Question about Dryers
What is the purpose of the T-O-D MICROTEMP unit?
I need to replace my Krups 453 Thermal fuse (ms-0061607). Where can I find one or is there a replacement?
They are obsolete and quite a high temperature rating for a coffeemaker (300 deg C) You could get someone to replace it with a 240 deg C microtemp and see how that works out, boiling is 100 deg C and coffee goes into your cup below that so it is quite reasonable to expect 240 deg C to be fine. I'm pretty sure that is the highest temperature microtemp available.
Jan 05, 2015 | Krups Coffee Makers & Espresso Machines
Will not heat
there is a white felt like tube on the top of the tank after you remove the top you will see this slide it out and replace the 2 microtemp fuses part number g4a01 at 141c. or 285.8 f use 2 of them just like they are in the unit . if too mutch to handle call bunn if under 3 years they will replace whole thing
Apr 17, 2014 | Bunn GRX-B
Microtemp thermal fuse
Contact a large electronics supplier. eg: Kohen Electronics in Red Deer
Apr 03, 2012 | Dryers
Unit stopped in middle of cycle tested to microtemp fuse nothing across?
On that thermal(microtemp) fuse if you found it to be open that is going to be the problem it should be closed with zero ohms resistiance
Gene
Aug 15, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Km7000 will not brew
Your heating plate/water heater has failed. Krups replace my whole unit.
Aug 15, 2009 | Krups KM7000
Krups km7005 water not heating nor hot plate
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbech, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Aug 01, 2009 | Krups Small Appliances Espresso Machine
My gr31sb grill wont heat up, i found the microtemp g4 thermal fuse is bad by by passing it and the grill works. how do i get a new fuse?
Don't know if this helps but Radio Shack has Microtemp 10 amp G4A00 Tf 144c (144 deg Celcius) Thermal Fuses. These are the ones with the little red conical end on them. Under $2 each. I needed one to put in my toaster oven. Couldn't find the small metal clips to attach it to the wiring though. Since it is very diffucult to solder these without damaging the fuse, I'll have to recycle the old clips.
Jul 24, 2009 | George Foreman GR31SB Indoor Grill
Blown microtemp fuse
Hi man, take a look here" http://www.tod.com/productdetail.asp?ProductID=30. I think u know what to do next ...
Apr 08, 2009 | Toastmaster TOV200 Toaster Oven with...
Power doesn't come on anymore
I determined that the thermal fuse in the Gaggia Classic that I am repairing had tripped and it is not re-settable. The fuse has the following stamped on it: MICROTEMP SKMAHD G4A00 184C I believe that is what is the culprit for all of us when the "power doesn't come on." Now, what is the rating of this fuse and where can I get a replacement? The fuse is the small resistor-like, diode-like part in a clear tube mounted against the boiler, and it must be physically cut out of the line to replace it!
Apr 30, 2008 | Gaggia Classic Espresso Machine
Heat
I found one on e-bay .. At the following link ,and my temp on my coffee maker (( Black&decker )) was at 216 C but I plan to up it du to the fact that there is a total of 3 thermal fuses in there . Hope this helps !!!!!!!!!
Rick @ www.antler-lights.com
http://cgi.ebay.com/Microtemp-Thermal-Fuse-You-specify-temp-required_W0QQitemZ140036901378QQihZ004QQcategoryZ66753QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
Sep 23, 2007 | Faberware FCP240 Coffee Maker
Dryers Logo
515 people viewed this question
Top Dryers Experts
