Question about HP Office Equipment & Supplies
Do i have to turn the printer on when i want to print or does it go on automaticly
    President:
  • 2,992 Answers
If the power is off, you need to turn it on manually. If the power is on but the printer is idle, it will start printing automatically when the operating system sends a print job to it.
Posted on Jan 01, 2011
How to stop automatic "activity report" printing
in the menu section search for activity report and turn it off
Apr 18, 2016 | Canon PIXMA MX452 Wireless Office All In...
After giving the print to immage runner 400s copier the print sends to the copier. The data button blinks once. but print out automatically cancels. why?
Windows Server 2003/Thin N Computing thin client L300 Printer Epson FX2175 installed with thin client when dos base print command is given 1st page is printed but when 2nd print command is given printer gets offline either switch off printer before giving comman or print from printer properties. Again third page print command is taken by printer (For alternate pages print command printer gets offline automatically)
Aug 29, 2012 | Canon imageRUNNER 400S Copier
How to duplex print with 895cxi
This model printer does not have a duplex unit and cannot print double sided documents automatically.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 08, 2012 | HP DeskJet 895cxi InkJet Printer
Lexmark x646e turn off after 3 mins
Try updating the firmware of your printer: http://bit.ly/P8Ng6S
May 24, 2012 | Lexmark X646e All-In-One Laser Printer
PRINT SPOOLER SERVICE IS NOT RUNNING MSG DISPLAY WHILE ADD PRINTER AND COULD NOT COMPLETE THE OPERATON
You need to go into services and turn on Print Spooler.
Start Run Type services.msc Click ok Scroll down to print spooler. Right click the entry Click restart.
Check that its startup type is set to automatic as well Right click the entry for print spooler Click Properties Select Automatic in the Startup type dropdown box. Click apply Click ok.
Aug 09, 2011 | Canon LASER SHOT LBP-2900 Printer
Can not print on two side of the paper
Not enough info. Not all printers are capable of printing 2 sides automatically, most are manual. You print one side, turn over the paper in the feeder and print the second side. Read your manual to see if it does 2 sided printing automatically.
Dec 29, 2009 | Epson Office Equipment & Supplies
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
Turn off the setting align ink catridge
go to SETTINGS , then go to DEFAULT of FACTORY DEFAULT click here, turn off PRINTER then turn ON again , see what happens , let me know , AJ
Aug 08, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP C4200 Printing both sides
Some printers automatically print on both sides of a page (automatic duplex printing); other printers allow you to manually reinsert pages to print the second side (manual duplex printing); and some printers do not support duplex printing at all. To find out whether your printer supports duplex printing, you can check the printer manual, contact the printer manufacturer, or check the printer's properties by clicking Properties in the Print dialog box.
To find out whether your printer supports duplex printingThe options in the Print dialog box can vary depending on your printer options and configuration.
You can use the following clues to determine whether a specific printer supports duplex printing:
  • Check your printer manual or consult your printer manufacturer.
  • Click the tabs in the Print dialog box and review the options. If options such as print on both sides of the paper, duplex printing, or two-sided printing appear on any of the tabs, the printer probably supports automatic duplex printing.
Notes
  • If you are printing to a combination copy machine and printer, and the copy machine supports two-sided copying, it probably supports automatic duplex printing.
  • If you have more than one printer installed, it's possible that one printer supports duplex printing and another printer does not.
To manually set up a printer to print to both sides of a sheet of paperWith some printers, you can use the Manual duplex check box under Printer in the Print dialog box. Word will print all of the pages that appear on one side of the paper and then prompt you to turn the stack over and feed the pages into the printer again.
You can also use the following procedure to set up your printer for manual duplex printing:
  1. On the File menu, click Print.
  2. In the lower-left corner of the Print dialog box, in the Print box, click Odd pages.
  3. Click OK.
  4. After the odd pages are printed, flip the stack of pages over, and then in the Print dialog box, click Even pages.
  5. Click OK.
Note Depending on the printer model, you might have to turn and reorder the pages to print the other side of the stack.
Sep 08, 2008 | Office Equipment & Supplies
X3470 printer installation
One of the most possible reason is related to Print Spooler service. Please check the "Print Spooler" service if its turned on. if its not you can turn it on. Here is the way to go Services screen
  • go to start menu then run and type "services.msc" then hit enter
  • locate the Print Spooler service in the services list
  • Change turn it on  switch to Automatic mode
Try reinstall
Good Luck
Dec 29, 2007 | Lexmark X3470 All-In-One InkJet Printer
26 people viewed this question
Seeker5211
Seeker5211
