Question about Eureka Vacuums
We have the Eureka EZ Kleen upright. We have suction through the hoses but not the main vacuum. The brush turns fine but the vacume does not **** anything up.
THE HOSE BETWEEN THE DETACHABLE WAND AND THE BRUSH ROLLER AREA MUST BE CLOGGED WITH CARPET FIBERS. CLEAN IT OUT AND IT SHOULD WORK.
SFC ANDERSON, RICHARD T US ARMY
Posted on Jan 09, 2009
Hi there. my cleaner turns on and i have suction through the hose, but not on the bottom. can you help?
Does the brushes turn , if not you have maybe a broken belt. if brushes turn i suspect a blockage in the bottom unit.
pete
Nov 08, 2010 | Eureka 2971AV EZ Kleen Bagless Upright...
Roller not moving
The belt is stretched, worn or broken and therefore not turning the roller brush. You need to replace the belt. It's simple to do. Here is a link to the belts you need and the manual which has instructions:
2971AV EZ Replacement Belts
2971AV EZ Owner's Guide (8.3 MB download)
Nov 19, 2009 | Eureka 2971AV EZ Kleen Bagless Upright...
The power paw on my vacuum machine is not working.Eureka ez kleen
The filter is not the reason it's not working. Take out screws and open Power Paw, remove fur from the roller brush on the right side, there is a small gap where fur winds around tightly, cut off with scissors or pull out with a small toothpick.
Oct 18, 2009 | Eureka Vacuums
My eureka capture is very noisy
check belt whistling may be something in hose
Aug 12, 2009 | Eureka 2971AV EZ Kleen Bagless Upright...
Eureka 2981bvz bagless belt pully is getting too hot and burning through belt
Check the brush roll, if one end has overheated and is locked up so it won't turn, then you need to replace the brush roll.
Jun 04, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Smell/suction
The brushroll may spin when looking at it but stops when pressure of the floor is applied. The belts stretch, so they look fine but are not. The smell - if it's a rubber smell - would also be the belt. Some, or most, brushrolls can get hair in the ends that could also cause a smell and belt problem.
Dec 17, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Burning smell/lost suction
Is the brush roll turning while on the carpet. If the belt is old, then it has stretched and will slip causing a rubber smell. But if it is an electrical smell, then your motor is failing and will need to be replaced.
Dec 15, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Picks up poorly
I'd check thoroughly, the hose right next to the bush roll.
Sep 13, 2007 | Eureka 2971AV EZ Kleen Bagless Upright...
Vacuums Logo
106 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
