I have a Monarch Mate T-700 turntable. Bringing the arm across to start the player sends a boom through the PA system - same thing when the LP finishes playing and the arm returns to off position. Is this likely to be a switch or power supply problem?
  • 101 Answers
The arm triggers the motor to start in most cases. lets say it starts the motor. if the pop is just as the motor starts. its either the switch arc that you hear. (dirty) or if they have a cap installed in the system it could be bad. the capacitor filters any noise like that when the motor starts or the switch arc.( when not Dirty) .
if the arm moving over don't start the motor. you have a button you turn or push to start it. Something under the bottom is Hanging the wires as they are moved by it moving in to place. the wires go up through the arm as well as are routed underneath so they are shorting out that one second on a piece of something ground. this could be but not likely.
Posted on Jan 01, 2011
Technics SL1600 Turntable auto start problem
From the pictures I have seen there's a 7 10 12 button, setting it to 12 should make it move to the start of an LP.
If it doesn't it seems there are a lots of video about this turntable on YouTube, here's one that shows the autostart.
Dec 22, 2013 | Technics Audio Players & Recorders
Needle slides across lp
It might try adjusting the arm weight in the back of the tone arm. If this does not work your needle is probably bad. The point on it has worn down and this is causing it to slide across the LP. You need to replace it.
Dec 11, 2013 | Audio Players & Recorders
ION Profile LP Vinyl-to-MP3 Turntable, tone arm won't drop
I've got the same problem. When you put therecord on, spin it from the centre, and it will release the mechanism inside,this is what I do, and it works fine. I think the problem is that there are twoplates under the turntable, and there was grease between them, after a few goesthe grease disappears, causing the problem.
May 22, 2012 | Audio Players & Recorders
I've just set up my Technics SL D212 turntable after moving house. It keeps skidding across records. I've tried the usual adjustments and leveled the turntable. Any clues?
Please make 100% certain the needle is still in place... To test this *GENTLY* rub your fingertip over it and you should hear noise from the speakers when you do. If there is NO noise then there is likely no needle.
Did you put the protective device on the needle/arm for the move? Is it still on there?
Sorry Mate, that the only thing I've got to help....
Feb 20, 2012 | Technics Audio Players & Recorders
The arm with the needle slides across the LP record - doesn't pick up sound
This is often a problem when you are using a 78 needle on a 45 or 33 record. Some needles can be flipped, so check to see if yours is able to flip between the 78 and 33 setting. If not, you may simply need a new one.
Jan 03, 2012 | Philco PC-841.651 Turntable
I have a Philco Classic ... the turntable did not work. I pulled the arm back, as suggested, and it worked! But it really drags when I try to play an LP. What now?
what do you mean it drags? I noticed if you don't pull the arm back far enough,it will turn on,but the arm will drag foward scratching your record. Try pulling it bacl ALL the way and then it should give you no problems.
Sep 29, 2009 | Philco (R) Classic Turntable CD Shelf...
Sl-dd33 turntable
If your needle just started to skip across the LP, then that means your stylus is damaged/worn and needs to be replaced. It's very hard to see the diamond tip on the stylus, and it might not even be there at all. So checking it might not yield any results. This is what happens when the needle is worn. It will skip across the record.
- OPTiC
Turntable Technician
www.1200s.com
Aug 27, 2008 | Audio Players & Recorders
Sony PS-LX250H turntable won't turn
check the switch that make the lp running located it on the arm (arm uses to put it on the LP) check the motor Make sure no debris whatsoever that can disrupt the LP to turn
Aug 06, 2007 | Sony PS-LX250H Turntable
332 people viewed this question
 Grubhead
Grubhead
