Question about Miele W460WPS Front Load Washer
Miele715. "main wash" light flashing. all cycles
5 Suggested Answers
  • 85 Answers
SOURCE: WASHING MACHINE BLOCKAGE
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Mar 02, 2009
Mark Harmer
  • 8 Answers
SOURCE: Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Posted on Sep 21, 2009
  • 70 Answers
SOURCE: 10 year old miele 300 washing machine jumps to
Most likely brushes. Fit carbon brushes part no.4297411 as they are less then half the price of the brush module Part no. 4229779.
Posted on Jun 19, 2010
Daniel S
  • 4323 Answers
SOURCE: My Miele W360 WPS Washing
Hi
The issue seems to be with the drain pump motor that is bad and should be replaced. However, before replacing remove the hoses to the main motor, remove electrical connections & remove motor (single screw holds motor; it is on the outside back of the machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate it, then motor will be required. If the error still appears then cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Posted on Jun 27, 2011
Why do my machine flashes red lights when pluged in AC and nothing else works ?
Replace doorlock and mainboard.
If all five spin cycle buttons flash, its a fatal error.
It depens on which wash button that ligths up.
One of them is doorlock error, the other is main board error
May 21, 2014 | Bosch WAE24166GB
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
My Frigidaire dishwasher - most buttons don't work and clean and sanitized lights are flashing after cycle completes.
Hello Rich - From what you have described if only some cycles are working, then there seems to be a communication problem coming from the main control panel, I would suggest contacting a professional technician to diagnose the unit.
Sep 23, 2012 | Frigidaire Dishwashers
Currys essentials dishwasher error warning
I have a curry s essentials CDW60W10 dishwasher that isn't completing any wash cycles can anyone suggest anything ? Machine isn't leaking wont select hard spray in cycle or drain
Aug 24, 2012 | Dishwashers
What is Error Code "F6E1"
I had the f6 e1 code flashing on Whirlpool Duet washer. It would stop midcycle and beep. I cleaned out the lint filter. This seemed to help but gradually the problem got worse. I cleaned filter again. Still beeping. I read more solution and finally found the answer! I never put the cover back on. There is a switch on the left bottom that is held in by the cover. Works fine now!
Jan 14, 2012 | Whirlpool duet Washing Machines
Washing machine keeps beeping then all lights and screen start flashing.
i would guess that you have a faulty main board, the quickest and surest way to determine the problem and that is to replace it with a second hand board out of an known old machine which has faulty seals.
Dec 11, 2011 | Fisher and Paykel Washing Machines
Dishwasher miele g646sc-the inlet/drain light flashes yet the drain system is clean and working the inlet filter is clean and the filter washed
Hi dear.If the checked lights comes on after the main wash & then flashes(when on main wash cycle,if the main pump works for a few minutes & then stops for a while & so on...)that indicates main wash pump faulty.You need to replace the motor it self.I hope that helps.Thanks.
Aug 25, 2010 | Dishwashers
Miele W460WPS Front Load Washer Logo
32 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
