Question about Epson Stylus Photo 1400 Printer
Waste ink goes to external tank but I need to set the counter. On a CIS system which has been reset
I DOWNLOADED THE SOFTWARE BUT I AM USING A MAC AND IT DOESN'T RECOGNIZE A PROGRAM TO OPEN IT WITH. ANY SUGGESTIONS?
Posted on May 16, 2014
  • Epson Master
  • 3,267 Answers
The free SSC utility which will reset the waste ink pad protection counter in most Epson inkjet printers can be downloaded from
http://www.ssclg.com/epsone.shtml. Remember though, if you don't change the ink pads, there will be an increasing danger of ink leakage from your printer, particularly if you tip it up for any reason - VERY messy, and it can clog up your printer mechanisms.
Posted on Jan 01, 2011
What is error P7 on Canon MP250 printer?
Please refer to this video, to fix it:
https://www.youtube.com/watch?v=HvBpioLPm3M
Inkjet printers has an "ink absorber" counter in which when it has reached a certain level that error will occur. Because when you are printing, some parts of the ink become waste ink & goes to the internal "tank" inside the printer where they are dried. The ink absorber counter tells you that the "tank" is nearly full which might flood the internal parts of the printer and damage them, causing short circuits.
However, this error could be bypassed by resetting the printer as described on the video.
Another better solution is by installing an external waste ink tank to channel the waste ink outside the printer to avoid internal damage. The P07 error will still occur, however you can bypass it.
Apr 28, 2014 | Office Equipment & Supplies
Epson l200 servce required problem
Never had one of this series, but I have went through about 25 Epson printers and the message you refer to means your waste ink pad needs to be cleaned or replaced.
To get rid of the message do a search on "how to reset waste ink pad counter for Epson l200" and you will find a utility that does what you want.
Feb 25, 2014 | Epson L200 Original Continuous Ink Tank...
Ink pad resetter for epson L110.. please help me..
The L110 needs the WICReset utility to reset the waste ink counter and a key to do that too.
I believe the WICReset tool will also reset the ink levels without needing a key so if you can source the necessary bulk ink locally you should be able to get printing again.
Aug 02, 2013 | Epson L100 Original Ink Tank System...
MY PRINTER IS TELLING THAT PARTS IN MY EPSON R220 NEEDS SERVICE
download .epson reset for printer,google will reset counters
Jul 05, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson r230
Apologies for the late response but this is a pretty standard issue ie: your waste counter in the printer memory has triggered a warning.
To solve it you need to either
  • Get the printer serviced which will replace the printer pads and reset the counter.
    OR...
  • Modify your printer to redirect waste ink to an external waste ink tank. Then use a suitable software utility to reset the waste ink counter.
For the latter approach, you can use the SSC utility to handle the reset and there are various kits out there pre-built or you can fashion a tank yourself if you're feeling adventurous..
Hope that helps..
Martin
Jul 04, 2009 | Epson Stylus Photo RX600 All-In-One InkJet...
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Printer send s message Life of parts ending
The "end of life" message means that the waste pads are full of waste ink.
You need to either:
  • get the printer serviced at an Epson service center
    OR
  • install an external waste ink counter and reset the waste ink/protection counter.
All the information you need to install an external waste ink tank is available from here:
http://www.continuousink.info/forum/viewtopic.php?t=4096
Resetting the waste ink counter is easily done using the IPR utility which you can read more about and find downloads for, from here:
http://www.wasteink.co.uk/epson-ipr-reset/
Hope that helps..
Martin
May 19, 2009 | Epson Stylus R340 InkJet Photo Printer
Epson 2400 paper red light and ink red light
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
Mar 07, 2009 | Epson Stylus Photo R2400 InkJet Printer
Epson cx2900 3 in 1 printer
the problem might be the ink, change the cartridge maybe the ink dried out....
Sep 05, 2007 | Epson Stylus C84 InkJet Printer
Epson Stylus Photo 1400 Printer Logo
171 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
