Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
My computer prompted me that the sandisk cruzer flashdrive is ready to be removed but the light is flashing can I still remove it or do I wait until the light stops flashing?
  • 101 Answers
I would wait till it stops flashing always. if the light is on, there is power going out to the drive that is being used. this alone can be damaging to the drive if removed then.
Posted on Jan 01, 2011
My sandisk cruzer 4 GB pendrive ws working fine but now whenever i try to format\copy\cut it shows location 0 with used space 0 free space 0 what should i do
Your flashdrive usually shows 2 drives when inserted to your computer, one is the U3 drive and the other one is the removable disk drives. U3 drive is your separate partition for the U3 system and in order for you to store, copy, format your flashdrive, you should be selecting the removable disk drive, not the U3 drive. U3 is a read only memory drive that is responsible for your U3 to work (just like portable applications). Hope this helps.
Jul 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to rcover from my sandisk back to my library
1. Does the flash drive LED light up when you plug it into various computers? ( not just your own fortesting purposes).
2. Does it pop up in windows explorer at all? ( Should be labeled as Removable Disk by default)
Your flashdrive may have essentially died. Test this flashdrive on multiple computers to determine whether its your computer or the flash drive. If you are trying to recover information try out the app Recuva which can be found on google search. Your information may have been corrupted.
May 05, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk 4gb cruzer micro showing 0 bytes and not accessible, i have valuable data in it
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive you need to format the flash drive, but you willlose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm www.CardRecovery.com
Feb 04, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I need step by step directions, please. It seems as simple as plug it in and its done, but I've got to go to "my computer" etc, etc, and I just need to be walked through it once Thank you
I can help you with your Sandisk Cruzer USB drive problem.
Sandisk Cruzer's are fairly unique in so far as they don't just appear in your My Computer window the way that every other USB drive I've ever used does.
Instead, Sandisk Cruzer's use a terribly 'helpful' piece of software that takes time to load every time you plug it in.
Here are the steps:
  1. Plug in your Sandisk Cruzer USB drive.
  2. Sit back and wait. Don't touch anything.
  3. If it is connected properly, the 'slide' bit will light up orange, at first flashing, eventually solid.
  4. When the orange Sandisk logo appears on your desktop, the drive is ready to use.
  5. Clicking on the Sandisk logo will bring up a menu.
  6. Click the 'Explore Drive' option to bring up a windows explorer screen of the USB drive.
  7. When you are done with the Cruzer, return to the Sandisk Menu App and select 'Eject' to prepare the USB drive for removal. (Just pulling it out without 'ejecting' it will destroy all your data 1 time out of 50 or 100, so always use the eject feature.)
I hope that helps.
Aug 28, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
I bought a SanDisk flash drive a little over a year ago. It opens fine on XP, where I have to enter the password to see my files, but on Windows 7, I'm never prompted to enter my password and thus can't...
The sandisk flashdrive has on the fly encryption. It encrypts it all the time when you remove it and then decrypts it all the time when you insert it unless you have a password. It's possible that sandisk has not encountered the different environment of windows 7 and did not make flashdrives ready for that os.
Dec 25, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Heating up, light not coming on
cruzer micro 4GB, loaded with data. works perfectly in all systems except my xp. Problem didn't originate until after ghosting system to correct different problem. Now, error message states flashdrive not recognized. must then get behind pc, and gently work with it until i can hear the shift in the duo core processors and the orange light on the flashdrive comes on. Please help.
Mar 10, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk 8GB lights up but wont register
This one is just a hunch. The drive might be bad but this is worth a try. Its possible the drive letter somehow changed on the flashdrive. Plug in the drive, RIGHT click on "My Computer" and select "Manage" from the drop down menu. Now select "Disk Management" from the list. If you see your flash drive on the list, right click on it and select "Change drive letter and paths", then click on "change", now assign it a new letter like "F" for example. Click ok, ok, ok. If it showed up the the list and it's still not registering, unplug it and plug it back in. Hope that helps.
Feb 15, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk Cruzer locks up my computer when i plug it in.
maybe the flashdrive is infrected witha virus or something
try to format it
Nov 16, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
120 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
