Question about Dishwashers
I want instruction manual for dishlex global 300 dishwasher
  • 3,740 Answers
Happy New Year and welcome to FixYa, I am Kelly.
It took a while to locate the manual as there was not a model number. The model number I located was an Electolux DW300XA and the manual can be found here:
http://manuals.appliancesonline.com.au/dw300xa/dw300xa_product_manual.pdf
If this is not your model number, please respond wth your model number and I will look for the correct manual.
Thanks for choosing FixYa,
Kelly
Posted on Jan 01, 2011
We have a Dishlex DX301WW with no manual. Would you please locate one for me.
thank you
Jenny
Posted on May 28, 2011
SOURCE: Dishlex Global 300 - stopping mid cycle
This is just a suggestion....  so please try and please post any corrections.
Anthony M is on the right track.  Refer to his entry and download the manuals. Tks Anthony.  When the Dishlex 300 starts for the first time, there is a service mode set up. The service mode allows you to set a 'fill-time' for the water to reach the right level, dependent on the water pressure and flow... which is described in the manual.  So resetting the Dishlex is the first step. Then set the water level.  If the water is too low, it will not wash, it will flash. When the water is too high, it will leak out of the rubber seal.
I hope this helps you all. Waz
Posted on Jan 14, 2009
SOURCE: Dishlex Global 300 Dishwasher
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
Posted on Sep 15, 2008
SOURCE: Dishlex dishwasher global 300. Dishwasher
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
Posted on Nov 05, 2008
SOURCE: My Dishlex Global 300 dishwasher
I think I had the same problem. I don't know much about dishwashers, but the "Flashing Rinse" has something to do with the drain, or the drain pump (which is why the water doesn't drain).
My dishwasher stopped its cycle, after having filled up with water, even though everything else worked fine, because the drain pump was not even turning on. So I guess, the first question I asked was, is the drain blocked? No. When this happened the first time, the flashing rinse cam up. After that, the dishwasher just wouldn't drain, and there was no longer a flashing rinse.
So then, I figured, the drain pump is probably rooted. The drain pump is found underneith the dishwasher, just behind the front panel on the left hand side.You'll need to remove the metal covers from the front and the left.
When this happened to me, I thought I'd need to buy a new pump, so I pulled the other one out (its a bit fiddly, you have to disconnect the two electrical wires, then remove the drain pipe from it, and then wiggle it off. But when I got it out, I unscrewed it (it has the special hexagonal screws, not phillips or flathead), and it turns out, a fairly large fruit seed had got into the drain pump and blocked it, preventing it from spinning. I put it back together again, and it worked.
It so far has beaten paying $100 for a new pump.
If you want a visual of what the drain pump looks like, look up the dishwasher part number #8905912, you should be able to find it on the internet. Hope this helps.
Posted on Sep 17, 2010
  • 3247 Answers
SOURCE: I'm looking for instruction manual
I think you will find the manual at this site.
Please rate the solution if you found it helpful. Otherwise post a comment and I will try get the solution you are after.
Posted on Oct 17, 2010
Testimonial: "Thank you for your help, that solved my problem. Regards Henry."
Dishlex global300 is gone into flood mode how do I fix it
Dishlex Global 300 Dishwasher issues - Kitchen - Home - Whirlpool ...
forums.whirlpool.net.au > Home > Kitchen
WhirlpoolAug 31, 2011 - As stated in the title, it is Dishlex Global 300 model and it was here when ... is flooding about to happen inside the DW and prevents flooding). Bosch or Asko dishwasher
Mar 7, 2014
Dishwasher that actually WORKS PROPERLY?
Dec 3, 2012
Dishlex Global 300 dishwasher woes
Aug 8, 2005
Dishwashers ...
Mar 28, 2004
More results from forums.whirlpool.net.au
Nov 25, 2015 | Dishwashers
I want to know where to put the tablet or detergent in the dishlex global 300
you may want to refer to page 10 of the instruction manual available from this site.
Dec 06, 2012 | Global Amici Set of 2 Glass Covered Dishes
I'm looking for instruction manual for Dishlex Global 300 dishwasher
Oct 17, 2010 | Dishwashers
I would like to download a user manual for dishwasher dishlex global 300 DX 300 WA - thanks Lou
I think I have a PDF 300 Manual. Please email at mexeter@westnet.com.au and I will email it back.
Rergards
Mark
Sep 02, 2010 | Dishwashers
Dishlex global 300.... The normal light starts flashing mid wash
i think it means the water heater in the dishwasher is not working,or the element is shot.
my 300 had a burning smell before the light started flashing.
Feb 07, 2010 | Electrolux Dishwashers
Dishlex Global 300 dishwasher no manual
Try Googling your dishwasher for the proper manual or see if you can go online and download it from the manfacturer
Jan 23, 2010 | Dishwashers
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Can you connect a dishlex global 300 dishwasher to the hot water supply?
Hi Devilnz_05
I have a DX300WA global model and the instruction manual actually recommends that you use the hot water outlet for a better cleaning result, but of course it is not mandatory.
May 04, 2008 | Dishwashers
Dishwashers Logo
2,552 people viewed this question
Top Dishwashers Experts
