Question about OEM Systems PIXMA iP3300 Photo Printer
I have a canon IP3300 It won't print with black ink & instead uses other ink to print green colour using M. excel. While in other application, the printer won't use the black ink to print & produce blank white paper. The cartridge is recognized by the printer & PC, but it won't print in black. Please i need your help, thanks!
Inky
  • 691 Answers
SOURCE: usb printer problem "port in use please wait"
Can you advise which operating system you are using? Assuming 32bit windows: Unplug the printer from the USB and try deleting the printer from the printers folder. Then download the latest driver from the Canon web site. Once you have you have it, in the control panel go to SYSTEM and into HARDWARE tab and then DEVICE MANAGER. Look under UNIVESAL SERIAL BUS CONTROLLERS and check that there are NO yellow symbols. If there are yellow symbols you need to remove the offending item from the list (making a note of it's description) and then reboot your machine. When it comes back up it should advise that new hardware has been found and go through the process of installing the drivers. You can now go the manufacturers web site and download the USB controller driver for your device. If the file is a zip extract it to a folder on your PC. When it asks if it can go online to find a suitable driver, let it do so and you can also specify a location for it look (where you extracted the download above) Once it finds the driver required and has finished installing it, reboot your system and then install the printer driver you just downloaded. Hopefully this will get you back on the go. If you have a windows 64 bit system I'm afraid you are on your own. 64 bit drivers that work are very hard to come by. Let us know if this is any use to you, if not we may more to offer.
Posted on Sep 16, 2007
SOURCE: Printer won't recognize ink cartridge
Guest again:
Called Canon.   It is a defective cartridge and they are going to send me a new one once I fax in my receipt for the purchase of the printer.
Posted on Oct 24, 2007
  • 125 Answers
SOURCE: Canon IP3300 won't print in black
I'm not sure but we have been having similar problems w/ both new and refilled cartridges. We notice that prior to putting the new cartridge, if it was placed upside down meaning on the flat side where it can stand up, we usually have problems w/ printing. Either no ink or streaks. I haven't tried this cuz I just finished tearing one cartridge apart. There is a small vent hold on the top near the middle. I was planning to get something that could plug the whole tight enough for a syringe neede to be able to pump air into the cartridge to force the ink out on the other side. It could be that the cartridge may have gotten some air. Though I'm not sure. I was going to do this but I have to leave in 10 min. If you pump air in do it gently and maybe 0.5-1ml. Make sure you have tissue or newspapers under the cartridge to absorb what gets pushed out. I would assume that the cartridge would not leak after I take the syringe out, I'd then try printing w/ it. No need to take the hole. It is canon's original vent hole anyway designed to stay have air passing through anyway. Let me know if you succeed. I will do the same thing tomorrow to see if it works. My email is renaisans@gmail.com Miles
Posted on Mar 01, 2008
  • 2692 Answers
SOURCE: CONTINUOUS FLOW INSTALLATION FOR IP3300
No . not very likely as the continous flow goes into the cartridge , correct? The electric contacts which must stay wet will still be wet.
Posted on Feb 16, 2009
puertobori
  • 7733 Answers
SOURCE: After a few years of
Try:
Posted on Nov 02, 2010
Can I use prodot black colour to my canon ink tank instead of esyink black colour
One can never recommend using non genuine printer ink as many are watered down and tend to splash around the printer . This can cause more problems in the long run. Pro dot is just a trade name. You can take the chance and you may be lucky. Its really a personal thing. I use Sainsbury's ink and have had no problems with it. It's up to you.
Dec 08, 2016 | Canon Office Equipment & Supplies
Canon IP3300 won't print color
hi chette,
its a common problem for printer dye ink,have you try to use other cartridge? a brand new one maybe?
if you insist using the old one, try these step.
1. use vinegar to clean your cartridge head
2. put a little vinegar into the cartridge
3. try deep cleaning it.
it only work for dye ink base not else :D
ciaw.
Jul 11, 2012 | Canon PIXMA iP3300 Printer
My canon pixma ip3300 printer black ink can recognize but when printing no black ink out
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jan 19, 2012 | Canon PIXMA iP3300 Printer
Cannon pixma ip3300 is not printing in black only color, (windows 7)
Does your blank ink cartrdige filled with ink?
Or before you print Click on the Properties button. Click the Color Tab\Print in Grayscale\Black ink only
Mar 18, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
My ink jet did not print
You must change both cartridge. Instead use completely new cartridge Part No 830 black and 831 colour
Sep 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer print blue instead of black
I have the same problem with my ip 5200, when printing a document in plain black.. I spoke to canon support and they suggested to save the .doc document as a txt file before printing. It works. Not too sure if this uses any colour ink to produce the black.
You can also set the printer on grayscale. However, the printer uses the colour ink to produce black.... hence printing in black & white becomes rather expensive.
If anyone has drivers to fix this problem please let me know...
Jul 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
My canon i960 is printing only green
I had this problem. If I tried to print a black& white photo on to glossy paper, it would only print green. When I tried on to plain paper using the 'fast' option, it printed in black. The reason for this is, on plain paper it uses the black cartridge, but output to glossy photo paper using the 'high' option, uses the mix of colours in your colour cartridge. If one or more of your colours has run out, you will get a print with the ink left in the cartridge. Replace the cartridge or refill it & your problem is solved.
Dec 19, 2007 | Cannon Canon i960 Photo Printer
How to reset waste ink absorber full ip3300 warning?
Try to enter service mode and reset EEPROM:
1. Start with the printer OFF
2. Hold down RESUME and then hold down POWER
3. release RESUME
4. press RESUME twice, then release POWER
5. Let green light blink until printer is done moving print head
Press RESUME 4 times then POWER to execute the command
turn the plug off turn on and all ok
Dec 13, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
OEM Systems PIXMA iP3300 Photo Printer Logo
245 people viewed this question
Top OEM Systems Office Equipment & Supplies Experts
k24674
 Russ Hill
Russ Hill
Are you an OEM Systems Office Equipment and Supply Expert? Answer questions, earn points and help others
