Question about GE DBXR463EBWW Electric Dryer
When my dryer has been on about 20 minutes, it starts a loud roaring sound. what can this be? should i be looking at purchasing a new one?
  • GE Master
  • 7,482 Answers
Your drum rollers probably have flat spots on them or need lubrication...both are cheap repairs, you do not need a new machine..follow these directions to solve your noise problem
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Jan 01, 2011
What is a roaring loud sound in front of 2000 chevy cavilier
Bad front wheel bearings will make a loud roaring sound, and get louder as time goes by, check this out! God-Bless!
Oct 01, 2017 | Cars & Trucks
Dryer is making a loud roaring noise when on but still works fine
Hmp..Maybe there's a part of the dryer need to be fixed.. Make sure to contact the service provider of that product,,k
Jul 15, 2012 | Kenmore 800 7982 Dryer
Spin cycle at high rpms is an extremely loud roar. This has changed considerably since purchased 2 years ago
This sounds like main tub transmission bearings.
Not economical to fix
30 years Experience in Home Refrigerator,Washer,Dryer, Repair
I would love to help you find a solution.
Leo Ponder
imufo2
Aug 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our dryer starts up and runs for a while (15-25mins) then a sound develops and the dryers stops working. It appears that whenever it cools down it will run again. On start up sometimes a strange sound is...
You definitely have a motor issue starting to develop. The motor bearings will usually allow the motor to run initially, but start to get loud after they heat up and eventually bind causing the motor to stop. The motor has a thermal switch on the side that will shut the motor off if it gets too hot, and will re-set after about 15 or 20 minutes.
The motors for this style dryer (I can't look up the exact part as I need the complete model # off your machine's model tag) are usually about $140-$160.
If you would like to get the motor and install it yourself, let me know and I can provide you walk-through directions on replacement of the part.
Aug 18, 2010 | Kenmore 800 6983 Electric Dryer
Hi, my GE model DBXR463ED1WW dryer is LOUD!
Roaring could be an over firing burner or fan related. Squeak or rumbles are bearings. Is the noise all the time or only when the burner is on? Eric
Jun 20, 2009 | GE DBXR463EBWW Electric Dryer
Roaring Sound During Operation of Dryer
Does the roaring sound occur after the machine warms up? If so, it could be a bad drum bearing. the heat from the dryer causes it to expand in its housing and, since it may been defective, could start "roaring". If so, The dryer drum shaft/bearing assembly will need to be replaced
If however, the roaring is immediate upon start up then u may have a bearing in your dryer motor. The entire motor may have to be replaced.
Dec 07, 2008 | Whirlpool LER4634J Electric Dryer
1997 Dodge Stratus, unknown roar
Try replacing the front end wheel baring(s) If it is a roar that you can hear resonating from the windows, this is most likely it.
Sep 07, 2008 | 1997 Dodge Stratus
GE DBXR463EBWW Electric Dryer Logo
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
