On a roberts rc 9907 how can I get it to carry on automatically recording on the second side of a tape once it's finished recording on the first side of the tape ?
    Brigadier General:
  • 8,546 Answers
The manual...
http://www.robertsradio.co.uk/assets/User_guides/Analogue_radios_pdfs/ug_RC9907.pdf
Turn the tape to the other side and start the recording where you desire.
Posted on Jan 01, 2011
How I solve the channel overlapping?
This is down to the head alignment. Once that is corrected the sound will recorded normally and playback normally too. However any tapes recorded during the fault will not play right.
The head alignment can be corrected, using two adjusting screws located either side of the head. To get at them the door cover has to be removed. To align you play a pre-recorded good quality tape. You adjust the screws till the sound is bright and clear and only the sound recorded on that side of the tape can be heard. Best done with headphones. If you can use a commercial music tape. If you use the decks own recordings it might not be right.
If there is any damage to the head mounting you will not be able to get the alignment right.
PS use the right screwdriver for the head screws. These are very small and easily wear away. If you wear the screw head away you might have a job getting a new small screw that will fit.
May 01, 2014 | Nakamichi Audio Players & Recorders
Recorded album and first track is cut at beginning everytime
you are going from a record(vinyl) to what before you are doing the ipod? a cd or a tape..when recording the tape..remember theres 30 seconds of plastic leader on those reels..need to forward the tape past that leader to the actual tape before the recording begins..the only other thing is that some recordings that are protected will automatically screw up your recording so as to stop copyright infringement..it may be sending a purposely blank signal for a brief period..and thats encoded into the original recording..
Mar 15, 2014 | Sony Sound Forge Audio Studio 9
How do I finalize my disk once I have finished recording from VHS tape. How do I get the finalize to light up on menu on screen?
If they are +RW discs they cant be finalized and can only be played on +RW compatible players. Use +R, -R or -RW if you need a wider compatibility (DVD-VIDEO). Finalizing is quite easy following directions in the manual.
Apr 20, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
I have a Fisher RS636 receiver. I can't seem to record from "Tape 2 to Tape 1" or from 1 to 2. I don't have a remote. Will this be a problem? Can you guide me through procedure. Do...
Most receivers have a dub switch and it would still be in one direction only, say Tape 1- >> Tape 2. Lacking a dub switch the Tape Loops are in an order like that so monitoring the one upstream of the other allows the second one to see it as a source.
Aug 22, 2011 | Audio Players & Recorders
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
I require to reset time & date. Also reset service indicator
How to reset time & date on Audi A4 B5 facelift - with digital clock.
For time and date settings you should carry out follow instructions:
1. On the instrument cluster display you will find two small buttons at the bottom side. The left button is provided for time and date settings.
2. Pull the button once and you will see the "hour" number in pulse mode. Then turn the button finely on the right side step by step until you set up the "hour" number. When you finished the "hour" number setting you must pull once again the button until the "minute" number come in pulse mode.
3. Now turn the button finely on the right side step by step until you set up the "minute" number. When you finished the "minute" number setting you must pull once again the button until the "day" number come in pulse mode.
4. In the same mode you will set up also the "month" and the "year" numbers. After all settings you must waiting few seconds until display no more pulsing.
Service reset instructions:
1. Press and hold button [A] in the picture below.
tdisline_573.jpg 2. Switch ignition ON.
3. The letters "SERVICE" will appear in the trip recorder display.
4. Release button [A].
5. Turn the button [B] to the left for approximately 2 seconds to reset the display.
Important note:
For vehicles with Longlife Service QG1 type, the Service Interval Indicator can only be reset with the VAG or similar diagnostic tool connected to the data link connector of the car.
May 25, 2011 | Audi TT Cars & Trucks
Tape to tape recording
Just put the tape to be copied in side A while the other the blank tape in side B. Press the play in side A . Then in side B simultaneously press the "Play " and the "Record". Then it will starting to record it will automatically stop.
Good luck:
Dont forget to rate:
Jul 01, 2009 | Panasonic SC-AK18 CD Shelf System
Will not record or play back VHS for more than 30 seconds
I can tell you some ideas genericaly for VCR's.
This could be an idler wheel assembly problem, or a tape tension, or a reel torque problem.
It can also be a power supply problem where the supply is working just on the edge. Due to some worn components in the supply it can be partialy shutting down.
Your machine will have to be checked out by an experienced VCR tech.
Jerry G.
Dec 04, 2008 | Radio Shack Accurian ADR-0106
JVC RC-QN2 - How to use the microphone on this unit?
That model seems to pre-date JVC's online manuals.
Let's try a little logic here though:
- Can it record on FM?    No - Can it record on CD?   No - Can it record on tape?   Probably. And if it is set up as most such devices, it will have to be switched to 'Tape,' then 'Record' and if you don't wish to actually put anything on tape, you may still have to have one in the drive and just leave it on 'Pause.'
Sep 14, 2008 | JVC RC-QN2 Cassette/CD Boombox
Camera not recording finished project from computer
clean the head using the VHS head cleaner. try diff tape.
Mar 06, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
 Grubhead
Grubhead
