Question about HP Pavilion TX2000Z Notebook
I recently purchased an HP Pavilion dv7-4087cl laptop. The mousepad includes a feature which makes it amazingly useless. When you touch a button with your thumb without first taking your finger off of the pad, it moves the cursor. For some unknown reason, someone somewhere decided that the button should act like it is just another part of the mousepad only with a feel of a click when tapped. Is there any way to turn this feature off or do I now have a $1000 doorstop?
    Brigadier General:
  • 8,909 Answers
I find it useful. A bit like the thumbwheel on an IBM mouse.
Anyway, I would go into the touchpad settings within the device manager and switch it off if you want to.
Hope this helps.
Posted on Jan 01, 2011
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
http://www.buy.com/prod/90w-laptop-ac-adapter-charger-for-hp-pavilion-dv5-1125nr-dv5-1127cl/q/loc/101/215845345.html
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
Jan 13, 2011 | HP Pavilion dv5-1125nr Notebook
The touchpad is not working.
Right click on 'computer' icon
Select 'properties'
Choose 'device manager'
Look downlist to find touchpad listing 'mice and other pointing devices'
Click 'disable'. Then 'enable'.
Try again with touch pad.
You may need to uninstall the driver and the reinstall.
Jan 10, 2011 | HP Pavilion dv5-1000us Notebook PC
Am having an HP laptop.Now i am having a problem with my mouse touch pad..the touch pad is working,but i am not able tpo clink on anyfile using mousepad.The coursers are moving when i scroll on th mouse...
Your laptop needs to visit a laptop service/repair centre.
However you can purchase and make use of a USB mouse; it'd serve.
If you own one, use it instead.
Oct 13, 2017 | HP Pavilion TX2000Z Tablet PC
My mousepad's scroll feature is no longer working after I took my laptop to Best Buy and had them install a new harddrive under warranty
Right above the Touchpad is the On/Off button to Enable the Touchpad, or Disable the Touchpad.
If the Touchpad light is on, then the Touchpad is Enabled. (The On light is right above the Touchpad also)
Do you have the Touchpad enabled?
Dec 12, 2009 | HP Pavilion dv1000 Notebook
I want to disable the "click" feature of the touch paD on my HP Pavilion DV2000 laptop. It is too sensitive and I want to only click using the buttons. Can you help me find the settings ?
Some laptops have a button directly on them to disable the touchpad feature, if you do not have one of theses. Look in your control panel for touchpad software. Synopsis TouchPad software is one of the more popular softwares, If you see this red ICON in control panel, open up the configuration window for it and there you will able option in there to disable the tap click.
Nov 02, 2009 | HP Pavilion dv4000 Notebook
Not working for my vertical scroll zone howcan activate this problem
Assuming you're talking about the touchpad, this can be enabled and disabled in your control panel.
Open your start menu, then Control panel, if it's not in classic mode click the Classic View link in the top-left corner. Now open the mouse icon and select the Device settings tab(red logo), now click the settings select by single clicking the synaptics touch pad from the list. click the settings button below the list and select the "Virtual Scrolling" section.
You will see two check boxes, the First enables the marked off vertical scrolling feature, the second enables a horizontal scrolling feature that may not be marked on the mousepad but runs along the bottom of the pad and works the same way.
Click OK, on both windows and close the comtrol panel.
Hope this helps FixYa, if not reply back with any additional info you can,
Chris
May 12, 2009 | HP Pavilion dv6000z Notebook
Thinking about purchasing a HP loading dock HP DV2000(ES631AA)
Compatibility document.write(neg_specification_newline('HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Note: When using a notebook that requires the included Expansion Accessory Adapter, the following functions will not be supported on the HP Notebook QuickDock: VGA port functionality, stereo microphone (only mono is supported) and power button (must use the notebook power button).')); HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Apr 18, 2009 | HP Computers & Internet
Hp dv7-1132nr Quickplay touch button doesn't launch quickplay.
i have same problem. Only wirelles button work. I dont know what to do? Is there any solution for this ? Is this hardware or software problem ?
Mar 13, 2009 | HP Pavilion dv9000z Notebook
Hi, i have recently bought HPpavilion dv2998se special edition notebook PC( laptop). It has come with an vista home and had an 60days or some days .Now iam not able to use MS office applications like...
The software was trial software and it has expired,The only way to continue use is to purchase it.(A purchase link is included in the trial software)
Please rate this fixya
Jan 29, 2009 | HP Pavilion dv2988se Laptop
HP Pavilion TX2000Z Notebook Logo
243 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
