Question about Music
OMS 2.8.3 with Cubase Audio XT for Mac OS 7.5 does not support MMC Punch-in record commands? Setting Cubase to MROS instead of OMS lets these commands through - furthermore - in OMS un-checking Midi Machine Control in the Steinberg ACI device setup does not influence performance, and play-locate-stop still work! what's going on?
5 Suggested Answers
  • 10 Answers
SOURCE: Electronic drum kit, with USB out, problem
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Posted on Aug 07, 2008
  • 1138 Answers
SOURCE: Problems setting midi channels using KN3000 and Cubase
If you are sequencing midi tracks you can imbed the patch change in the track and the midi channel assignment and when the sequence plays the info will be sent to the keyboard. Do you have it set to receive Omni?
Posted on Apr 25, 2009
  • 1138 Answers
SOURCE: Hook up CASIO CTK-720 to Imac with Snow Leopard (10.6.2) G-Band
Thanks Francois. This is good advice. It is posted in the problems and questions section of musical instrument repairs.
Posted on Nov 30, 2009
  • 65 Answers
SOURCE: does the Steinberg C1 has
In a word: no
Posted on Sep 15, 2011
Crackling and popping during playback/recording, latency issues. Using Firestudio Project, Windows 7 and Cubase 5.
Turn OFF all resource hogs such as Anti-virus, Anti-pop-up, and other background programs. Disconnect all internet access such as wireless and Ethernet service programs. All these resource hogs and programs for instance that keep track of when to run scans just cause interrupts of the servicing of the high speed audio grabbers. Your machine should be BARE of all these hogs.
Feb 23, 2011 | PreSonus Firestudio 2626 26x26 + Cubase...
Problems with yamaha mw10c usb mixing desk i have a signal on desk but cubase is not picking it up and i can find no option in any cubase menu to read the usb audio
Make sure that in the control panel of Windows, "Sounds and Devices" under the "voice and recording" tab, the Yamaha mixer is shown as the device for both voice recording and playback.
Feb 04, 2011 | Yamaha MW10C 10-Channel USB Mixer
Hi, I bought a Lexicon Alpha in order to use with Apple Mac (Logic). Now, my microphone is a dynamic microphone so it does not need any phantom power. When I connect the usb cable, the blue light comes...
I suspect the problem is with the software setup in your PC. Verify all the options and also verify that the AUDIO system is assigned as stereo and assigned to the Lexicon for both in and out... Also check any "PAN" control settings. There is a possibilty that the Alpha has a dead channel...
Try putting a stereo signal into the 1/4 inch jacks and see if both record... if NOT then take it for repair under warranty... I had a Lexicon Omega that had a problem myself... warranty repair...
Jan 10, 2011 | Lexicon Alpha Personal Recording Studio
I have a behringer Xenyx 1622 mixer and am using cubase when i plug it in the it says its ready to go but, something happens and theres no volume..and i cant set it up in cubase?...any suggestions..
When you open Cubase you MUST open a new project.
Then select 24 track audio for example... unless yoou are doing MIDI record and playback.
Then open up a mixer panel and select a channel to read or connect to a file.
There are too many options to describe and the "says its ready to go " is not enough information to know where you are.
You may have to imprt files or record music... Don't forget to select a track on the display of tracks.
Apr 27, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
How do i get my samson c01U mic to work with windows vista and cubase le?
plug your condenser microphone into your computer before starting up the cubase program; then after you plug it into your computer start cubase; when cubase loads, press the [F4] key, then that will bring you to the audio configuration menu, there will be a speaker option and microphone option or what ever that stuff is; go to the microphone option and choose the microphone that you are using, then after you choose your microphone setting click close; then after that make create a [audio] then on the audio tab you will see a red button, by pressing that it will allow you to record, but there is another button beside it called a [monitor], press that button then it will allow you to hear your voice while you record your vocals. hope this help.
Apr 21, 2010 | Samson Audio C01upak C01u Microphone and...
My PSR 550 giving signal (thru m audio fast track)...but no sound
You have to decide whether your keyboard will function as the controller to send the midi info to your program and have the program use the onboard sounds on your soundcard or use the sounds on your keyboard.Here is a link to a forum that I highly recommend:http://www.recordingreview.com/ It is free to join and the free download of Killer Home Recording Setting Up is great. There is lots of info on this site that will explain exactly what you need to know.Check out midi troubleshooting 101 and Getting Started with Midi Sequencing. The site owner Brandon Drury uses Cubase himself and I highly recommend their forum. Hope this helps.
Mar 02, 2010 | Music
CAN'T GET ALPHA TO WORK IN CUBASE OR AUDACITY ?
See if this info here will help you:http://www.lexiconpro.com/knowledgebase.php?product=7 Let me know if this helps.
Nov 30, 2009 | Lexicon Alphaâ„¢ Desktop Recording Studio
Yamaha Psr-340
I don't have Cubase myself but there must be a track setting that allows you to monitor what you are playing live. Also make sure your keyboard shows up as the midi controller on the software. Your receive channel has to match the send channel of the keyboard. Make sure that synthA or synthB shows up as the sound source (audio out). XFi Midiport is your midi in but since Cubase already sees your keyboard your problem is an audio one not a midi one. Hope this helps.
Jul 18, 2009 | Music
Apr 23, 2009 | Music
Music Logo
48 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
