricity) from the timer to the water level switch. Contacts inside the switch send current back through either the pink wire, meaning an empty tub, or tan wire, meaning a full tub of water. this should give you a bit more information about the water level switch also the tube that comes down from the water level switch is also controled as to how much water by that tube that comes off the switch and plugs into the drum as well hint hint If you have any further questions message me back we arent able to tell how to change the engineering specs to a unit although we all love a good mad scientist message me back if you have any further questions Thanks Rick
Apr 03, 2011 | Whirlpool Washing Machines
The machine fills and will not start agitating unless the lid is open and closed several times.
The most likely failure is the water level pressure switch or a failed lid switch. If the washer will drain and spin then it's not a failed lid switch. If it will not drain and spin the likely failure is the lid switch.
The water level switch (pressure switch) has 3 wires attached to it, V (violet), P (Pink) and a T (tan) wire. When the tub is empty of water, contact V&P are closed to allow the tub to fill with water. Once the water level reaches the desired setting, contact V&P opens and then contact V&T closes to start the motor agitating. So, with this said if you were to unplug the washer and remove the wires from the water level pressure switch and test to see if terminals V&T is closing by using an ohm meter would indicate if the contact is closed or not.
Jan 12, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Machine comes on fills with water but will not advance on its own. But it seems the cycle continues because it will go off after a while but when I lift the lid the water still there and if i manually turn...
This symptom of the unit filing and then not washing can be caused by few things.
1. The water level pressure switch not making contact to the motor control circuit but shutting off the water valve. There should be 120 VAC on the yellow wire of the water level control pressure switch when the fill level has reached the correct level.
2. An internal timer contact problem for the motor control circuit. Power for the timer motor should also be present on terminal 14 of the timer.
3. A defective motor speed switch. There should also be power on the yellow wire going to the motor.
All of the above power is sourced via the lid switch.
Black wire is power in. You know you have power in... as it fills.
This is going to take a meter to isolate the problem. Changing parts can get expensive but treouble shooting with a meter will result in determining where the failure has occurred.
Thanks for using FixYa.
May 30, 2010 | Maytag LAT3600A Top Load Washer
Maytag clothes washer, with pump and belt replaced in Nov. 2007, clothes were too wet after spin cycle
The start of the spin cycle is dependent on the pump pumpin out water and the later level switch sensing that the water level is low enough. The water level switch has (usually) a clear tube connected to it and is found in the control panel. You will want to check continuity at different times. First you will fill the tub to the highest water level. Then unplug the machine. By screwing in the screw on the water level switch. Scew it all the way in. then you will check continutity. there should be no cont. between green and brown. and there should be cont between green and black or yellowblack. Do this continuity test with the wires off the switch. Once this test is complete, reattach the wires and plug in the machine and set the timer on spin or drain. When the tub is pumped dry, stop the spin cycle and unplug the washer and do the continuity test again. This time you should have continutiy from green to brown. and no continuity from green to black or yellowblack. Now when i mention the colors that means the placement where those wires were. Make note before you remove them so that you can get them back to place. If you do not get these readings, the water level switch is bad, or there is a leak in the air pressure tube leading to it. At that point I would replace the entire switch and tube. I wish you the best of luck.
Apr 21, 2009 | Washing Machines
Kenmore 80 series washing machine-top load
You will need to replace the pressure switch, Take back off console to get to the switch, there are 3 wires brown, purple and pink, also a hose that attaches to the switch needs to be removed. Switch will cost about 30. dollars
Feb 20, 2009 | Dishwashers
New Timer--New Problem
Sound like you connected the timer up wrong, from my drawing check the following connections to the timer.
terminal 12 & 26 - Black (linked) mains supply
terminal 17 yellow/red (from rinse switch)
terminal 28 grey (from water level switch)
terminal 15 light blue (advance rinse switch water level switch)
terminal 27 brown (door switch)
terminal 25 brown (door switch)
terminal 62 green/black (motor)
terminal 7 red (motor)
terminal 32 yellow (motor)
terminal 9 blue (capacitor /motor)
terminal 8 white/yellow (motor) and white (water solenoids hot and cold)
terminal 71 pink (water selector switch and hot solenoid)
terminla 72 purple (water selector switch and cold solenoid)
terminal 70 white/blue (water selector switch)
Watch the light blue wires as there are several of them!!
Dec 12, 2006 | Admiral AW22 Top Load Washer
Washing Machines Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal De
