Question about Brother Office Equipment & Supplies
Continous 'change drum soon' message after I change the drum.
  • 3 more comments
  • Anonymous Jul 15, 2008
    I'm currently seeing a "change drum" on the fax machine. I also have attempted to print out a fax report several times and the fax machine switches over to sleep mode.
    1. Where is the drum to change?
    2. Why wont it print a fax report
  • JuliaFertig Jul 15, 2008
    I am currently sitting here at work attempting to figure out two things with the brother IntelliFax 2820. It is flashing the "change drum" and I don't have the slightest clue where to locate this and haven't found a feasible anwser in your support area. Also, I've made several attempts to print out a fax report but the machine switches over to sleep mode as soon as I attempt this. Any help would be great! Thanks!
    Regards,
    Julia
  • Anonymous Oct 16, 2008
    trying to recieve faxes but the fax machine keeps going to sleep mode and reads also change drum soon. How can I get this fixed and recieve all my faxes
  • Anonymous Feb 20, 2009
    i HAVE THE MESSAGE change drum soon
  • Anonymous Apr 07, 2009
    I change the drum and the "change drum soon" is still on the screen.
5750e fax machine: To reset the drum counter follow the instructions listed below :
Get the message to appear in the LED
1. Open the front cover.
2. Remove and Re-insert Drum/Toner unit
3. Press the CLEAR key.
4. Press 1 to reset.
5. Close the front cover, pressing firmly on each side until they click
into place.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000007572&Sympt=Why+does+the+message+CHANGE+DRUM+SOON+continue+to+appear+on+the+LCD+display+after+I+replaced+the+drum%3f&Model=58&ProductGroup=2&Keyword=Change%20drum%20soon%20message&ProductID=PPF5750e
Posted on May 27, 2009
Try hitting the button "Stop/Exit" and "Change Drum Soon" will not be there anymore. It should show the current date and time.
Carol
Posted on Aug 18, 2008
3 Suggested Answers
SOURCE: change drum soon will not clear after new drum inserted
Reset of the drum counter
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
Hope this helps...
Posted on Jun 12, 2008
Logjam
  • 159 Answers
SOURCE: Change Drum Soon still shows after changing the drum unit
After changing the Drum, open front cover and press "clear" then press "1" to reset.
Posted on Jul 23, 2008
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Alarm says replace drum soon. Can the message be
The "replace drum soon" indicater is a warning for you to have a new replacement drum "on-hand". Soon the display will change to "REPLACE DRUM" AT WHICH TIME THE UNIT WILL STOP PRINTING.
When the new drum cartridge is then installed...the REPLACE DRUM indicator will be reset. DO NOT replace the drum before the machine says to.
Jun 04, 2010 | Muratec F320 Plain Paper LED Fax
How do i reset the message change drum soon on
Press Clear.
8 Press 1 and when the LCD shows ACCEPTED,
and then close the front cover.
Jun 05, 2009 | Brother IntelliFAX 4100 Laser Fax
FAX SAYS TO CHANGE THE DRUM SOON
Open the front couver as if you are about to change the drum unit. With the couver still open, press the options button for a while and in the display will apear a message asking if you want to change the drum unit. Choise the yes option and close the front couver. GOOD LUCK.
Nov 13, 2008 | Brother IntelliFax-2820 Laser Fax
"Change Drum Soon" Message; not change when we changed the drum.
Description:
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
Aug 07, 2008 | Brother MFC-7820N Laser Printer
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
Jul 30, 2008 | Brother IntelliFAX 4100 Laser Fax
Jul 22, 2008 | Brother IntelliFAX 4100 Laser Fax
Changing the drum
I fixed the problem (following the user's guide).
1. After reinstalling the new drum unit into the printer, keep the front cover open.
2. Press "Clear/Back" on the machine
3. Press "1" and when the LCD shows "Accepted", close the front cover.
May 14, 2008 | Brother DCP-8040 Copier
Replace Drum Soon Message
Read your manual. There is a counter that goes off, that can be reset when you change the drum.
With power on and front cover open press set, then select reset drum
Mar 25, 2008 | Brother MFC-7820N Laser Printer
1,402 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
