Question about Hitachi Televison & Video
I have recently purchased a hitachi tv 19ld3560u a and the tv when left in standby mode overnight turns itself on around 7 am. I am assuming that this maybe a software fault?
  • 58 Answers
SOURCE: Blue ghost image on the top left hand corner of my Hitachi 50V500A.
You have a defective light engine and you do not have to be under warranty for Hitachi to replace this part. We just went through this and here's what you need to do. Call Hitachi's customer relations department at 800-654-7013 and tell them that you have a defective light engine. They will act like they've never heard of this problem but they have. They will give you the names of some certified dealers in your area to call. Once a tech comes out and confirms that it's the light engine, call Hitachi back and they will send a brand new light engine to the dealer and Hitachi will cover the cost of the part (cost $1500).
Here is the deal, if you're under warranty, Hitachi will cover the part and the install. If you're not under warranty, all you pay is the install. Our install cost $400. Others on this site have paid $200. Do not let anyone tell you that you have to pay for the light engine part...you do not. Hitachi has not recalled this part but they are replacing it for free. Also, deal only with Hitachi customer realations number that I listed. Good Luck!
Posted on Feb 14, 2008
  • 1779 Answers
SOURCE: TH-42PX80U JUST TURNED ITSELF OFF
The 7 blinks indicates that a failure has happened within the Y main and the upper and lower y drive panels. I recommend you taking it in to a Service center for and evaluation.
Posted on May 23, 2009
  • 65 Answers
SOURCE: Acoustic Solutions TV Fault
I think you are looking at a power board problem. I had the same thing happen to a Vizio and I replaced the power board and it solved the problem. It could also be the input board but most likely the power board.
Thanks,
Ced
Posted on Jul 13, 2009
  • 76 Answers
SOURCE: HItachi Model 42HDS69 Stuck in Standby
Tv problems?. any warrenty on the set? how old is the set?
Posted on Mar 18, 2010
SOURCE: Hitachi 42LDF30U LCD TV stuck in standby mode
Hi there mine has started doing the same thing today, on other hitachi models it is a serious fault warning, i will come back when i find out more.
Posted on Jul 19, 2010
Standby keeps turning on when in standby but auto works turns itself on and off fine. Both sides of unit
I don't think you have a problem... I have a Taylor 8756p-27. In standby mode with my unit the beater motor turns on for about 15 seconds every 15 minutes and the compressor turns on as needed to keep the mix at a safe temperature. This is what standby mode is supposed to do. If you don't want it to turn on and off so much in standby mode, perhaps leave it in AUTO mode and it will turn off and on as it needs to to keep your product at the proper temperature.
May 06, 2015 | Taylor 754-33 Ice Cream Machine Soft Serve...
Hitachi Plasma TV Model PD32-A3000/AVC-A3000
Check for any fuse blown also, Otherwise it s a power supply fault.
Jul 30, 2008 | Televison & Video
I have a hitachi television L32HP04U A that won't come out of standby. When switched on it the LED will light blue and then blink blue and red.
Probably you should just disable the Standby feature, though it also depends on why it's in Standby. On some TVs, it's when it's been left on and idle for a certain period of time- basically the TV will turn itself off, or go into a lower powered state. It's possible it will not come out of it because the TV could be overheated, and needs time to go back to normal. Without know the specifics as to why the Standby happens I couldn't say, and it's also hard to say what the issue is with it coming out of it.
Go into the TV Menu and find Power Options. Set Power to Normal, or Quick Start (or whatever Hitachi calls it). If this is separate from the Standby Options, then disable the Standby option on its own.
Jun 06, 2014 | Hitachi 32LD8700 32 in. LCD Television
Hello. I recently bought model TC-L32C22 for the waiting room of an office. Every morning when I turn on the tv, I have to go through the setup of the channels again. Why is this? Did I do the initial...
Could the unit be losing power overnight? If the TV is on a switched outlet, change outlets (or make sure the switch stays on). Did you actually finish the setup? The setup screen will continue to appear if you press Exit before it is completed. You should have seen the "Setup is complete" message.
If you are correcting the time as well as repeating the scan, the TV is probably losing power overnight.
If this is power related, consider a UPS that will power the TV overnight in Standby mode. It uses 100 W when on and 0.3 W in standby.
I hope this helps.
Jan 19, 2011 | Panasonic Televison & Video
HITACHI 26LD2550B,AFTER SWITCHING OFF OVERNIGHT,SWITCH ON NEXT DAY ONLY GET SOUND FOR 15 MINS,THEN PICTURE COMES ON PERFECT
This maybe due to capacitors dried up in air conditioned room. Keep the TV in standby mode, will keep the large electrolytic capacitor cured at all times.
Aug 15, 2010 | Hitachi Televison & Video
Jul 07, 2010 | Hitachi Televison & Video
TV on Standby
There is a Sony S3000 protect blinks table:ebf219b.gif
May 27, 2010 | Sony KDL-32S3000 32 in. LCD Television
Mar 18, 2010 | HP Televison & Video
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Hitachi Plasma Model PD32-A3000/AVC-A3000
vertical red line on screen - I have a Hitachi plasma 42HDs69
Jul 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
