Question about Nikon Coolpix 3200 Digital Camera
Lens error comes up when camera switched on - Nikon Coolpix 3200 Digital Camera
    Guru:
  • 441 Answers
Good day,
This is a common problem and sometimes can be fixed.
Please see details on my tip on how to fix this error here:
http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Let me know if my tip was useful for your problem!
Regards
Posted on Jan 05, 2011
Error 00
Always when an error occurs, switch off the camera. Wait till the memory access light stops burning or stops flashing (If it did)
Then remove the battery. This will be a signal to the camera, to start all over again, when the battery is placed back and the camera is switched on again.
In your case, the camera indicated an error with the lens, or the connection with the lens.
Carful remove the lens, as described in the manual. Check is all contacts are clean and intact and of course shiny. Just a spec of dust could be the culprit. Place the lens back and look and feel if it lock correct. Then try switching on the camera again.
If you are not sure the battery is charged completely, before placing it back, charge the battery.
Then reinsert the battery and hope the error does not come back. When the error comes back it is time to contact a service centre.
Feb 05, 2014 | Samsung NX1000
I can't get rid of 'Lens Error' message and keep my camera switched on for more than a minute.
You don't need to drop a camera to get a lens error. Could be anything, from holding the camera in a wrong way (touching the lens barrel) or a bit of dust in the barrel or a gear, or a gear that breaks off. If the lens retracts correct when the camera is switched of, and comes out to the full extend when it is switched on, you should think everything is in working order. But when you say, the screen looks ver blurry that could be an indication, the lens is not coming out correct, or the focus mechanics does not work correct. I'm afraid you have to bring the camera in to a service centre (or buy a new one) if you can't solve this, by again take out the battery, charge the battery and reinsert the battery.
Jan 26, 2014 | Nikon COOLPIX S3300
I cant use my camera it appers system error how can i fix this?
Please check if the lens can move free. If there is any obstruction, it will stop and the camera will give an error. Also never try to stop the lens from moving.
Start over again. Remove the battery, charge it. Place the battery and the memory card when you are sure the memory card is not in the locked position. Then close the battery door carefully, so the door is locked correct. Then switch on again.
If the error comes back, perhaps the lens is blocked inside (broken gear or something like that) you have to contact the service centre.
Jan 10, 2014 | Sanyo Xacti VPC-S770 Digital Camera
Lens error
that could be the lens cover not opening all the way, try and look at the lens as if you were doing self-portrait, and power on. if lens cover opens all the way but lens doesn't come out, the lens might be stuck or motor broke.
Sep 06, 2009 | Canon PowerShot SD850 IS Digital Camera
LENS ERROR problem
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Aug 04, 2009 | Nikon Coolpix 3200 Digital Camera
Lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 15, 2009 | Nikon COOLPIX P5000 Digital Camera
I have c1 error
c1 error is caused by Dirt /dust in the lens and lens gear box ( this drives zooming only ) preventing optimum functioning. Lens cannot properly come on line ( shutter and diaphragh mechanism then do not come on line ) and the camera switches off. Solution : is ether replace lens unit or dismantle lens to clean out ( from gear box and the helicoil of the lens ).
Dec 15, 2008 | Kyocera Finecam S4 Digital Camera
Lens error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 13, 2007 | Vivitar ViviCam 4345 Digital Camera
Nikon Coolpix 3200 Digital Camera Logo
120 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
