Question about Belkin Wireless Surf Router (F7D2301)
Want to connect an iPad to wireless router, it won't accept password ?
Make sure you are entering the letters in upper-case when entering the password to connect to this router. The iPad always shows letters on the keyboard in upper-case, but they may be entered in lower-case and it will not connect.
Posted on Jul 18, 2012
mbase213
  • 728 Answers
SOURCE: can't connect wirelessly as it won't accept my password.
Hello paulclarke88;
What your router is asking for is a secure wep login. You can provide this number by loging into your router directly, and go to the securty section of the menu, and generate a new wep key. It will then generate a key, that you should write it down, because this new key is what will give you access with your Acer. Typically the Dlink login is ip address 192.168.0.1 Usernames admin Password
is left blank.
Good Luck and don't forget to leave a rating.
Thanks Mark
Posted on Apr 16, 2009
  • 104 Answers
SOURCE: wireless g router won't accept my password on OSX
Assuming you don't have access to the admin of the router.
press and HOLD the reset button with a dull pointed object for 10 seconds (it is next to the power plug) you will have access to the setup wizard with a connected PC's browser at
HTTP//192.168.2.1
use a known security arrangement or non at all for just the test phase to make sure all can communicate with another.
Posted on Mar 28, 2010
  • 1584 Answers
SOURCE: my N1 vison keep losing on wireless connection
If you have a 3G phone in the house, It operates at the same frequency and is a nono.
If not I would suggest you completley rest modem and re-enter U/N, P/W etc and set up secure network also. If still a problem, maybe faulty modem.
Posted on May 10, 2010
SOURCE: I am trying to connect my ipad to my wireless
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Click on wireless then wireless security Enable WEP then enter new password save settings and restart router .Then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Nov 18, 2010
  • 3289 Answers
SOURCE: My iPad thinks my Siemens
Hi Kent - this is apparently a router supplied by an ISP in the UK. From what I have seen, there is a WPA key on the bottom label of the router. It looks like this:
I found this on this site.
I hope this helps & good luck! Please rate this reply "4 thumbs up" if you're happy with the info I found. Thanks!
Posted on Jan 13, 2011
Can't connect my Belkin F5D7234-4 v4 to my ipad
This link is for Iphone repair, It solved some of my Ipad problems. Hope it works out for you
Dec 27, 2011 | Belkin (F5D7230-4) Router (587009)
My router won't accept password that is on printout from when setup
Check the wireless settings of your router. Connect the computer to the router and open the setup page of the router. The wireless settings might be changed. Follow this link to find wireless network key
Nov 28, 2011 | Linksys Wireless-G WRT54G Router
Won't accept password
Which password? Are you trying to connect to the wireless network. Make sure that you have the correct network password. Open the setup page of the wireless router and check the wireless network key WEP WPA.
If you are trying to open the setup page of the router then try default password admin.
Can't connect iphone to dlink router
When my ipod tries to connect to my computer wirelessly, it asks for the password. I enter it, but it won't accept password. It finds the router ok, just says password is incorrect. I've checked and it's the right one. Any suggestions?
Nov 27, 2011 | D-Link DIR-615 Wireless Router
G + MIMO Wireless Belkin Router - I cannot connect to the internet with my iPad. It will not accept the password to my network at home. How do I connect my iPad to my home network?
Did you configure the router, to select:
1. SSID, the "name" of your network;
2. encryption-level. Hint: use 'WPA' or 'WPA2'.
3. password to your network.
If so, then enter the SSID/password on the iPad, to connect to your network.
Jul 30, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I am trying to connect my Ipad to my wireless router (Wi Fi) and the Ipad is telling me I have enter the incorrect password.. I know that I am entering the correct password.. Please help me.
Welcome to Fixya. If you iPad is not accepting you password you can check the password or Network Key on your router. To access the router page you need a working computer that is connected to the router. To access your router you need to use a computer that is connected to it. Open a Browser then type 192.168.0.1 or http://routerlogin.net. The Default username is admin and the password is password. Password is case sensitive.
Go to the Wireless Tab select Wireless Security under the Security Mode you will see there Network Key or Passphrase. The Network Key serves as a password or security code on your network to make it secure. Network Key is case sensitive.
Don't forget to say thanks. Thanks for using Fixya
Feb 07, 2011 | NetGear WNR1000 Router
I'm trying to connect a new iPad to our home wireless network. The network key for the Linksys WRT5-4G router that always works on every other computer does not work with the iPad. What steps do I need to...
  1. From the iPad's Homescreen, tap Settings. (This assumes you didn't rearrange your apps. If you did, find the Settings icon wherever you put it.)
  2. In the Settings screen, tap Network.
  3. To start the iPad scanning for available wireless networks, tap the WiFi button and then slide the slider to "on". In a few seconds, you'll see a list of all the networks near you, whether they're public or private (if you don't see the list, there may not be any within range).
  4. The list of WiFi networks you'll see will include two kinds: public and private. Private networks have a lock icon next to them; Public don't. The bars next to each network indicate the strength of the connection - more bars means a faster connection.
    To connect to a public network, just tap the network name and you'll be online.
  5. If you want to access a private network, you'll need a password. Assuming you've got the password, tap the network name and enter it the password. Then tap the "join" button at the bottom right of the screen. If your password is correct, you'll connect to the network and be surfing the web. If not, try entering it again (assuming you've got the right one, of course).
  6. Advanced users can click the arrow to the right of the network to access more technical configuration settings. Everyday users probably won't need to look at these options.
Jan 11, 2011 | Linksys Wireless-G WRT54G Router
I have a WZR-HP-G300NH router and am having trouble connect my ipad to it. Ipad is asking for a pass word. How do I fix it?
I recently got this router and had trouble keeping a wireless connection to my ipad. On the router, I set up security with wpa2/psk and set a password and was able to enter that password on the ipad and got a connection but only briefly. After repeated losses of connection, I took encryption off and now it works fine. This is a terrible solution though and eventually want to get encryption back on .
Sep 14, 2010 | BuffaloShop Buffalo Technology WHRG300N...
My linksys router will now allow my Ipad to connect. The ipad does connect to other routers execept mine
usually with the IPAD. You need to put the correct settings into the wireless connection settings.
You wll need your SSID (the name your router shows up as when you search for wireless connections)
Your security type ( WEP or WPA/WPA2)
your wifi password.
I have connected many IPADS, as long as you have the correct details it should work
Are you setting the correct security type?
Aug 08, 2010 | Linksys Wireless-G WRT54G Router
How i connect dlink access point in apple ipad
in your apple ipad switch on your wireless and search for the available networks you can find your router name just click that it will ask for the wep key its nothing but your wireless password you need to enter that then it will connect automatically
Jul 26, 2010 | D-Link AirPlus DI-524 Wireless Router
Belkin Wireless Surf Router (F7D2301) Logo
201 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
