Question about Acer TravelMate 529ATX Notebook
Computer works,,,, but displays only white screen plss help ; ((
    Genius:
  • 1,288 Answers
Only way to eliminate some issues is to connect it to an external monitor. If the screen works and you get an image on an external monitor, the graphics chip on the laptop is at least ok and the fault is with either the inverter, backlight or VGA cable (probably the latter).
If you get no image on the external monitor, then you need to look at the graphics chip on the motherboard as possibly failing
Posted on Jan 01, 2011
My pc desktop is showing a white screen when its on what should i do?
Is it an LCD monitor ?
When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See Below for the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance. Hope this helps.
Dec 30, 2012 | Compaq Computers & Internet
My pc is showing a white screen when iys on
Blank and white screen solution
Hi,there are two kinds of white screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your phone am sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to the model of the phones care center to fix you problem...
And also flex can make screen go blank and or white.(if it is a flip phone)The flex is a connector that connects the screen to the phone board of the phone.That can also be the cause, when the flex is damaged,it can cause blank and white screen display .
i hope ,i will help you ,thanks for trusting fixya...
Sep 16, 2010 | Cell Phones
W205 sony ericsson screen white how to solve this problem
WHITS SCREEN DISPLAY.
hi,
also sometimes it might be the flex of the phone too,
what makes the phone to display white can also be caused the flex inside that connected to the screen of the phone that makes the phone display
is faulty and it needs to be replaced so that the screen can be as one again.
Aug 07, 2010 | Cell Phones
I have a blank screen but sound on start up. It sometimes works but not for long
plss help me bout psp 3.90 M33-3, it was my nephew psp and we didnt knw how to fixe it. it was we cannot detect the games but when you check at the memory card there it was. plss help.. thnx!
Jul 01, 2010 | Sony PlayStation Portable (PSP) Console
How to connect my compaq v2148ap laptop to tv using svideo??plss help fast....i dnt have the vga wire i have the 7 pin wire!!
Do not use a cheap cable !
Use a good quality cable
You also need to tell your computer that it has another display available to it
to do this RIGHT click on a blank area of your desktop then select properties.
Now click settings If you can see TWO screens with the number 1 and 2 on you are already part way there
Now click Advanced.
If you see a tab that is for your graphics card select it
From here you should be able to tell your laptop to use multiple displays
You should select Clone (if you have dual-view available then select that)
You may have to lower the screen resolution at first and maybe even adjust the two displays individually
If there is an option for "detect my tv" that would also be a good starting point.
It does vary from card to card and even computer to computer for the exact steps.
With any luck you should now have two displays and it would be just a matter of making minor alterations to make the two displays suit your taste.
Be aware however that not all computers with Svideo may work with a regular tv. This process works best with flat screen lcd and plasma tvs
Aug 22, 2009 | Compaq 389897-001 - HP/ Presario V2000...
White screen when I take a picture
CCD FAILURE
Just call Fuji u are entitled for free repairs as it is a manufac known defect in thousands of cameras plss see the link and call fuji in ur area see www.fuifilm.com
http://www.imaging-resource.com/badccds.html
Pls rate me FIXYA ! for free help
May 05, 2009 | Cameras
Help me fix to the set up of my monitir AOC 7f 17''
Good morning! kindly try the following:
-mouse pointer on the screen, right click the mouse, then click the Properties, then click Settings tab, then click Troubleshoot or Advance which will guide you in setting your screen display. best regards.
May 04, 2009 | MPC Computers AOC 7F 17" CRT Monitor
Philips 170S4 white screen not display.
its in the power suppy section,most of the lcd monitor has this problem,try to check the capacitor electrolytic or replace all th 16v capacitor
Apr 03, 2008 | Gateway FPD2275W LCD Monitor
Acer TravelMate 529ATX Notebook Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
