Question about JVC Car Audio & Video
I have just fitted a JVC KD-R711 to my 1973 MGB Roadster. As there is no custom wiring harness I have connected the 12v battery feed to the yellow lead in the power cord and the earth to the black lead in the power cord. The unit will not switch on however the display lights up for a few seconds when the ignition is turned on with a timer showing and then goes off. If I press the eject button "eject" comes up in the display for a few seconds and then goes off. If I press "reset" it has no effect. I have tried swapping the red and yellow wires and then the unit is completely dead and pressing "reset" has no effect. Halfords have tested the unit and it works as I would expect it. Any suggestions welcome.
  • Joe Lumsden Jan 02, 2011
    Hi Dan
    Thanks for your answer. Just a point of clarification please.
    So far I have been using a fused ignition live connected to the yellow lead.
    I can connect the yellow (12v) to the red (accessory) but then how can the yellow be ignition live and the red constant live or vice versa as they are now connected together?
    Regards
    Joe
    Hi Dan
    Yes that's it - it works. Thanks.
    Now that you have put me on the right path and reading the instructions again I think the red will be the ignition switched supply and yellow the constant.
    How a manufacturer can describe a required feed as "accessory terminal" (the red lead) is beyond me.
    Happy new year to you and kind regards
    Joe
    Genius:
  • 1,098 Answers
Hi
If you connect the red and yellow together then attach them it should work, use an inline fuse if it has not already got one, the yellow should be ignition live and the red constant live although on JVC I have seen them the other way around also.
Hope this helps
Regards
Dan
Posted on Jan 01, 2011
  • Dan Doherty
    Dan Doherty Jan 02, 2011
    Hi Joe
    I meant puerly to test, if you put both the red and wire toghether then if the unit works as it should. try it and get back to me.
    Regards
    Dan
  • Dan Doherty
    Hi Joe
    yes this is what I was saying about JVC don't know why but some are vice versa, I think possibly because some are foreign imports intended for other markets. Happ new year hope it is an enjoyable one. Nice car by the way
    Regards
    Dan
The memory on my new jvc car stereo model kd-s17 does noty work whenever i turn the key off then on i have to reset the clock and presets all of my wires are connected
need to check the yellow constant power wire on wire harness to see
1. connected to battery with constant 12 volts
2. if wire has power 12 volts
if no power check fuses to see if blown
with out this wire working right you will never have pre set station on radio or clock
with correct time
Dec 22, 2010 | JVC KD-G801 CD Player
AM FM CD DET FACE CAR STEREO: installed an alpine stereo in my mustang and every...
That's because the memory wire has not been connected to a permanent live supply.
There will be an ignition switched 12v supply and a memory wire. The first is yellow on many brands and the second is red, but you need to refer to your fitting manual to check or look directly at the wiring harness as the wires are often individually labelled.
Since they both take 12v some folks mistakenly think that they can just be piggy-backed to each other and feed from the same supply. They can, but only if it's to a permanent live feed but that then leaves the risk of the unit being left switched on when the car is parked and draining the battery.
May 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
I need a wiring diagram for a JVC KD-R805 installation
For putting it into what kind of car? Or did you mean the radio harness itself? Red is constant 12v, yellow is Accessory 12v, Black is the ground. Solid blue is power antenna, blue with a stripe is a 12v accessory meant to power the amp (AKA AMP REM), White is front left speaker, gray is front right. Purple is rear left, green is rear right and any of the white,gray, green or purple wires with a black stripe is the negative for that speaker. If you post a reply with a vehicle model and year I can give you the factory wire harness colors as well.
Jan 13, 2010 | JVC KD-R800 Car CD/ MP3 Player
Just installed jvc kd-s16 and it loses power after 5 seconds. Used proper wiring harness and installed in 1996 f150
Connect Yellow to Battery (always 12V), red to ignition, and black to ground. Disconnect all others. Check it. If the radio stays on and plays CD, then radio is good. You may check other wiring
Dec 27, 2009 | JVC AM FM CD DET FACE CAR STEREO
I recently purchased a jvc kd-pdr51 car stereo and tried fitting it on my own but whilst fitting it i had problems fitting all the wire in at the back.so after much hassle i disconnected the stereo to try...
Could be an anti theft feature - should be in the manual along with reset instructions. Some of these aftermarket stereos have the switched and permanent 12V feeds swapped compared to the vehicle wiring, which can cause similar problems. Worth checking the feed voltages are correctly connected.
Nov 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
I have the same model cd player (jvc kd-s575) and I need to connect this straight to a 12v battery. What is the best way to do ths and what wires are positive and negative?
im bit confused, if you are going to use this radio in car, or outside, using car battery.....? anyway, this how you hookup all the wires..
+YELOW WIRE,- DIRECT FROM BATTERY TERMNIAL..12+
+RED- MAIN WIRE..CONNECTED TO ACC/IGNITION SWITCH, ALSO 12V+
-BLACK- NEGTIVE, GROUNDING WIRE 12V-
WHITE TO WHITE/BLK----SPEAKER
GREEN TOGREEN---SPEAKER
GREY TO GREY-----SPEAKER
PURPLE TO PURPLE------SPEAKER
if you are using outside the car using car battery, then you can twist yellow and red togather..for postive 12v+
Oct 26, 2009 | JVC KD-S570 CD Player
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
See ya message on kd-g120 cd player
Hello tinsman360, It sounds like a wiring problem. Make sure that the yellow wire from the receiver wiring harness is connected to a constant 12V source (live with the ignition turned off) and the red wire is connected to a switched 12V source (accessory) that is only live when the ignition is in "accessory" or "on". Also check that the ground wire (black) is connected to the metallic body or chassis of the car. It's also possible that one or more of the other wires is shorted to ground or another wire. Check for bare insulation and/or the ends of unused wires coming into contact with the chassis or with other wires. Especially note that the blue/white wire should only be connected to a power antenna or a remote amp. Hope this helps.
Jun 06, 2009 | JVC KD-G120 CD Player
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
JVC car radio/cd player wont switch on
As a sanity check run a temporary wire directly from the battery positive to the radio. Twist the red and yellow wires together and connect it to the wire from the battery. If this works either your red or yellow wire connection under the dash or to the harness is not hot like you think. Yellow usually goes to a constant 12 volt source (to keep radio memory) and the red wire to 12volts when the ignition is on. In some radios this is reversed. The test I mentioned will determin if the problem is in the wiring or the radio.
Jun 18, 2007 | JVC KD-S570 CD Player
Car Audio & Video Logo
262 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
